Question about DMA and usbcore on E51 cpus
Quote from the ch554 English datasheed:
Note: the length of the buffer that receives data >= min (maximum data packet length possibly received + 2 bytes, 64 bytes)
I am still not shure if I understand that correctly.
An example:
#define EP0_SIZE 0x08
uint8_t xdata EP0Buffer[EP0_SIZE +2]? _at_ 0x0000;//8 byte buffer for EP0 to save memory
//gap may be used by the linker
uint8_t xdata EP2Buffer[2*BULK_SIZE] _at_ 0x0080;
EP0 shares the buffer beetween IN & OUT. Should i reserve 2 more Bytes for that buffer?
For EP1..3 it can happen that 2 bytes of EPxInBuffer will be destroyed. But that does not seem a problem. EP4 i never used up to now.
Is it save to use #define EP0_SIZE 0x08 to use just a 10 byte Buffer for DMA0 or should i alway declare 0x40 even when I plan just to use 8Bytes for the control transfers?
That was the first question I asked here.
https://www.wch.cn/bbs/thread-67984-1.html
So you can just reserve 10 bytes for ep0 until you get screwed by the USB host send more data that it should.
In theory it is a problem, but in practice, ch55xduino set ep1_addr at 10 (in board.txt) at the first version and nobody complains so far.
thanks dq_user for your response.
Maybe i will use something like that:
uint8_t xdata EP2Buffer[2*BULK_SIZE] _at_ 0x0000;
uint8_t xdata EP3Buffer[2*BULK_SIZE] _at_ 0x0080;
uint8_t xdata EP0Buffer[BULK_SIZE+2] _at_ 0x0100;
when using EP0Size = 0x08 EP0Buffer[10..63] can be savely used for some temp buffers.
by memset(&EP0Buffer[10], 0xAA, BULK_SIZE-10); Test the range  for something different all 60 sec
in some debug build should give an idea if overflows can happen.
