CH554如果操作FT232USB转串口芯片,类似操作CH340一样?
CH554使用ch554_uart_2_uart.rar进行usb串口透传,怎么操作FT232的USB转串口芯片,案例中只有CH34X,PL2303,CP210x。怎么添加FT232的支持?谢谢 了
如果在原例程上修改添加更好不过了。
您好
开发特定USB设备的主机时,可以使用一些上位机软件抓取USB设备和上位机的通信,然后使用MCU模拟这个PC的通信过程。
在枚举获取描述符部分,FT232和其他设备一样,在设置波特率等方面可能不同。这边提供一段FT232波特率等配置的代码,按照这样的顺序发送SETUP包,就是配置FT232的过程,希望能有所帮助。
unsigned char Baud_buf1_5[8]={0x40,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
unsigned char Baud_buf6[8]={0x02,0x01,0x00,0x00,0x81,0x00,0x00,0x00};
unsigned char Baud_buf7[8]={0x40,0x09,0x10,0x00,0x00,0x00,0x00,0x00};
unsigned char Baud_buf8[8]={0xc0,0x05,0x00,0x00,0x00,0x00,0x02,0x00};  //无
unsigned char Baud_buf9[8]={0x40,0x04,0x07,0x00,0x00,0x00,0x00,0x00};  //无
unsigned char Baud_buf10[8]={0x40,0x01,0x01,0x01,0x00,0x00,0x00,0x00};
unsigned char Baud_buf11[8]={0x40,0x01,0x02,0x02,0x00,0x00,0x00,0x00};
unsigned char Baud_buf12[8]={0x40,0x02,0x00,0x00,0x00,0x00,0x00,0x00}; //无
//unsigned char Baud_buf13[8]={0x40,0x03,0xc4,0x09,0x00,0x00,0x00,0x00};
unsigned char Baud_buf14[8]={0x40,0x03,0xc4,0x09,0x00,0x00,0x00,0x00}; //特特率
unsigned char Baud_buf15[8]={0x40,0x01,0x02,0x02,0x00,0x00,0x00,0x00}; //无
unsigned char Baud_buf16[8]={0x40,0x01,0x01,0x01,0x00,0x00,0x00,0x00}; //无
unsigned char Baud_buf17[8]={0x40,0x04,0x07,0x02,0x00,0x00,0x00,0x00}; //设置数据位、停止位、校验位等
unsigned char Baud_buf18[8]={0x40,0x02,0x00,0x00,0x00,0x00,0x00,0x00}; //流控设置
unsigned char Baud_buf19[8]={0x40,0x06,0x00,0x00,0x00,0x00,0x00,0x00};
//配置FT232R波特率
void FT232R_Baud_Config( UINT32 baud )
	unsigned char s=0,ix;
	unsigned short int len;
	FT232R_Baud_Set(Baud_buf1_5);
	FT232R_Baud_Set(Baud_buf6);
	FT232R_Baud_Set(Baud_buf7);
	FT232R_Baud_Set(Baud_buf8);
	FT232R_Baud_Set(Baud_buf10);
	FT232R_Baud_Set(Baud_buf11);
	FT232R_Baud_Set(Baud_buf12);
	baud = 10*3000000/baud;    //分频
	baud = (baud+5)/10;        //做四舍五入
	Baud_buf14[2]=baud&0xff;
	Baud_buf14[3]=(baud>>8)&0xff;
	Baud_buf14[4]=(baud>>16)&0xff;
	FT232R_Baud_Set(Baud_buf14);//这一次的波特率
	FT232R_Baud_Set(Baud_buf17);
	FT232R_Baud_Set(Baud_buf18);
	FT232R_Baud_Set(Baud_buf19);
你好,根据你提供的数组,我添加到CH554_uart2uart的工程,当前实现了FT232插入时检测设备,并且能接收一段我开发板发送的字符,但是当开发板已经发送结束了,CH554还是一直接收到FT232发送的东西,并且串口打印是乱码的。
下面是工程中我添加的FT232设置波特率部分函数
UINT8 FT232_Baud_Config(UINT32 baud)
	UINT8 s;
	UINT16 tmp;
	TxBuffer[0] = 0x40;
	TxBuffer[1] = 0x00;
	TxBuffer[2] = 0x00;
	TxBuffer[3] = 0x00;
	TxBuffer[4] = 0x00;
	TxBuffer[5] = 0x00;
