关于CH32V003在arduino环境和MounRive环境开发下,出现时钟抖动大
都是PWM的PWM_MODE1输出方波 ,代码都一样,都是使用内部晶振
上图是arduino环境下,使用内部晶振
_cgi-bin_mmwebwx-bin_webwxgetmsgimg__&MsgID=1918744680997644115&skey=@crypt_ae7b7cb_353b846e0e2c0cac39f8facb325d1e23&mmweb_appid=wx_webfilehelper.jpg下图是在MounRive环境下,也是内部晶振
_cgi-bin_mmwebwx-bin_webwxgetmsgimg__&MsgID=2954966158802487468&skey=@crypt_ae7b7cb_353b846e0e2c0cac39f8facb325d1e23&mmweb_appid=wx_webfilehelper.jpg两者对比,明显在MounRive环境下的代码,没有抖动。。。
arduino 下使用的代码
void TIM1_PWMOut_Init(u16 arr, u16 psc, u16 ccp)
    GPIO_InitTypeDef GPIO_InitStructure={0};
    TIM_OCInitTypeDef TIM_OCInitStructure={0};
    TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStructure={0};
    RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOD | RCC_APB2Periph_TIM1, ENABLE );
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_Init( GPIOD, &GPIO_InitStructure );
    TIM_TimeBaseInitStructure.TIM_Period = arr;
    TIM_TimeBaseInitStructure.TIM_Prescaler = psc;
    TIM_TimeBaseInitStructure.TIM_ClockDivision = TIM_CKD_DIV1;
    TIM_TimeBaseInitStructure.TIM_CounterMode = TIM_CounterMode_Up;
    TIM_TimeBaseInit( TIM1, &TIM_TimeBaseInitStructure);
    TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
    TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
    TIM_OCInitStructure.TIM_Pulse = ccp;
    TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
    TIM_OC1Init( TIM1, &TIM_OCInitStructure );
    TIM_CtrlPWMOutputs(TIM1, ENABLE );
    TIM_OC1PreloadConfig( TIM1, TIM_OCPreload_Disable );
    TIM_ARRPreloadConfig( TIM1, ENABLE );
    TIM_Cmd( TIM1, ENABLE );
void setup() {
  TIM1_PWMOut_Init( 1, 2-1, 1 );
void loop() {
  // put your main code here, to run repeatedly:
MounRive下使用的代码
#include "debug.h"
int main(void)
    SystemCoreClockUpdate();
    Delay_Init();
    while(1);
都使用同样的 system_ch32v00x.c 配置
/********************************** (C) COPYRIGHT *******************************
 * File Name          : system_ch32v00x.c
 * Author             : WCH
 * Version            : V1.0.0
 * Date               : 2023/12/26
 * Description        : CH32V00x Device Peripheral Access Layer System Source File.
* Copyright (c) 2021 Nanjing Qinheng Microelectronics Co., Ltd.
* Attention: This software (modified or not) and binary are used for
* microcontroller manufactured by Nanjing Qinheng Microelectronics.
#include
* Uncomment the line corresponding to the desired System clock (SYSCLK) frequency (after
* reset the HSI is used as SYSCLK source).
* If none of the define below is enabled, the HSI is used as System clock source.
