/*设备描述符*/ UINT8C DevDesc[18] = {0x12,0x01,0x10,0x01,0x00,0x00,0x00,THIS_ENDP0_SIZE, 0x31,0x51,0x07,0x20,0x00,0x00,0x00,0x00, 0x00,0x01 }; UINT8C CfgDesc[41] = { 0x09,0x02,0x29,0x00,0x01,0x01,0x04,0xA0,0x23, //配置描述符 0x09,0x04,0x00,0x00,0x02,0x03,0x00,0x00,0x05, //接口描述符 0x09,0x21,0x00,0x01,0x00,0x01,0x22,0x22,0x00, //HID类描述符 0x07,0x05,0x82,0x03,ENDP2_IN_SIZE,0x00,0x01, //端点描述符 0x07,0x05,0x02,0x03,ENDP2_OUT_SIZE,0x00,0x01, //端点描述符 }; /*字符串描述符 略*/ /*HID类报表描述符*/ UINT8C HIDRepDesc[ ] = { 0x06, 0x00,0xff, 0x09, 0x01, 0xa1, 0x01, //集合开始 0x09, 0x02, //Usage Page 用法 0x15, 0x00, //Logical Minimun 0x26, 0x00,0xff, //Logical Maximun 0x75, 0x08, //Report Size 0x95, THIS_ENDP0_SIZE, //Report Counet 0x81, 0x06, //Input 0x09, 0x02, //Usage Page 用法 0x15, 0x00, //Logical Minimun 0x26, 0x00,0xff, //Logical Maximun 0x75, 0x08, //Report Size 0x95, THIS_ENDP0_SIZE, //Report Counet 0x91, 0x06, //Output 0xC0 }; // 建议gamepad UINT8C HIDRepDesc2[] = { 0x05, 0x01, // USAGE_PAGE (Generic Desktop) 0x09, 0x05, // USAGE (Game Pad) 0xa1, 0x01, // COLLECTION (Application) 0xa1, 0x00, // COLLECTION (Physical) // ReportID - 8 bits 0x85, 0x01, // REPORT_ID (1) // X & Y - 2x8 = 16 bits 0x05, 0x01, // USAGE_PAGE (Generic Desktop) 0x09, 0x30, // USAGE (X) 0x09, 0x31, // USAGE (Y) 0x15, 0x81, // LOGICAL_MINIMUM (-127) 0x25, 0x7f, // LOGICAL_MAXIMUM (127) 0x75, 0x08, // REPORT_SIZE (8) 0x95, 0x02, // REPORT_COUNT (2) 0x81, 0x02, // INPUT (Data,Var,Abs) // Buttons - 8 bits 0x05, 0x09, // USAGE_PAGE (Button) 0x19, 0x01, // USAGE_MINIMUM (Button 1) 0x29, 0x08, // USAGE_MAXIMUM (Button 8) 0x15, 0x00, // LOGICAL_MINIMUM (0) 0x25, 0x01, // LOGICAL_MAXIMUM (1) 0x75, 0x08, // REPORT_SIZE (8) 0x95, 0x01, // REPORT_COUNT (1) 0x81, 0x02, // INPUT (Data,Var,Abs) 0xc0, // END_COLLECTION 0xc0 // END_COLLECTION }; void Enp2BlukIn( ) { memcpy( Ep2Buffer+MAX_PACKET_SIZE_2, UserEp2Buf, USE_EP2_BUF_LEN); //加载上传数据 if( Ready ) { UEP2_T_LEN = THIS_ENDP0_SIZE; //上传最大包长度 UEP2_CTRL = UEP2_CTRL & ~ MASK_UEP_T_RES | UEP_T_RES_ACK; //有数据时上传数据并应答ACK Endp2Busy = 1; } } main() { UINT8 i, ch; CfgFsys(); // CH559时钟选择配置 mDelaymS(5); // 修改主频等待内部晶振稳定,必加 mInitSTDIO(); // 串口0初始化 Port1Cfg(1, 6); for (i = 0; i < ENDP2_IN_SIZE; i++) // 准备演示数据 { UserEp2Buf[i] = i; } USBDeviceInit(); // USB设备模式初始化 EA = 1; // 允许单片机中断 UEP1_T_LEN = 0; // 预使用发送长度一定要清空 UEP2_T_LEN = 0; // 预使用发送长度一定要清空 Ready = 0; ch = 0; LED_PIN = 0; while (1) { if (Ready && (Ep2InKey == 0)) { while (Endp2Busy) { } UserEp2Buf[0] = 1; ++ch; UserEp2Buf[1] = ch; UserEp2Buf[2] = ch; UserEp2Buf[3] = ch; UserEp2Buf[4] = ch; Enp2IntIn(); } LED_PIN = !Ep2InKey; mDelaymS(100); // 模拟单片机做其它事 } }
请教各位大佬,上面代码中HIDRepDesc是官网默认带的,可以发送数据,并通过HidRawDataWatcher看到发送了什么数据;
改为HIDRepDesc2,这个我自定义的gamepad后,Enp2BlukIn发送的数据HidRawDataWatcher就看不到了。
好像只要指定了report id就无法发送数据了,我在main中已经指定了UserEp2Buf的第一个字节是1了。
CH390:以太网控制器芯片
