配网器程序self_provisioner_vendor_with_peripheral 给泰凌微8250 通用node配网超时
[13:58:04.783] CH58x_BLE_LIB_V1.90
[13:58:04.783] MESH_LIB_V1.73
[13:58:04.783] APP_DBG blemesh_on_sync> Bluetooth initialized
[13:58:05.264] APP_DBG prov_complete>
[13:58:05.279] APP_DBG blemesh_on_sync> Mesh network restored from flash
[13:58:05.300] APP_DBG blemesh_on_sync> Mesh initialized
[13:58:05.300] Initialized..
[13:58:05.300] Advertising..
[13:58:05.300]
[14:00:33.120] APP_DBG unprov_recv>
[14:00:33.120] APP_DBG link_open>
[14:00:33.343]
[14:00:36.780] APP_DBG node_added>
[14:00:36.780]
[14:00:39.273] APP_DBG link_close> reason 0
[14:00:39.273]
[14:00:40.215] APP_DBG cfg_cli_rsp_handler>
[14:00:40.215] APP_DBG cfg_cli_rsp_handler> Opcode 0x0000, timeout
[14:00:40.215] APP_DBG App_ProcessEvent> app_nodes[1] ADDR 2
[14:00:40.311]
[14:00:42.845] APP_DBG cfg_cli_rsp_handler>
[14:00:42.845] APP_DBG cfg_cli_rsp_handler> Opcode 0x0000, timeout
[14:00:42.845]
[14:00:44.316] APP_DBG App_ProcessEvent> app_nodes[1] ADDR 2
[14:00:44.316]
[14:00:45.473] APP_DBG cfg_cli_rsp_handler>
[14:00:45.473] APP_DBG cfg_cli_rsp_handler> Opcode 0x0000, timeout
[14:00:45.473]
[14:00:48.103] APP_DBG cfg_cli_rsp_handler>
[14:00:48.103] APP_DBG cfg_cli_rsp_handler> Opcode 0x0000, timeout
[14:00:48.103] APP_DBG App_ProcessEvent> app_nodes[1] ADDR 2
[14:00:48.327]
[14:00:50.733] APP_DBG cfg_cli_rsp_handler>
[14:00:50.733] APP_DBG cfg_cli_rsp_handler> Opcode 0x0000, timeout
[14:00:50.733]
[14:00:51.371] APP_DBG node_work_handler> Ran Out of Retransmit
[14:00:51.371] APP_DBG node_work_handler> Delete node complete
[14:00:51.371]
[14:13:01.001] APP_DBG node_added>
[14:13:01.001]
[14:13:03.607] APP_DBG link_close> reason 0
是不是不同公司的产品不能通用?
您好,中心节点例程是支持标准mesh的,由于标准mesh的吞吐量小,我们代码里默认负载包长为221字节,注意修改以下参数为7;另外注意,中心节点例程里缺少通用模型比如通用开关模型的客户端代码,适配其他MCU的标准模型需要再添加。
好的, 再问一下,那个例程中有通用开关模型的客户端的发送的代码,我需要参考一下,多谢了
