usb使用ch348l扩展8路串口
在Linux系统有如下报错,或导致串口号异常变化
[235788.049659] usb usb3-port9: disabled by hub (EMI?), re-enabling...
[235788.049664] usb 3-9: USB disconnect, device number 5
[235788.050135] usb_ch9344 3-9:1.0: usb_bulk_msg(send) failed, err -19
[235788.050138] usb_ch9344 3-9:1.0: usb_bulk_msg(send) failed, err -19
[235788.050139] usb_ch9344 3-9:1.0: usb_bulk_msg(send) failed, err -19
[235788.050154] usb_ch9344 3-9:1.0: usb_bulk_msg(send) failed, err -19
[235788.050155] usb_ch9344 3-9:1.0: usb_bulk_msg(send) failed, err -19
[235788.050157] usb_ch9344 3-9:1.0: usb_bulk_msg(send) failed, err -19
[235788.050158] usb_ch9344 3-9:1.0: usb_bulk_msg(send) failed, err -19
[235788.050389] usb_ch9344 3-9:1.0: ch9344 usb device disconnect.
[235788.273149] usb 3-9: new high-speed USB device number 30 using xhci_hcd
[235788.399455] usb 3-9: New USB device found, idVendor=1a86, idProduct=55d9, bcdDevice= 1.36
[235788.399460] usb 3-9: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[235788.399461] usb 3-9: Product: USB2.0 To Multi Serial Ports
[235788.399463] usb 3-9: Manufacturer: wch.cn
[235788.402262] usb_ch9344 3-9:1.0: ttyCH9344USB from 8 - 15: ch9344 device attached.
各路大神,有遇到过的吗
您好,如上信息提示和硬件工作状态有关,即USB通讯不稳定导致。出现串口变号的根本原因是:打开串口节点的时候USB硬件发生了物理掉线。
可检查设计原理图和PCB,如外部使用了延长线连接,那么可尝试缩短线材/使用带屏蔽线材等。
