使用CH579的TMR例程,将PB15设置为下拉输入后,即使外部引脚悬空也读出1,PB14 13 12 也是如此。而其他引脚却一切正常。#include?"CH57x_common.h"
__align(4)?UINT32?CapBuf[100]; __align(4)?UINT32?PwmBuf[100]; volatile?UINT8?capFlag?=?0; void?DebugInit(void) { ????GPIOA_SetBits(GPIO_Pin_9); ????GPIOA_ModeCfg(GPIO_Pin_8,?GPIO_ModeIN_PU); ????GPIOA_ModeCfg(GPIO_Pin_9,?GPIO_ModeOut_PP_5mA); ????UART1_DefInit(); } int?main() {????? ????UINT8??i; UINT32?x?=?0; ?? /*?配置串口调试?*/??? ????DebugInit(); ????PRINT(?"Start?@ChipID=%02X\n",?R8_CHIP_ID?); ???? ????//设置GPIO为下拉,输出结果 ????GPIOB_ModeCfg(?GPIO_Pin_15,?GPIO_ModeIN_PD?); ????PRINT("read?res?=?%d\r\n",?GPIOB_ReadPortPin(?GPIO_Pin_15?)); ???? #if?0???????/*?定时器0,设定100ms定时器进行IO口闪灯,?PB3-LED?*/ ???? ????GPIOB_SetBits(?GPIO_Pin_3?); ????GPIOB_ModeCfg(?GPIO_Pin_3,?GPIO_ModeOut_PP_5mA?); ???? ????TMR0_TimerInit(?FREQ_SYS/10?);??????????????????//?设置定时时间?100ms ????TMR0_ITCfg(ENABLE,?TMR0_3_IT_CYC_END);??????????//?开启中断 ????NVIC_EnableIRQ(?TMR0_IRQn?); #endif? #if?1???????/*?定时器3,PWM输出?*/ ???? ????GPIOA_ResetBits(?GPIO_Pin_2?);????????????//?配置PWM口?PA2 ????GPIOA_ModeCfg(?GPIO_Pin_2,?GPIO_ModeOut_PP_5mA?); ???? ????TMR3_PWMInit(?High_Level,?PWM_Times_1?); ????TMR3_PWMCycleCfg(?3200?);????????//?周期?100us ????TMR3_Disable(); ????TMR3_PWMActDataWidth(?1000?);??????????????//?占空比设置?,?修改占空比必须暂时关闭定时器 ????TMR3_Enable(); ???? #endif??? #if?1???????/*?定时器1,CAP捕捉,?*/ ????PWR_UnitModCfg(?DISABLE,?UNIT_SYS_LSE?);?????//?注意此引脚是LSE晶振引脚,要保证关闭才能使用其他功能 ????GPIOA_ResetBits(?GPIO_Pin_10?);?????????????//?配置PWM口?PA10 ????GPIOA_ModeCfg(?GPIO_Pin_10,?GPIO_ModeIN_PU?); ????TMR1_CapInit(?Edge_To_Edge?); ????TMR1_CAPTimeoutCfg(?0xFFFFFFFF?);???//?设置捕捉超时时间 ????TMR1_DMACfg(?ENABLE,?(UINT16)(UINT32)&CapBuf[0],?(UINT16)(UINT32)&CapBuf[100],?Mode_Single?); ????TMR1_ClearITFlag(?TMR1_2_IT_DMA_END?);??????//?清除中断标志?? ????TMR1_ITCfg(ENABLE,?TMR1_2_IT_DMA_END);??????????//?开启DMA完成中断 ????NVIC_EnableIRQ(?TMR1_IRQn?); ???? ????while(?capFlag?==?0?); ????capFlag?=?0; ????for(?i=0;?i<100;?i++?) ????{ ????????printf("%08ld?",?CapBuf[i]&0x1ffffff);??????//?bit26?最高位表示?