CH32V208G的systick功能 延迟时间不准确
我看官方例程并没有systick的例程,所以我模仿了582F自己写了一个,但是延迟不太对,1000个中断本来对应的是1s,结果只有0.9s
void Interrupt_VTF_Init(void)
    NVIC_EnableIRQ(SysTicK_IRQn);
    SetVTFIRQ((u32)SysTick_Handler,SysTicK_IRQn,0,ENABLE);
uint32_t SysTick_Config(uint64_t ticks)
    if((ticks - 1) > SysTick_LOAD_RELOAD_Msk)
        return (1); /* Reload value impossible */
    SysTick->CMP = ticks - 1; /* set reload register */
    SysTick->CTLR = SysTick_CTLR_INIT |
                    SysTick_CTLR_STRE |
                    SysTick_CTLR_STCLK |
                    SysTick_CTLR_STIE |
                    SysTick_CTLR_STE; /* Enable SysTick IRQ and SysTick Timer */
    return (0);                       /* Function successful */
main()
    WCHBLE_Init();
    HAL_Init();
    RF_RoleInit();
    RF_Init();
    IMU_Init();
    SysTick_Config(130000);
    Interrupt_VTF_Init();
    pretime = systick;
    PRINT("Enter Main Loop\r\n");
    Main_Circulation();
void SysTick_Handler(void)
    systick++;
    if(systick > 1000)
        systick = 0;
        if(ledstate111 == 0)
            ledstate111 = 1;
            GPIO_ResetBits(GPIOC, GPIO_Pin_7);
        else
            GPIO_SetBits(GPIOC, GPIO_Pin_7);
            ledstate111 = 0;
    SysTick->SR = 0; //清除中断标志
#include "debug.h"
volatile uint64_t systick;
uint16_t ledstate111;
__attribute__((interrupt("WCH-Interrupt-fast")))
void SysTick_Handler( void ) {
    SysTick->SR &= ~(1); //clear
    systick++;
        if(systick > 1000)
            systick = 0;
                ledstate111 = 1;
            else
                ledstate111 = 0;
void ch32v_systick_init(void) {
    #define SysTick_LOAD_RELOAD_Msk    (0xFFFFFFFFFFFFFFFF)
    #define SysTick_CTLR_INIT          (1 << 5)
    #define SysTick_CTLR_MODE          (1 << 4)
    #define SysTick_CTLR_STRE          (1 << 3)
    #define SysTick_CTLR_STCLK         (1 << 2)
    #define SysTick_CTLR_STIE          (1 << 1)
    #define SysTick_CTLR_STE           (1 << 0)
    SysTick->CMP = 72000 - 1;           /* set reload register */
    SetVTFIRQ((uint32_t)SysTick_Handler, SysTicK_IRQn, 0, ENABLE);
                    SysTick_CTLR_STRE |
                    SysTick_CTLR_STIE |
    //HCLK DIV 8
    //SysTick->CTLR &= ~(SysTick_CTLR_STCLK);
int main(void)
    GPIO_InitTypeDef  GPIO_InitStructure = {0};
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
    /* LED init */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
    GPIO_Init(GPIOC, &GPIO_InitStructure);
    //NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
    Delay_Init();
    USART_Printf_Init(115200);
    PRINT("SystemClk:%d\r\n",SystemCoreClock);
    PRINT("we are in user app\n");
    ch32v_systick_init();
    while(1) {
这个代码能用, 问题解决了
问题找到了,开启了systick, delay_US就不能再调用,使用会出问题
