使用ch32v208然后用freertos数据量API问题
在使用数据流的时候,发现当发送数据量已经超过触发值,接收函数还是没把数据打印出来,得是发送再发一次后才会与发送的打印数据一起打印出来,但是我用win32运行freertos跑同样的代码没有这个问题,不知道是否是printf函数的问题
/********************************** (C) COPYRIGHT *******************************
 * File Name          : main.c
 * Author             : WCH
 * Version            : V1.0.0
 * Date               : 2021/06/06
 * Description        : Main program body.
* Copyright (c) 2021 Nanjing Qinheng Microelectronics Co., Ltd.
* Attention: This software (modified or not) and binary are used for
* microcontroller manufactured by Nanjing Qinheng Microelectronics.
 *@Note
 task1 and task2 alternate printing
#include "debug.h"
#include "FreeRTOS.h"
#include "task.h"
#include "string.h"
#include "queue.h"
#include "timers.h"
#include "stdlib.h"
#include "string.h"
#include "semphr.h"
#include "event_groups.h"
#include "stream_buffer.h"
/* Global define */
#define TASK1_TASK_PRIO     3
#define TASK1_STK_SIZE      512
#define TASK2_TASK_PRIO     1
#define TASK2_STK_SIZE      512
#define TASK3_TASK_PRIO     1
#define TASK3_STK_SIZE      512
/* Global Variable */
TaskHandle_t Task2Handle = NULL;
TaskHandle_t Task3Handle = NULL;
StreamBufferHandle_t StreamBufferHandle = NULL;
/* SemaphoreHandle */
SemaphoreHandle_t printfSemaphoreHandle = NULL;
//#define MYPRINT(format, ...)    vTaskSuspendAll();portENTER_CRITICAL();printf(format, ##__VA_ARGS__);portEXIT_CRITICAL();xTaskResumeAll()
//#define MYPRINT(format, ...)    vTaskSuspendAll();printf(format, ##__VA_ARGS__);xTaskResumeAll()
#define MYPRINT(format, ...)    xSemaphoreTake(printfSemaphoreHandle,portMAX_DELAY);printf(format, ##__VA_ARGS__);xSemaphoreGive(printfSemaphoreHandle)
 * @fn      GPIO_Toggle_INIT
 * @brief   Initializes GPIOA.0/1
 * @return  none
void GPIO_Toggle_INIT(void)
  GPIO_InitTypeDef  GPIO_InitStructure={0};
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
 * @fn      task1_task
 * @brief   task1 program.
 * @param  *pvParameters - Parameters point of task1
 * @return  none
void task1_task(void *pvParameters)
    TickType_t xLastWakeTime = 0;
    xLastWakeTime = xTaskGetTickCount();
    while(1)
        if(GPIO_ReadOutputDataBit(GPIOA, GPIO_Pin_0) == Bit_RESET)
            GPIO_SetBits(GPIOA, GPIO_Pin_0);
        else
            GPIO_ResetBits(GPIOA, GPIO_Pin_0);
        vTaskDelayUntil( &xLastWakeTime, pdMS_TO_TICKS(1000));
void task2_task(void *pvParameters)
    unsigned char StrTable[50] = {0};
    int16_t StrLength = 0;
    int16_t SendLength = 0;
    int16_t Count = 0;
    while(1)
        vTaskDelay(pdMS_TO_TICKS(3000));
        Count++;
        StrLength = sprintf(StrTable,"StreamBuffer Test Count = %d",Count);
        SendLength = xStreamBufferSend(StreamBufferHandle,(void *)StrTable,StrLength,portMAX_DELAY);
        MYPRINT("Send: StrLength = %d  SendLength = %d\r\n",StrLength,SendLength);
void task3_task(void *pvParameters)
    int16_t ReadLength = 0;
    while(1)
        memset(StrTable,0x00,sizeof(StrTable));
        ReadLength = xStreamBufferReceive(StreamBufferHandle,(void *)StrTable,(sizeof(StrTable) - 1),portMAX_DELAY);
        MYPRINT("Read: ReadLength = %d String = %s\r",ReadLength,StrTable);
 * @fn      main
 * @brief   Main program.
 * @return  none
int main(void)
    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
    Delay_Init();
    USART_Printf_Init(115200);
    printf("SystemClk:%d\r\n",SystemCoreClock);
    printf("FreeRTOS Kernel Version:%s\r\n",tskKERNEL_VERSION_NUMBER);
    GPIO_Toggle_INIT();
    /* create two task */
    printf("uint8_t = %d , uint16_t = %d , size_t = %d \r\n",sizeof(uint8_t),sizeof(uint16_t),sizeof(size_t));
    StreamBufferHandle = xStreamBufferCreate(200,100);      //最大缓冲区为1000,大于50字节触发
    if(StreamBufferHandle != NULL)
        printf("Creat Success \r\n");
    printfSemaphoreHandle = xSemaphoreCreateBinary();
    xSemaphoreGive(printfSemaphoreHandle);
    xTaskCreate((TaskFunction_t )task1_task,
                            (const char*    )"task1",
                            (uint16_t       )TASK1_STK_SIZE,
                            (void*          )NULL,
                            (UBaseType_t    )TASK1_TASK_PRIO,
                            (TaskHandle_t*  )NULL);
    xTaskCreate((TaskFunction_t )task2_task,
                            (const char*    )"task2",
                            (uint16_t       )TASK2_STK_SIZE,
                            (void*          )NULL,
                            (UBaseType_t    )TASK2_TASK_PRIO,
                            (TaskHandle_t*  )&Task2Handle);
    xTaskCreate((TaskFunction_t )task3_task,
                            (const char*    )"task3",
                            (uint16_t       )TASK3_STK_SIZE,
                            (void*          )NULL,
                            (UBaseType_t    )TASK3_TASK_PRIO,
    vTaskStartScheduler();
    while(1)
        printf("shouldn't run at here!!\n");
您好,可在每个打印函数打印时加个换行符(\)或在每个打印函数后面加个fflush(stdout)函数试一下
感谢3楼加上fflush(stdout)后确实可以了
