我在Central例程中调用LL_AddWhiteListDevice(PeerAddrDefType,PeerAddrDef);设置白名单,然后将DEFAULT_DISCOVERY_WHITE_LIST设置为TRUE。但是依旧可以扫描到其他Peripheral,还请大神指点。以下是相关代码:
void Central_Init( )
memset(&g_data_update_last, 0, sizeof(data_update_s));
memset(&g_data_update_new, 0, sizeof(data_update_s));
memset(&g_ble_protocol, 0, sizeof(ble_protocol_s));
memset(&g_one_line_data, 0, sizeof(g_one_line_data));
/** default 1 */
setIoDefault();
centralTaskId = TMOS_ProcessEventRegister( Central_ProcessEvent );
// Setup GAP
GAP_SetParamValue( TGAP_DISC_SCAN, DEFAULT_SCAN_DURATION );
/// GAP_SetParamValue( TGAP_DISC_SCAN, 200 );
GAP_SetParamValue( TGAP_CONN_EST_INT_MIN, DEFAULT_MIN_CONNECTION_INTERVAL );
GAP_SetParamValue( TGAP_CONN_EST_INT_MAX, DEFAULT_MAX_CONNECTION_INTERVAL );
GAP_SetParamValue( TGAP_CONN_EST_SUPERV_TIMEOUT, DEFAULT_CONNECTION_TIMEOUT );
// Setup the GAP Bond Manager
uint32 passkey = DEFAULT_PASSCODE;
uint8 pairMode = DEFAULT_PAIRING_MODE;
uint8 mitm = DEFAULT_MITM_MODE;
uint8 ioCap = DEFAULT_IO_CAPABILITIES;
uint8 bonding = DEFAULT_BONDING_MODE;
GAPBondMgr_SetParameter( GAPBOND_CENT_DEFAULT_PASSCODE, sizeof( uint32 ), &passkey );
GAPBondMgr_SetParameter( GAPBOND_CENT_PAIRING_MODE, sizeof( uint8 ), &pairMode );
GAPBondMgr_SetParameter( GAPBOND_CENT_MITM_PROTECTION, sizeof( uint8 ), &mitm );
GAPBondMgr_SetParameter( GAPBOND_CENT_IO_CAPABILITIES, sizeof( uint8 ), &ioCap );
GAPBondMgr_SetParameter( GAPBOND_CENT_BONDING_ENABLED, sizeof( uint8 ), &bonding );
// Initialize GATT Client
GATT_InitClient();
// Register to receive incoming ATT Indications/Notifications
GATT_RegisterForInd( centralTaskId );
/** add whitelist */
LL_ClearWhiteList();
// Setup a delayed profile startup
tmos_set_event( centralTaskId, START_DEVICE_EVT );
