ch32V208BLE初始化后AD转换失效
用的是BLE_UART例程,蓝牙初始化那些都没改过,添加了一段AD采集代码,然后只要运行例程里初始化的这个任务,ADC转换一两秒后就不转换了,ADC寄存器的值就一直是0了。BLE有哪些地方跟ADC冲突了吗?
void Peripheral_Init()
    Peripheral_TaskID = TMOS_ProcessEventRegister(Peripheral_ProcessEvent);
//    // Setup the GAP Peripheral Role Profile
//        uint8_t  initial_advertising_enable = TRUE;
//        uint16_t desired_min_interval = 6;
//        uint16_t desired_max_interval = 1000;
//        // Set the GAP Role Parameters
//        GAPRole_SetParameter(GAPROLE_ADVERT_ENABLED, sizeof(uint8_t), &initial_advertising_enable);
//        GAPRole_SetParameter(GAPROLE_SCAN_RSP_DATA, sizeof(scanRspData), scanRspData);
//        GAPRole_SetParameter(GAPROLE_ADVERT_DATA, sizeof(advertData), advertData);
//        GAPRole_SetParameter(GAPROLE_MIN_CONN_INTERVAL, sizeof(uint16_t), &desired_min_interval);
//        GAPRole_SetParameter(GAPROLE_MAX_CONN_INTERVAL, sizeof(uint16_t), &desired_max_interval);
//    // Set the GAP Characteristics
//    GGS_SetParameter(GGS_DEVICE_NAME_ATT, GAP_DEVICE_NAME_LEN, attDeviceName);
//    // Set advertising interval
//        uint16_t advInt = DEFAULT_ADVERTISING_INTERVAL;
//        GAP_SetParamValue(TGAP_DISC_ADV_INT_MIN, advInt);
//        GAP_SetParamValue(TGAP_DISC_ADV_INT_MAX, advInt);
//    // Setup the GAP Bond Manager
//        uint32_t passkey = 0; // passkey "000000"
//        uint8_t  pairMode = GAPBOND_PAIRING_MODE_WAIT_FOR_REQ;
//        uint8_t  mitm = TRUE;
//        uint8_t  bonding = TRUE;
//        uint8_t  ioCap = GAPBOND_IO_CAP_DISPLAY_ONLY;
//        GAPBondMgr_SetParameter(GAPBOND_PERI_DEFAULT_PASSCODE, sizeof(uint32_t), &passkey);
//        GAPBondMgr_SetParameter(GAPBOND_PERI_PAIRING_MODE, sizeof(uint8_t), &pairMode);
//        GAPBondMgr_SetParameter(GAPBOND_PERI_MITM_PROTECTION, sizeof(uint8_t), &mitm);
//        GAPBondMgr_SetParameter(GAPBOND_PERI_IO_CAPABILITIES, sizeof(uint8_t), &ioCap);
//        GAPBondMgr_SetParameter(GAPBOND_PERI_BONDING_ENABLED, sizeof(uint8_t), &bonding);
//    // Initialize GATT attributes
//    GGS_AddService(GATT_ALL_SERVICES);         // GAP
//    GATTServApp_AddService(GATT_ALL_SERVICES); // GATT attributes
//    DevInfo_AddService();                      // Device Information Service
//    ble_uart_add_service(on_bleuartServiceEvt);
//    // Init Connection Item
//    peripheralInitConnItem(&peripheralConnList);
//    // Register receive scan request callback
//    GAPRole_BroadcasterSetCB(&Broadcaster_BroadcasterCBs);
    // Setup a delayed profile startup
    tmos_set_event(Peripheral_TaskID, SBP_START_DEVICE_EVT);
ADC配置
void ADC_Function_Init(void)
    ADC_InitTypeDef  ADC_InitStructure = {0};
    GPIO_InitTypeDef GPIO_InitStructure = {0};
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
    RCC_ADCCLKConfig(RCC_PCLK2_Div8);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4|GPIO_Pin_6 | GPIO_Pin_5|GPIO_Pin_7 | GPIO_Pin_0|GPIO_Pin_1;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    ADC_DeInit(ADC1);
    ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
    ADC_InitStructure.ADC_ScanConvMode = ENABLE;
    ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
    ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
    ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
    ADC_InitStructure.ADC_NbrOfChannel = AD_CHANNEL_NUM;
    ADC_Init(ADC1, &ADC_InitStructure);
    ADC_DMACmd(ADC1, ENABLE);
    ADC_Cmd(ADC1, ENABLE);
    ADC_BufferCmd(ADC1, DISABLE); //disable buffer
    ADC_ResetCalibration(ADC1);
    while(ADC_GetResetCalibrationStatus(ADC1));
    ADC_StartCalibration(ADC1);
    while(ADC_GetCalibrationStatus(ADC1));
    Calibrattion_Val = Get_CalibrationValue(ADC1);
    printf("-CalibrattionValue:%d\n", Calibrattion_Val);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_4, 1, ADC_SampleTime_239Cycles5);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_6, 2, ADC_SampleTime_239Cycles5);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_5, 3, ADC_SampleTime_239Cycles5);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_7, 4, ADC_SampleTime_239Cycles5);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 5, ADC_SampleTime_239Cycles5);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 6, ADC_SampleTime_239Cycles5);
    ADC_SoftwareStartConvCmd(ADC1, ENABLE);
https://www.wch.cn/bbs/thread-104468-1.html
已回复,请参考。?
