22:20:45 **** Incremental Build of configuration obj for project CH583M ****
make -j4 all
Memory region Used Size Region Size %age Used
c:/mounriver/mounriver_studio/toolchain/risc-v embedded gcc/bin/../lib/gcc/riscv-none-embed/8.2.0/../../../../riscv-none-embed/bin/ld.exe: ../StdPeriphDriver\libISP583.a(ISP583.o): can't link soft-float modules with single-float modules
c:/mounriver/mounriver_studio/toolchain/risc-v embedded gcc/bin/../lib/gcc/riscv-none-embed/8.2.0/../../../../riscv-none-embed/bin/ld.exe: failed to merge target specific data of file ../StdPeriphDriver\libISP583.a(ISP583.o)
FLASH: 136852 B 448 KB 29.83%
collect2.exe: error: ld returned 1 exit status
RAM: 2576 B 32 KB 7.86%
make: *** [makefile:57: CH583M.elf] Error 1
22:20:45 Build Failed. 3 errors, 0 warnings. (took 496ms)
