开启广播需要处理哪些消息?
尝试自己建议一个简单的蓝牙代码模板.
但是现在连广播都没法开启.查了好多遍,也不知道问题出在哪里.我认为前面的代码应该都不会出问题.可能出在消息处理上.麻烦帮看看到底什么原因没有出现广播.代码基于ch582
main.c的主要代码
int?main(void)
#if(defined(DCDC_ENABLE))?&&?(DCDC_ENABLE?==?TRUE)
???PWR_DCDCCfg(ENABLE);
#endif
???SetSysClock(CLK_SOURCE_PLL_60MHz);
#if(defined(HAL_SLEEP))?&&?(HAL_SLEEP?==?TRUE)
????GPIOA_ModeCfg(GPIO_Pin_All,?GPIO_ModeIN_PU);
????GPIOB_ModeCfg(GPIO_Pin_All,?GPIO_ModeIN_PU);
#endif
#ifdef?DEBUG
????GPIOA_SetBits(bTXD1);
????GPIOA_ModeCfg(bTXD1,?GPIO_ModeOut_PP_5mA);
????UART1_DefInit();
#endif
????PRINT("%s\n",?VER_LIB);
????CH58X_BLEInit();
????HAL_Init();
????GAPRole_PeripheralInit();
????Device_Init();
????Main_Circulation();
初始化的代码
void Device_Init()
?? Device_TaskID = TMOS_ProcessEventRegister(Device_ProcessEvent);
?? uint16_t desired_min_interval = DEFAULT_DESIRED_MIN_CONN_INTERVAL;
?? uint16_t desired_max_interval = DEFAULT_DESIRED_MAX_CONN_INTERVAL;
?? // Setup the GAP Peripheral Role Profile
?????? uint8_t initial_advertising_enable = TRUE;
????? // Set the GAP Role Parameters
????? GAPRole_SetParameter(GAPROLE_ADVERT_ENABLED, sizeof(uint8_t), &initial_advertising_enable);
????? GAPRole_SetParameter(GAPROLE_SCAN_RSP_DATA, sizeof(scanRspData), scanRspData);
????? GAPRole_SetParameter(GAPROLE_ADVERT_DATA, sizeof(advertData), advertData);
????? GAPRole_SetParameter(GAPROLE_MIN_CONN_INTERVAL, sizeof(uint16_t), &desired_min_interval);
????? GAPRole_SetParameter(GAPROLE_MAX_CONN_INTERVAL, sizeof(uint16_t), &desired_max_interval);
?? // Set the GAP Characteristics
??? GGS_SetParameter(GGS_DEVICE_NAME_ATT, GAP_DEVICE_NAME_LEN, attDeviceName);
?????? uint16_t advInt = DEFAULT_ADVERTISING_INTERVAL;
????? // Set advertising interval
?????? GAP_SetParamValue(TGAP_DISC_ADV_INT_MIN, advInt);
?????? GAP_SetParamValue(TGAP_DISC_ADV_INT_MAX, advInt);
????? // Enable scan req notify
?????? GAP_SetParamValue(TGAP_ADV_SCAN_REQ_NOTIFY, ENABLE);
??? // Setup the GAP Bond Manager
??????? uint32_t passkey = 0; // passkey "000000"
??????? uint8_t? pairMode = DEFAULT_PAIRING_PARAMETER;
??????? uint8_t? mitm = FALSE;
??????? uint8_t? ioCap = GAPBOND_IO_CAP_NO_INPUT_NO_OUTPUT;
??????? uint8_t ?bonding = REQ_BONDING;
??????? uint8_t ?autoSync = USING_WHITE_LIST;
?????? GAPBondMgr_SetParameter(GAPBOND_PERI_DEFAULT_PASSCODE, sizeof(uint32_t), &passkey);
?????? GAPBondMgr_SetParameter(GAPBOND_PERI_PAIRING_MODE, sizeof(uint8_t), &pairMode);
?????? GAPBondMgr_SetParameter(GAPBOND_PERI_MITM_PROTECTION, sizeof(uint8_t), &mitm);
?????? GAPBondMgr_SetParameter(GAPBOND_PERI_IO_CAPABILITIES, sizeof(uint8_t), &ioCap);
?????? GAPBondMgr_SetParameter(GAPBOND_PERI_BONDING_ENABLED, sizeof(uint8_t), &bonding);
?????? GAPBondMgr_SetParameter(GAPBOND_AUTO_SYNC_WL, sizeof(uint8_t), &autoSync);
??? // Initialize GATT attributes
??? GGS_AddService(GATT_ALL_SERVICES); ? ?? // GAP
??? GATTServApp_AddService(GATT_ALL_SERVICES); // GATT attributes
??? DevInfo_AddService();
??? // Setup a delayed profile startup
??? tmos_set_event(Device_TaskID, START_DEVICE_EVT);
uint16_t Device_ProcessEvent(uint8_t task_id, uint16_t events)
??? if(events & SYS_EVENT_MSG)
???????? uint8_t *pMsg;
???????? if((pMsg = tmos_msg_receive(Device_TaskID)) != NULL)
???????????? //这里是消息处理代码,往下传递的回调的函数代码在这里
??????????? // Release the TMOS message
?????????????? tmos_msg_deallocate(pMsg);
???????? return (events ^ SYS_EVENT_MSG);
??? if(events & START_DEVICE_EVT)
???????? // Start the Device
???????? GAPRole_PeripheralStartDevice(Device_TaskID, &DeviceBondCB, &DevicePeripheralCB);
???????? return (events ^ START_DEVICE_EVT);
?? //下面是其他消息的处理
实际调试,回调函数DevicePeripheralCB里面的代码是被执行的,不过全部复制8个0也没啥意义.
static??void?DeviceGapStateCB(gapRole_States_t?newState,?gapRoleEvent_t?*pEvent)
????if(newState?==?GAPROLE_STARTED)
????????//?Set?the?system?ID?from?the?bd?addr
????????uint8_t?systemId[DEVINFO_SYSTEM_ID_LEN];
????????GAPRole_GetParameter(GAPROLE_BD_ADDR,?systemId);
???????//?shift?three?bytes?up
????????systemId[7]?=?systemId[5];
????????systemId[6]?=?systemId[4];
????????systemId[5]?=?systemId[3];
???????//?set?middle?bytes?to?zero
????????systemId[4]?=?0;
????????systemId[3]?=?0;
????????DevInfo_SetParameter(DEVINFO_SYSTEM_ID,?DEVINFO_SYSTEM_ID_LEN,?systemId);
???????gapProfileState?=?newState;
为啥空格全部变成?了?
帖子编辑过后空格就全部变成?????了
方便的话将完整工程发送到rzz@wch.cn,便于查找问题。可以先简化一下程序参考Broadcaster(广播者)例程,先使设备可以正常广播。
根据发过来的工程进行测试能够搜索到广播且可以连接。测试条件CH582M的DEMO板。确认硬件烧录我们的例程是否可以正常广播同时也可以使用我们的DEMO板烧录你的程序进行测试。
