rv1126开发板添加ch343驱动出现错误
icon_rar.gifch343ser_linux-main.zip
用的是这个代码。
编译正常。能正常识别到ttyCH343USB0.
[  163.815243] usb 2-1: new full-speed USB device number 2 using ohci-platform
[  164.042656] usb 2-1: New USB device found, idVendor=1a86, idProduct=55d3, bcdDevice= 4.45
[  164.042685] usb 2-1: New USB device strings: Mfr=0, Product=2, SerialNumber=3
[  164.042695] usb 2-1: Product: USB Single Serial
[  164.042703] usb 2-1: SerialNumber: 5719028097
[  164.044893] usb_ch343 2-1:1.0: ttyCH343USB0: usb to uart device
[  164.046660] usb_ch343 2-1:1.0: chip idproduct is 21971,chiptype is 8
[  164.048648] usb_ch343 2-1:1.0: chip type is 2
[  164.048830] usb_ch343 2-1:1.0: normal to probe
[root@RV1126_RV1109:/]# stty -F /dev/ttyCH343USB0
[  181.176634] usb_ch343 2-1:1.0: chip type is 2
[  181.176665] usb_ch343 2-1:1.0: ch343_update_status - unknown status received:len:10, data0:0xa1, data1:0x20
speed 9600 baud; line = 0;
-brkint -imaxbel
[root@RV1126_RV1109:/]# printf "01" >/dev/ttyCH343USB0
发数据的时候会出现多出2个数据。
这是什么原因导致的。而且每次第一次插上,只要直接通信,都会报ch343_update_status - unknown status received:len:10, data0:0xa1, data1:0x20这个。后续不会报。但是发数据就很奇怪
您好,看您发的是V1.6的老版本驱动,麻烦下载安装最新的CH343 Linux驱动,驱动链接:https://github.com/WCHSoftGroup/ch343ser_linux。
下载了最新的驱动后,解决了发送数据出错的问题。在设备插上后,第一次对ttyCH343USB0进行操作(配置或者使用默认配置进行数据发送)的时候会报错。但是后续操作并没有受影响
