CH583 用WHCISP 【开启两线仿真接口】,进MounRiver 点仿真后,出现以下错误提示,怎么解决 ?
Open On-Chip Debugger 0.11.0+dev-02415-gfad123a16-dirty (2023-07-03-15:11)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
Info : only one transport option; autoselect 'sdi'
Warn : Transport "sdi" was already selected
Ready for Remote Connections
Started by GNU MCU Eclipse
Info : Listening on port 6666 for tcl connections
Info : Listening on port 4444 for telnet connections
Info : WCH-LinkE  mode:RV version 2.9
Warn :  The debug interface has been opened,there is a risk of code leakage ,ensure that the debug interface has been closed before leaving factory !
Info : wlink_init ok
Info : clock speed 6000 kHz
Info : [wch_riscv.cpu.0] datacount=2 progbufsize=8
Info : [wch_riscv.cpu.0] Examined RISC-V core; found 1 harts
Info : [wch_riscv.cpu.0]  XLEN=32, misa=0x40901125
[wch_riscv.cpu.0] Target successfully examined.
Info : starting gdb server for wch_riscv.cpu.0 on 3333
Info : Listening on port 3333 for gdb connections
Info : accepting 'gdb' connection on tcp/3333
Info : flash size = 448kbytes
Warn : Prefer GDB command "target extended-remote :3333" instead of "target remote :3333"
Info : The target is not running when halt was requested, stopping GDB.
Error: Hart is not halted!
您好,可以参考安装目录下MounRiver_Studio\ExTool\WCH-Link使用说明.pdf 第九章排除下问题。
