CH554 端点3上传数据问题
CH554 通过端点3上传数据到PC,  上传两字节 0x03,0x00 到PC ,收到确实0X6d,0xdf. 不知为何?
#define THIS_ENDP0_SIZE     DEFAULT_ENDP0_SIZE
#define ENDP1_IN_SIZE 64
#define ENDP2_IN_SIZE 4
#define ENDP3_IN_SIZE 2
#define ENDP3_OUT_SIZE 64
UINT8X  Ep0Buffer[MIN(64,THIS_ENDP0_SIZE+2)]  _at_  0x0000;    //端点0 OUT&IN缓冲区,必须是偶地址
UINT8X  Ep1Buffer[MIN(64,ENDP1_IN_SIZE+2)] _at_  MIN(64,THIS_ENDP0_SIZE+2);  //端点1 IN缓冲区,必须是偶地址
UINT8X  Ep2Buffer[MIN(64,ENDP2_IN_SIZE+2)] _at_ (MIN(64,THIS_ENDP0_SIZE+2)+MIN(64,ENDP1_IN_SIZE+2)); //端点2 IN缓冲区,必须是偶地址
UINT8XEp3Buffer[MIN(64,ENDP3_IN_SIZE+2)+MIN(64,ENDP3_OUT_SIZE+2)] _at_ (MIN(64,THIS_ENDP0_SIZE+2)+MIN(64,ENDP1_IN_SIZE+2)+MIN(64,ENDP2_IN_SIZE+2));   //端点3 OUT+IN缓冲区
// Description  : Touch设备模式配置,设备模式启动,收发端点配置,中断开启
// Input Value  : None
// Output Value : None
void CTouchDeviceInit()
IE_USB = 0;
USB_CTRL = 0x00;                                                // 先设定模式
UDEV_CTRL = bUD_PD_DIS;                                         // 禁止DP/DM下拉电阻
  UDEV_CTRL &= ~bUD_LOW_SPEED;                                     //选择全速12M模式,默认方式
  USB_CTRL &= ~bUC_LOW_SPEED;
  UEP0_DMA = Ep0Buffer;                                           //端点0数据传输地址
  UEP4_1_MOD &= ~(bUEP4_RX_EN | bUEP4_TX_EN);                     //端点0单64字节收发缓冲区
  UEP1_DMA = Ep1Buffer;                                           //端点1数据传输地址
  UEP4_1_MOD = UEP4_1_MOD & ~bUEP1_BUF_MOD | bUEP1_TX_EN;         //端点1发送使能 64字节缓冲区
UEP2_DMA = Ep2Buffer;                                           //端点2数据传输地址
  UEP2_3_MOD = UEP2_3_MOD & ~bUEP2_BUF_MOD | bUEP2_TX_EN;         //端点2发送使能 64字节缓冲区
UEP3_DMA = Ep3Buffer;
UEP2_3_MOD |= bUEP3_TX_EN;                                      //端点3发送使能
  UEP2_3_MOD |= bUEP3_RX_EN;                                      //端点3接收使能
UEP2_3_MOD &= ~bUEP3_BUF_MOD;                                   //端点3收发各64字节缓冲区
//  UEP3_CTRL = bUEP_AUTO_TOG | UEP_T_RES_NAK | UEP_R_RES_ACK;      //端点3自动翻转同步标志位,IN事务返回NAK,OUT返回ACK
USB_DEV_AD = 0x00;
USB_CTRL |= bUC_DEV_PU_EN | bUC_INT_BUSY | bUC_DMA_EN;          // 启动USB设备及DMA,在中断期间中断标志未清除前自动返回NAK
UDEV_CTRL |= bUD_PORT_EN;                                       // 允许USB端口
USB_INT_FG = 0xFF;                                              // 清中断标志
USB_INT_EN = bUIE_SUSPEND | bUIE_TRANSFER | bUIE_BUS_RST;
IE_USB = 1;
case UIS_TOKEN_IN | 3:                                                  //endpoint 3# 中断端点上传
            UEP3_T_LEN = 0;                                                     //预使用发送长度一定要清空
//            UEP3_CTRL ^= bUEP_T_TOG;                                            //手动翻转同步标志位
            UEP3_CTRL = UEP3_CTRL & ~ MASK_UEP_T_RES | UEP_T_RES_NAK;           //默认应答NAK
            Endp3Busy = 0;
            break;
case UIS_TOKEN_OUT | 3:                                        // endpoint 3# 批量端点下传
if ( U_TOG_OK ) {                                          // 不同步的数据包将丢弃
//UEP3_CTRL ^= bUEP_R_TOG;                                // 手动翻转
len = USB_RX_LEN;
printf("KeyLength:%d\n",len);
if(len == 1)
CTouchUploadKeyInfo();
else
printf("Key:");
for ( i = 0; i < len; i ++ )
printf("x%02X ",(UINT16)(Ep3Buffer[i]) );
printf("\n");
CTouchSaveKeyInfo();
break;
// Description  : key upload
void Enp3IntIn( )
memcpy( Ep3Buffer, KeyData, sizeof(KeyData));
  if( TouchDeviceReady )
  UEP3_T_LEN = sizeof(KeyData);                              //上传数据长度
        UEP3_CTRL = UEP3_CTRL & ~ MASK_UEP_T_RES | UEP_T_RES_ACK;     //有数据时上传数据并应答ACK
        Endp3Busy = 1;
void CTouchUploadKeyInfo()
//需要返回的2字节报告的缓冲
 UINT8 Buf[2]={0,0};
 Buf[0] = 0x03;
 Buf[1] = 0x00;
 while( Endp3Busy )
    ;  //如果忙(上一包数据没有传上去),则等待。
 memcpy(KeyData,Buf,2);
 Enp3IntIn();
您好
您设置的端点3模式为单64字节接收,64发送模式。缓冲区定义只给了66的大小。
应当设置您的缓冲区大小为128字节,缓冲区地址为接收数据,地址偏移64是发送数据。
