ch32v307的tim1设置pwm和rtthread的kprint用的usart输出冲突?
最近在用赤兔板子调试lcd,st7789,里面有这么一段代码:
void LCD_GPIOInit(void)
    GPIO_InitTypeDef GPIO_InitStructure;
    RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOB| RCC_APB2Periph_TIM1, ENABLE );
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_14;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_Init( GPIOB, &GPIO_InitStructure );
    rt_kprintf("LCD manufacturer ID41\n\r  ");
    TIM_OCInitTypeDef TIM_OCInitStructure;
    TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStructure;
    TIM_TimeBaseInitStructure.TIM_Period = 100;
    TIM_TimeBaseInitStructure.TIM_Prescaler = 288-1;
    TIM_TimeBaseInitStructure.TIM_ClockDivision = TIM_CKD_DIV1;
    TIM_TimeBaseInitStructure.TIM_CounterMode = TIM_CounterMode_Up;
    TIM_TimeBaseInit( TIM1, &TIM_TimeBaseInitStructure );
    rt_kprintf("LCD manufacturer ID42\n\r  ");
#if (PWM_MODE == PWM_MODE1)
    TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
#elif (PWM_MODE == PWM_MODE2)
    TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
#endif
    TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
    TIM_OCInitStructure.TIM_Pulse = 50;
    TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;
    TIM_OC2Init( TIM1, &TIM_OCInitStructure );
    rt_kprintf("LCD manufacturer ID43\n\r  ");
    TIM_CtrlPWMOutputs( TIM1, ENABLE );
    TIM_OC2PreloadConfig( TIM1, TIM_OCPreload_Disable );
    TIM_ARRPreloadConfig( TIM1, ENABLE );
    rt_kprintf("LCD manufacturer ID44\n\r  ");
    TIM_Cmd( TIM1, ENABLE );
   // printf("LCD manufacturer ID45\n\r  ");
上面代码是使用gpiob的pin14作为亮度调节输出。当不用rtthread时,使用debug.c里的printf打印,输出数据一切正常;当我用rtthread后,使用rt_kprint打印,就输出乱码,在
之前的所有打印都正常,在其之后的所有打印都输出乱码
- RT -     Thread Operating System
 / | \     4.0.4 build May 24 2023
 2006 - 2021 Copyright by rt-thread team
MCU: CH32V307
SysClk: 144000000Hz
www.wch.cn-guolin
LCD manufacturer ID1
  LCD manufacturer ID2
 L??[[??I3????Y?s3cue??礃??mn?l7?洊?x5?慆6窙??? x5?萵??#膻05胊?n
[11:47:15.654]收←◆欬??!!
这种是我用来定位哪里出问题的标志
您好,建议你按照下图在初始化的时候将对应结构体清零,打印应该就正常了,这边测试过没有问题,你可以试一下