高电平还是低电平 ????}printf("\n"); #endif #if?1???????/*?定时器2,计数器?*/ GPIOB_ModeCfg(?GPIO_Pin_11,?GPIO_ModeIN_PD?); GPIOPinRemap(?ENABLE,?RB_PIN_TMR2?); TMR2_CountInit(?FallEdge_To_FallEdge?); TMR2_CountOverflowCfg(?1000?);??????????????????//?设置计数上限1000 /*?开启计数溢出中断,计慢1000个周期进入中断?*/??? TMR2_ClearITFlag(?TMR0_3_IT_CYC_END?); NVIC_EnableIRQ(TMR2_IRQn); TMR2_ITCfg(?ENABLE,?TMR0_3_IT_CYC_END); do { /*?约0.5s打印一次当前计数值,如果送入脉冲频率较高,可能很快计数溢出,需要按实际情况修改?*/ x++; if(?!(?x?&?0xfffff?)?) printf("=%ld?",?TMR2_GetCurrentCount()); }while(1);? #endif #if?1?/*?定时器2,DMA?PWM.*/ ????GPIOB_ModeCfg(GPIO_Pin_11,?GPIO_ModeOut_PP_5mA); ????GPIOPinRemap(ENABLE,?RB_PIN_TMR2); ????PRINT("TMR2?DMA?PWM\n"); ????TMR2_PWMCycleCfg(120000);?//?周期?2000us ????for(i=0;?i<50;?i++) ????{ ??????PwmBuf[i]=2400*i; ????} ????for(i=50;?i<100;?i++) ????{ ??????PwmBuf[i]=2400*(100-i); ????} ????TMR2_PWMInit(Low_Level,?PWM_Times_16); ????/*?Note:?DMA须在PWM初始化后进行配置?*/ ????TMR2_DMACfg(ENABLE,?(uint16_t)(uint32_t)&PwmBuf[0],?(uint16_t)(uint32_t)&PwmBuf[100],?Mode_LOOP); ????/*?开启计数溢出中断,计慢1000个周期进入中断?*/ ????TMR2_ClearITFlag(TMR1_2_IT_DMA_END); ????NVIC_EnableIRQ(TMR2_IRQn); ????TMR2_ITCfg(ENABLE,?TMR1_2_IT_DMA_END); #endif ????while(1);???? } void?TMR0_IRQHandler(?void?)????????//?TMR0?定时中断 { ????if(?TMR0_GetITFlag(?TMR0_3_IT_CYC_END?)?) ????{ ????????TMR0_ClearITFlag(?TMR0_3_IT_CYC_END?);??????//?清除中断标志 ????????GPIOB_InverseBits(?GPIO_Pin_3?);???????? ????} } void?TMR1_IRQHandler(?void?)????????//?TMR1?定时中断 { ????if(?TMR1_GetITFlag(?TMR1_2_IT_DMA_END?)?) ????{ ????????TMR1_ITCfg(DISABLE,?TMR1_2_IT_DMA_END);???????//?使用单次DMA功能+中断,注意完成后关闭此中断使能,否则会一直上报中断。 ????????TMR1_ClearITFlag(?TMR1_2_IT_DMA_END?);??????//?清除中断标志?? ????????capFlag?=?1; ????????printf("*"); ????} } void?TMR2_IRQHandler(void) { if(?TMR2_GetITFlag(TMR0_3_IT_CYC_END)?)? { ?TMR2_ClearITFlag(?TMR0_3_IT_CYC_END?); ?/*?计数器计满,硬件自动清零,重新开始计数?*/ ?/*?用户可自行添加需要的处理?*/ } if(TMR2_GetITFlag(TMR1_2_IT_DMA_END)) { TMR2_ClearITFlag(TMR1_2_IT_DMA_END); PRINT("DMA?end\n"); /*?DMA?结束?*/ /*?用户可自行添加需要的处理?*/ } }
CH182: 以太网PHY收发器芯片