	TxBuffer[6] = 0x00;
	TxBuffer[7] = 0x00;
	s = HostCtrlTransfer( NULL, NULL );
	TxBuffer[0] = 0x40;
	TxBuffer[1] = 0x00;
	TxBuffer[2] = 0x00;
	TxBuffer[3] = 0x00;
	TxBuffer[4] = 0x00;
	TxBuffer[5] = 0x00;
	TxBuffer[6] = 0x00;
	TxBuffer[7] = 0x00;
	TxBuffer[0] = 0x02;
	TxBuffer[1] = 0x01;
	TxBuffer[2] = 0x00;
	TxBuffer[3] = 0x00;
	TxBuffer[4] = 0x81;
	TxBuffer[5] = 0x00;
	TxBuffer[6] = 0x00;
	TxBuffer[7] = 0x00;
	TxBuffer[0] = 0x40;
	TxBuffer[1] = 0x09;
	TxBuffer[2] = 0x10;
	TxBuffer[3] = 0x00;
	TxBuffer[4] = 0x00;
	TxBuffer[5] = 0x00;
	TxBuffer[6] = 0x00;
	TxBuffer[7] = 0x00;
	TxBuffer[0] = 0xc0;
	TxBuffer[1] = 0x05;
	TxBuffer[2] = 0x00;
	TxBuffer[3] = 0x00;
	TxBuffer[4] = 0x00;
	TxBuffer[5] = 0x00;
	TxBuffer[6] = 0x02;
	TxBuffer[7] = 0x00;
	TxBuffer[0] = 0x40;
	TxBuffer[1] = 0x01;
	TxBuffer[2] = 0x01;
	TxBuffer[3] = 0x01;
	TxBuffer[4] = 0x00;
	TxBuffer[5] = 0x00;
	TxBuffer[6] = 0x00;
	TxBuffer[7] = 0x00;
	TxBuffer[0] = 0x40;
	TxBuffer[1] = 0x01;
	TxBuffer[2] = 0x02;
	TxBuffer[3] = 0x02;
	TxBuffer[4] = 0x00;
	TxBuffer[5] = 0x00;
	TxBuffer[6] = 0x00;
	TxBuffer[7] = 0x00;
	TxBuffer[0] = 0x40;
	TxBuffer[1] = 0x02;
	TxBuffer[2] = 0x00;
	TxBuffer[3] = 0x00;
	TxBuffer[4] = 0x00;
	TxBuffer[5] = 0x00;
	TxBuffer[6] = 0x00;
	TxBuffer[7] = 0x00;
	tmp=(10*3000000/baud);
	tmp = (tmp+5)/10;
	TxBuffer[0] = 0x40;
	TxBuffer[1] = 0x03;
	TxBuffer[2] = (UINT8)(tmp&0Xff);
	TxBuffer[3] = (UINT8)((tmp>>8)&0xff);
	TxBuffer[4] = (UINT8)((tmp>>16)&0xff);
	TxBuffer[5] = 0x00;
	TxBuffer[6] = 0x00;
	TxBuffer[7] = 0x00;
	TxBuffer[0] = 0x40;
	TxBuffer[1] = 0x04;
	TxBuffer[2] = 0x07;
	TxBuffer[3] = 0x02;
	TxBuffer[4] = 0x00;
	TxBuffer[5] = 0x00;
	TxBuffer[6] = 0x00;
	TxBuffer[7] = 0x00;
	TxBuffer[0] = 0x40;
	TxBuffer[1] = 0x02;
	TxBuffer[2] = 0x00;
	TxBuffer[3] = 0x00;
	TxBuffer[4] = 0x00;
	TxBuffer[5] = 0x00;
	TxBuffer[6] = 0x00;
	TxBuffer[7] = 0x00;
	TxBuffer[0] = 0x40;
	TxBuffer[1] = 0x06;
	TxBuffer[2] = 0x00;
	TxBuffer[3] = 0x00;
	TxBuffer[4] = 0x00;
	TxBuffer[5] = 0x00;
	TxBuffer[6] = 0x00;
	TxBuffer[7] = 0x00;
	return s;
下面是用SSCOM串口工具打印的乱码信息:
求助,当前该如何修改程序?问题是出在哪里呢?
您好
使用一些上位机抓包软件可以看到,FT232在上传数据时,会默认一直上传两个字节,0x01 0x60(`),这两个字节的数据您可以省略掉,只保留后面的数据即可。
您好,我尝试着过滤数据包中的0x01和0x60,但是这样做会导致我数据包丢包,是否有可能对FT232进行设置,不要一直发送0x01和0x60这两个字符?
楼主解决了吗 工程是否可以发给我参考一下
楼主工程是否可以分享一下,邮箱个人信息保护,已隐藏
你好,请问问题解决了吗?
按照下面的操作:
会出现在接受FT232的数据时,单字节最高bit位总是为0,例如我发0x81,单片机uart口收到的就是0x01, 发0xAA,收到的就是0x2A,请问有遇到过这种情况吗?
