芯片是CH32V208WBU6
WCH-LinkUtility V1.70
无论点击解锁还是上锁,日志都是一个结果
“Succeed,the Read-protect is Enable,and Write-Protect is Disable!”
下面的日志是我来来回回点好几次的结果,根本看不出是点的解锁还是上锁
18:17:36:645>> Begin to set chip type...
18:17:36:708>> Succeed
18:17:36:915>> Succeed
18:17:37:137>> Begin to set chip type...
18:17:37:207>> Succeed
18:17:37:212>> Succeed,the Read-protect is Enable,and Write-Protect is Disable!
18:17:39:650>> Failed,the chip type is not matched or status of chip is wrong!
18:17:42:580>> Succeed
18:17:42:802>> Begin to set chip type...
18:17:42:867>> Succeed
18:17:42:874>> Succeed,the Read-protect is Enable,and Write-Protect is Disable!
18:17:46:400>> Succeed
18:17:46:621>> Begin to set chip type...
18:17:46:689>> Succeed
18:17:46:691>> Succeed,the Read-protect is Enable,and Write-Protect is Disable!
18:17:48:101>> Begin to set chip type...
18:17:48:164>> Succeed
18:17:48:371>> Succeed
18:17:48:595>> Begin to set chip type...
18:17:48:660>> Succeed
18:17:48:665>> Succeed,the Read-protect is Enable,and Write-Protect is Disable!
18:17:54:010>> Begin to set chip type...
18:17:54:074>> Succeed
18:17:54:282>> Succeed
18:17:54:513>> Begin to set chip type...
18:17:54:579>> Succeed
18:17:54:581>> Succeed,the Read-protect is Enable,and Write-Protect is Disable!
18:17:56:247>> Succeed
18:17:56:468>> Begin to set chip type...
18:17:56:534>> Succeed
18:17:56:540>> Succeed,the Read-protect is Enable,and Write-Protect is Disable!
18:17:58:508>> Begin to set chip type...
18:17:58:571>> Succeed
18:17:58:776>> Succeed
18:17:59:010>> Begin to set chip type...
18:17:59:074>> Succeed
18:17:59:078>> Succeed,the Read-protect is Enable,and Write-Protect is Disable!
18:17:59:668>> Begin to set chip type...
18:17:59:731>> Succeed
18:17:59:940>> Succeed
18:18:00:168>> Begin to set chip type...
18:18:00:234>> Succeed
18:18:00:244>> Succeed,the Read-protect is Enable,and Write-Protect is Disable!
18:18:00:916>> Begin to set chip type...
18:18:00:982>> Succeed
18:18:01:191>> Succeed
18:18:01:420>> Begin to set chip type...
18:18:01:484>> Succeed
18:18:01:490>> Succeed,the Read-protect is Enable,and Write-Protect is Disable!
