用CH32V307评估板做一个矩阵键盘的检测。
使用PE13~PE15作为外部中断引脚,同时配置了PD8~PD11引脚为推挽输出,芯片上电后就卡死了。
测试用PA0~PA3作为外部中断引脚,则可以正常运行。请问CH32V307的PE13~PE15脚作为外部中断的话会影响PD8~PD11引脚的工作吗?
附上初始化代码
void key_init() { GPIO_InitTypeDef GPIO_InitStructure = {0}; EXTI_InitTypeDef EXTI_InitStructure = {0}; NVIC_InitTypeDef NVIC_InitStructure = {0}; RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO | RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE, ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOE, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOD, &GPIO_InitStructure); GPIO_ResetBits(GPIOD, GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOA, &GPIO_InitStructure); GPIO_SetBits(GPIOA, GPIO_Pin_0); NVIC_InitStructure.NVIC_IRQChannel = EXTI15_10_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); GPIO_EXTILineConfig(GPIO_PortSourceGPIOE, GPIO_PinSource13); GPIO_EXTILineConfig(GPIO_PortSourceGPIOE, GPIO_PinSource14); GPIO_EXTILineConfig(GPIO_PortSourceGPIOE, GPIO_PinSource15); EXTI_InitStructure.EXTI_Line = EXTI_Line13 | EXTI_Line14 | EXTI_Line15; EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt; EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling; EXTI_InitStructure.EXTI_LineCmd = ENABLE; EXTI_Init(&EXTI_InitStructure); EXTI_ClearITPendingBit(EXTI_Line13); EXTI_ClearITPendingBit(EXTI_Line14); EXTI_ClearITPendingBit(EXTI_Line15); }
CH397: 高集成度、低功耗USB网卡芯片
