CH32V003J4M6的关于注入通道的疑惑
为了适配和优化打印输出, 稍稍修改了一下EVT的例程 "Auto_Injection" , 具体程序如下:
根据个人理解, 规格通道和注入通道应该顺序对通道 A0(PA_2)和A2(PC_4)分别采样, 但是奇怪的是对通道 A2 输入信号时会对通道 A0 造成同步的信号, 而通道 A0 却接收不到信号. 具体如下图:
如果是配置错误请指出, 非常感谢!
#include "debug.h"
void ADC_Function_Init(void)
    ADC_InitTypeDef  ADC_InitStructure = {0};
    GPIO_InitTypeDef GPIO_InitStructure = {0};
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOA, ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
    RCC_ADCCLKConfig(RCC_PCLK2_Div8);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
    GPIO_Init(GPIOC, &GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    ADC_DeInit(ADC1);
    ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
    ADC_InitStructure.ADC_ScanConvMode = DISABLE;
    ADC_InitStructure.ADC_ContinuousConvMode = DISABLE;
    ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
    ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
    ADC_InitStructure.ADC_NbrOfChannel = 1;
    ADC_Init(ADC1, &ADC_InitStructure);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 1, ADC_SampleTime_241Cycles);
    ADC_InjectedChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_241Cycles);
    ADC_Calibration_Vol(ADC1, ADC_CALVOL_50PERCENT);
    ADC_AutoInjectedConvCmd(ADC1, ENABLE);
    ADC_Cmd(ADC1, ENABLE);
    ADC_ResetCalibration(ADC1);
    while(ADC_GetResetCalibrationStatus(ADC1));
    ADC_StartCalibration(ADC1);
    while(ADC_GetCalibrationStatus(ADC1));
u16 Get_ADC_Val(u8 ch)
    u16 val;
    ADC_SoftwareStartConvCmd(ADC1, ENABLE);
    while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC));
    val = ADC_GetConversionValue(ADC1);
    return val;
int main(void)
    u16 adc_val;
    u16 adc_jval;
    SystemCoreClockUpdate();
    Delay_Init();
    USART_Printf_Init(115200);
    printf("SystemClk:%d\r\n", SystemCoreClock);
    printf( "ChipID:%08x\r\n", DBGMCU_GetCHIPID() );
    ADC_Function_Init();
    while(1)
        while( !ADC_GetFlagStatus( ADC1, ADC_FLAG_JEOC ) );
        adc_val = ADC_GetConversionValue(ADC1);
        adc_jval = ADC_GetInjectedConversionValue(ADC1, ADC_InjectedChannel_1);
        Delay_Ms(50);
        printf("%04d, %04d\r\n", adc_val, adc_jval);
        Delay_Ms(2);
你好,检查一下代码中是不是使用的外部晶振的宏,system_ch32v00x.c 中,如果是,请改为内部晶振的宏。PA2是外部晶振输入引脚,使用外部晶振的宏会自动使能IO的功能。后续具体请与我邮箱联系zdg@wch.cnimage.png
额, 之前确实没改过来. 刚才试了一下, 修改后对A0通道输入的信号确实有反应了!
但是对A2的信号输入还是会对A0造成干扰, 具体如下图:
此时A0通道的引脚未接任何信号 (为悬空状态) 所以,?其他的任何引脚变化都会干扰该引脚??
引脚不可以悬空的,因为采样的时候有采样电容,不接固定电平,电容不能充放电。另外,采样电压要低于VDD。
