CH32V203 RTC读取出来的数据全部为0
- 使用的例程:CH32F20xEVT\EVT\EXAM\RTC
修改了RTC时钟为内部时钟源:
u8?RTC_Init(void) { ????u8?temp?=?0; ????RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR?|?RCC_APB1Periph_BKP,?ENABLE); ????PWR_BackupAccessCmd(ENABLE); ????/*?Is?it?the?first?configuration?*/ ????BKP_DeInit(); ????RCC_LSEConfig(RCC_LSE_ON); ????while(RCC_GetFlagStatus(RCC_FLAG_LSERDY)?==?RESET?&&?temp?<?250) ????{ ????????temp++; ????????Delay_Ms(20); ????} ????if(temp?>=?250) ????{ ????????return?1; ????} ?????RCC_RTCCLKConfig(?RCC_RTCCLKSource_LSI?);//仅修改了此处 ?????RCC_RTCCLKCmd(?ENABLE?); ?????RTC_WaitForLastTask(); ?????RTC_WaitForSynchro(); ?????// RTC_ITConfig(RTC_IT_ALR,?ENABLE); ?????RTC_ITConfig(?RTC_IT_SEC,?ENABLE?); ?????RTC_WaitForLastTask(); ?????RTC_EnterConfigMode(); RTC_SetPrescaler(?40000?); //?????RTC_SetPrescaler(?32767?); ?????RTC_WaitForLastTask(); ?????RTC_Set(?2023,?4,?25,?16,?58,?55?);???????/*?Setup?Time?*/ ?????RTC_ExitConfigMode(); ?????BKP_WriteBackupRegister(?BKP_DR1,?0XA1A1?); ????RTC_NVIC_Config(); ????RTC_Get(); ????return?0; }
- 使用MounRiver Studio编译的固件烧录后,连串口都无法打印。
这个论坛html页面,能不能做好一点,发个问题,贴个代码发出来就是乱码,编辑了N次。
CH397: 高集成度、低功耗USB网卡芯片