//#define SYSCLK_FREQ_8MHz_HSI    8000000
//#define SYSCLK_FREQ_24MHZ_HSI   HSI_VALUE
#define SYSCLK_FREQ_48MHZ_HSI   48000000
//#define SYSCLK_FREQ_8MHz_HSE    8000000
//#define SYSCLK_FREQ_24MHz_HSE   HSE_VALUE
//#define SYSCLK_FREQ_48MHz_HSE   48000000
/* Clock Definitions */
#ifdef SYSCLK_FREQ_8MHz_HSI
  uint32_t SystemCoreClock         = SYSCLK_FREQ_8MHz_HSI;          /* System Clock Frequency (Core Clock) */
#elif defined SYSCLK_FREQ_24MHZ_HSI
  uint32_t SystemCoreClock         = SYSCLK_FREQ_24MHZ_HSI;        /* System Clock Frequency (Core Clock) */
#elif defined SYSCLK_FREQ_48MHZ_HSI
  uint32_t SystemCoreClock         = SYSCLK_FREQ_48MHZ_HSI;        /* System Clock Frequency (Core Clock) */
#elif defined SYSCLK_FREQ_8MHz_HSE
  uint32_t SystemCoreClock         = SYSCLK_FREQ_8MHz_HSE;         /* System Clock Frequency (Core Clock) */
#elif defined SYSCLK_FREQ_24MHz_HSE
  uint32_t SystemCoreClock         = SYSCLK_FREQ_24MHz_HSE;        /* System Clock Frequency (Core Clock) */
#elif defined SYSCLK_FREQ_48MHz_HSE
  uint32_t SystemCoreClock         = SYSCLK_FREQ_48MHz_HSE;        /* System Clock Frequency (Core Clock) */
#else
  uint32_t SystemCoreClock         = HSI_VALUE;
#endif
__I uint8_t AHBPrescTable[16] = {1, 2, 3, 4, 5, 6, 7, 8, 1, 2, 3, 4, 5, 6, 7, 8};
/* system_private_function_proto_types */
static void SetSysClock(void);
  static void SetSysClockTo_8MHz_HSI(void);
  static void SetSysClockTo_24MHZ_HSI(void);
  static void SetSysClockTo_48MHZ_HSI(void);
  static void SetSysClockTo_8MHz_HSE(void);
  static void SetSysClockTo_24MHz_HSE(void);
  static void SetSysClockTo_48MHz_HSE(void);
#endif
 * @fn      SystemInit
 * @brief   Setup the microcontroller system Initialize the Embedded Flash Interface,
 *        the PLL and update the SystemCoreClock variable.
 * @return  none
void SystemInit (void)
  RCC->CTLR |= (uint32_t)0x00000001;
  RCC->CFGR0 &= (uint32_t)0xFCFF0000;
  RCC->CTLR &= (uint32_t)0xFEF6FFFF;
  RCC->CTLR &= (uint32_t)0xFFFBFFFF;
  RCC->CFGR0 &= (uint32_t)0xFFFEFFFF;
  RCC->INTR = 0x009F0000;
  RCC_AdjustHSICalibrationValue(0x10);
  SetSysClock();
 * @fn      SystemCoreClockUpdate
 * @brief   Update SystemCoreClock variable according to Clock Register Values.
 * @return  none
void SystemCoreClockUpdate (void)
    uint32_t tmp = 0, pllsource = 0;
    tmp = RCC->CFGR0 & RCC_SWS;
    switch (tmp)
        case 0x00:
            break;
        case 0x04:
            SystemCoreClock = HSE_VALUE;
            break;
        case 0x08:
            pllsource = RCC->CFGR0 & RCC_PLLSRC;
            if (pllsource == 0x00)
                SystemCoreClock = HSI_VALUE * 2;
            else
                SystemCoreClock = HSE_VALUE * 2;
            break;
        default:
            break;
    tmp = AHBPrescTable[((RCC->CFGR0 & RCC_HPRE) >> 4)];
    if(((RCC->CFGR0 & RCC_HPRE) >> 4) < 8)
        SystemCoreClock /= tmp;
    else
        SystemCoreClock >>= tmp;
 * @fn      SetSysClock
 * @brief   Configures the System clock frequency, HCLK, PCLK2 and PCLK1 prescalers.
 * @return  none
RCC->APB2PCENR |= RCC_APB2Periph_GPIOD;
GPIOD->CFGLR&=(~0xF0);
GPIOD->CFGLR|=0x80;
GPIOD->BSHR =0x2;
//GPIO_IPD_Unused();
    SetSysClockTo_8MHz_HSI();
    SetSysClockTo_24MHZ_HSI();
    SetSysClockTo_48MHZ_HSI();
    SetSysClockTo_8MHz_HSE();
    SetSysClockTo_24MHz_HSE();
    SetSysClockTo_48MHz_HSE();
#endif
 /* If none of the define above is enabled, the HSI is used as System clock.
  * source (default after reset)
 * @fn      SetSysClockTo_8MHz_HSI
 * @brief   Sets HSE as System clock source and configure HCLK, PCLK2 and PCLK1 prescalers.
