请问在CH582芯片上将蓝牙触摸屏例程移植到复合HID设备中无法使用
   请问在CH582芯片上将蓝牙触摸屏例程移植到复合HID设备中,在电脑上可以用,安卓设备上无法使用是什么原因。描述符如下:
/* 多媒体 */
    0x05, 0x0C, 0x09, 0x01, 0xA1, 0x01,
    0x85, HID_RPT_ID_CONSUMER_IN, 0x05, 0x0C, 0x19, 0x00, 0x2A, 0xFF, 0x03,
    0x95, 0x01, 0x75, 0x10, 0x15, 0x00, 0x26, 0xFF, 0x03, 0x81, 0x00,
    0x05, 0x07, 0x19, 0x00, 0x29, 0xFF, 0x75, 0x08, 0x26, 0xFF, 0x00, 0x81, 0x00, 0x81, 0x01,
    0x06, 0x00, 0xFF, 0x0A, 0x03, 0xFE, 0x0A, 0x04, 0xFE, 0x75, 0x01, 0x95, 0x02, 0x25, 0x01, 0x81, 0x02,
    0x0A, 0x05, 0xFF, 0x95, 0x01, 0x75, 0x05, 0x25, 0x1F, 0x81, 0x02,
    0x75, 0x01, 0x81, 0x01, 0x1A, 0x01, 0xFD, 0x2A, 0xFF, 0xFD, 0x15, 0x01,
    0x26, 0xFF, 0x00, 0x75, 0x08, 0x81, 0x00, 0x0A, 0x02, 0xFF, 0x26, 0xFF, 0x00, 0x15, 0x00, 0x81, 0x02, 0xC0,
 /* 触摸屏 */
    0x05, 0x0D, // Usage Page (Digitizer)
    0x09, 0x04, // Usage (Touch Screen)
    0xA1, 0x01, // Collection (Application)
    0x85, HID_RPT_ID_MOUSE_IN, /* REPORT_ID (01) */
    0x09, 0x22, //   Usage (Finger)
    0xA1, 0x02, //   Collection (Logical)
    0x09, 0x42, /* USAGE (TIP SWITCH) */
    0x15, 0x00, //     Logical Minimum......... (0)
    0x25, 0x01, //     Logical Maximum......... (1)
    0x75, 0x01, //     Report Size............. (1)
    0x95, 0x01, //     Report Count............ (1)
    0x81, 0x02, //     Input...................(Data, Variable, Absolute)
    0x75, 0x07, //     Report Size............. (7)
    0x81, 0x01, //     Input...................(Constant)
    0x09, 0x51, /* USAGE (Contact Identifier) */
    0x75, 0x08, //     Report Size............. (8)
    0x05, 0x01, //     Usage Page (Generic Desktop)
    0x09, 0x30, //     Usage (X)
    /*48 49 50*/
    0x26, (uint8_t)DEF_DESKTOP_X_MAX, (uint8_t)(DEF_DESKTOP_X_MAX >> 8), /* LOGIC_MAX (0X0800) */
    0x75, 0x10,                                                          //     Report Size............. (16)
    0x09, 0x31,                                                          //     Usage (Y)
    /*61 62 63*/
    0x26, (uint8_t)DEF_DESKTOP_Y_MAX, (uint8_t)(DEF_DESKTOP_Y_MAX >> 8), /* LOGIC_MAX (0X0800) */
    0x75, 0x10,                                                          //     Report Size............. (16) 64 65
    0x95, 0x01,                                                          //     Report Count............ (1)  66 67
    0x81, 0x02,                                                          //     Input...................(Data, Variable, Absolute) 68 69
    0xC0,        //   End Collection 70
    0xc0,
    /* 键盘*/
    0x05, 0x01,     // Usage Pg (Generic Desktop)
    0x09, 0x06,     // Usage (Keyboard)
    0xA1, 0x01,     // Collection: (Application)
    0x85, HID_RPT_ID_KEY_IN,     //   ReportID (1)
    0x05, 0x07,     // Usage Pg (Key Codes)
    0x19, 0xE0,     // Usage Min (224)
    0x29, 0xE7,     // Usage Max (231)
    0x15, 0x00,     // Log Min (0)
    0x25, 0x01,     // Log Max (1)
    // Modifier byte
    0x75, 0x01,     // Report Size (1)
    0x95, 0x08,     // Report Count (8)
    0x81, 0x02,     // Input: (Data, Variable, Absolute)
    // Reserved byte
    0x95, 0x01,     // Report Count (1)
    0x75, 0x08,     // Report Size (8)
    0x81, 0x01,     // Input: (Constant)
    // LED report
    0x95, 0x05, // Report Count (5)
    0x05, 0x08, // Usage Pg (LEDs)
    0x19, 0x01, // Usage Min (1)
    0x29, 0x05, // Usage Max (5)
    0x91, 0x02, // Output: (Data, Variable, Absolute)
    // LED report padding
    0x75, 0x03, // Report Size (3)
    0x91, 0x01, // Output: (Constant)
    // Key arrays (6 bytes)
    0x95, 0x06,     // Report Count (6)
    0x25, 0x65,     // Log Max (101)
    0x19, 0x00,     // Usage Min (0)
    0x29, 0x65,     // Usage Max (101)
    0x81, 0x00,     // Input: (Data, Array)
void hidEmuSendTouchReport(uint8_t *data)
    uint8_t buf[6];
    buf[0] = data[1];                  // touch or not
    buf[1] = 1;                     // touch ID
    buf[2] = data[2];        // X axis data low 8bit
    buf[3] = data[3]; // X axis data high 8bit
    buf[4] = data[4];        // Y axis data low 8bit
    buf[5] = data[5]; // Y axis data high 8bit
    HidDev_Report(HID_RPT_ID_MOUSE_IN, HID_REPORT_TYPE_INPUT,
                  6, buf);
使用不同的设备蓝牙连接的报表描述符可能不一样,确认一下在移植之前的程序连接不同设备是可以使用的。
如果不可用,需要进行抓包查看,如某蓝牙触摸屏连接安卓设备是可行,移植后不可行。抓包对比描述符的差异。
