CH32V203C8T6的定时器1可以输出多路不同频率的PWM吗,我看到CSDN上有人用V307开发板好像实现了这个功能 。
void PWM_Init()
    GPIO_InitTypeDef GPIO_InitStructure={0};
    TIM_OCInitTypeDef TIM_OCInitStructure={0};
    TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStructure={0};
    RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOE | RCC_APB2Periph_TIM1 | RCC_APB2Periph_AFIO, ENABLE );
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_Init( GPIOE, &GPIO_InitStructure );
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_14;
    GPIO_Init( GPIOE, &GPIO_InitStructure );    //配置使用的IO
    GPIO_PinRemapConfig(GPIO_FullRemap_TIM1, ENABLE);    //重映射IO
    TIM_TimeBaseInitStructure.TIM_Period = 10000;
    TIM_TimeBaseInitStructure.TIM_Prescaler = 0;
    TIM_TimeBaseInitStructure.TIM_ClockDivision = TIM_CKD_DIV1;
    TIM_TimeBaseInitStructure.TIM_CounterMode = TIM_CounterMode_CenterAligned1;
    TIM_TimeBaseInit( TIM1, &TIM_TimeBaseInitStructure);    //配置核心计数器工作模式
    TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
    TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
    TIM_OCInitStructure.TIM_Pulse = 5000;
    TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
    TIM_OC1Init( TIM1, &TIM_OCInitStructure );
    TIM_OC2Init( TIM1, &TIM_OCInitStructure );
    TIM_OC3Init( TIM1, &TIM_OCInitStructure );
    TIM_OC4Init( TIM1, &TIM_OCInitStructure );       //配置比较输出通道
    TIM_CtrlPWMOutputs(TIM1, ENABLE );          //高级定时器置位MOE
    TIM_OC1PreloadConfig( TIM1, TIM_OCPreload_Disable );
    TIM_OC2PreloadConfig( TIM1, TIM_OCPreload_Disable );
    TIM_OC3PreloadConfig( TIM1, TIM_OCPreload_Disable );
    TIM_OC4PreloadConfig( TIM1, TIM_OCPreload_Disable );    //禁止ccr预装载
    TIM_ARRPreloadConfig( TIM1, ENABLE );           //开启核心计数器自动重装载
    TIM_Cmd( TIM1, ENABLE );       //开启核心计数器
int main(void)
    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
    SystemCoreClockUpdate();
    Delay_Init();
    USART_Printf_Init(115200);
    printf("SystemClk:%d\r\n",SystemCoreClock);
    printf( "ChipID:%08x\r\n", DBGMCU_GetCHIPID() );
    printf("This is printf example\r\n");
    PWM_Init();
    TIM1->CH1CVR = 2000;
    TIM1->CH2CVR = 4000;
    TIM1->CH3CVR = 6000;
    TIM1->CH4CVR = 8000;
    while(1)
这是复制那个大佬的代码
我之前只做过4个通道设置不同占空比,分频频率没有试过.
您好,可以利用定时器翻转模式实现输出不同频率的PWM波形,附件为参考例程,可以参考一下
icon_rar.gifCH32V307 TIM翻转模式多通道.zip