 * @return  none
    /* Flash 0 wait state */
    FLASH->ACTLR &= (uint32_t)((uint32_t)~FLASH_ACTLR_LATENCY);
    FLASH->ACTLR |= (uint32_t)FLASH_ACTLR_LATENCY_0;
    /* HCLK = SYSCLK = APB1 */
    RCC->CFGR0 |= (uint32_t)RCC_HPRE_DIV3;
 * @fn      SetSysClockTo_24MHZ_HSI
 * @brief   Sets System clock frequency to 24MHz and configure HCLK, PCLK2 and PCLK1 prescalers.
 * @return  none
    RCC->CFGR0 |= (uint32_t)RCC_HPRE_DIV1;
 * @fn      SetSysClockTo_48MHZ_HSI
 * @brief   Sets System clock frequency to 48MHz and configure HCLK, PCLK2 and PCLK1 prescalers.
 * @return  none
    uint8_t tmp = 0;
    tmp = *( uint8_t * )CFG0_PLL_TRIM;
    if(tmp != 0xFF)
        RCC_AdjustHSICalibrationValue((tmp & 0x1F));
    FLASH->ACTLR |= (uint32_t)FLASH_ACTLR_LATENCY_1;
    /* PLL configuration: PLLCLK = HSI * 2 = 48 MHz */
    RCC->CFGR0 &= (uint32_t)((uint32_t)~(RCC_PLLSRC));
    RCC->CFGR0 |= (uint32_t)(RCC_PLLSRC_HSI_Mul2);
    /* Enable PLL */
    RCC->CTLR |= RCC_PLLON;
    /* Wait till PLL is ready */
    while((RCC->CTLR & RCC_PLLRDY) == 0)
    /* Select PLL as system clock source */
    RCC->CFGR0 &= (uint32_t)((uint32_t)~(RCC_SW));
    RCC->CFGR0 |= (uint32_t)RCC_SW_PLL;
    /* Wait till PLL is used as system clock source */
    while ((RCC->CFGR0 & (uint32_t)RCC_SWS) != (uint32_t)0x08)
 * @fn      SetSysClockTo_8MHz_HSE
 * @brief   Sets System clock frequency to 56MHz and configure HCLK, PCLK2 and PCLK1 prescalers.
 * @return  none
    __IO uint32_t StartUpCounter = 0, HSEStatus = 0;
    /* Close PA0-PA1 GPIO function */
    RCC->APB2PCENR |= RCC_AFIOEN;
    AFIO->PCFR1 |= (1<<15);
    RCC->CTLR |= ((uint32_t)RCC_HSEON);
    /* Wait till HSE is ready and if Time out is reached exit */
    do
        HSEStatus = RCC->CTLR & RCC_HSERDY;
        StartUpCounter++;
    } while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT));
    if ((RCC->CTLR & RCC_HSERDY) != RESET)
        HSEStatus = (uint32_t)0x01;
    else
        HSEStatus = (uint32_t)0x00;
    if (HSEStatus == (uint32_t)0x01)
        /* Select HSE as system clock source */
        RCC->CFGR0 |= (uint32_t)RCC_SW_HSE;
        /* Wait till HSE is used as system clock source */
        while ((RCC->CFGR0 & (uint32_t)RCC_SWS) != (uint32_t)0x04)
    else
         * If HSE fails to start-up, the application will have wrong clock
     * configuration. User can add here some code to deal with this error
 * @fn      SetSysClockTo_24MHz_HSE
 * @brief   Sets System clock frequency to 72MHz and configure HCLK, PCLK2 and PCLK1 prescalers.
 * @return  none
    do
        StartUpCounter++;
    else
    else
 * @fn      SetSysClockTo_48MHz_HSE
 * @return  none
    do
        StartUpCounter++;
    else
        /* PLL configuration: PLLCLK = HSE * 2 = 48 MHz */
        RCC->CFGR0 |= (uint32_t)(RCC_PLLSRC_HSE_Mul2);
        /* Enable PLL */
    else
#endif
您好,根据你的信息,目前没看出程序上的差别,你应该没有使用arduino的库,你可以使用arduino的库或者使用外部晶振试一下是否会有该问题。此外,你可以多次测量一下,看arduino的是否每次都有抖动以及MRS的是否会有抖动情况出现。或你可以降低频率试一下。若你对项目进行开发,建议还是使用MounRiver进行开发,这样即使遇到问题也方便我们提供技术支持。后续若有问题,可邮箱(lzs@wch.cn)沟通。
