只能运行到1 发送设备地址0x30 逻辑分析仪检测到的确是0x18
#define NorthAdderss 0x30
I2C_Init(I2C_Mode_I2C, 10000, I2C_DutyCycle_16_9, I2C_Ack_Enable, I2C_AckAddr_7bit, 0);
while(I2C_GetFlagStatus(I2C_FLAG_BUSY));
PRINT("IIC start\r\n");
I2C_GenerateSTART(ENABLE);
while(!I2C_CheckEvent(I2C_EVENT_MASTER_MODE_SELECT));
I2C_Send7bitAddress(NorthAdderss, I2C_Direction_Transmitter);
PRINT("1 \r\n");
while(!I2C_CheckEvent(I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
PRINT("2 \r\n");
I2C_SendData(0x39);
while(!I2C_CheckEvent(I2C_EVENT_MASTER_BYTE_TRANSMITTED));
PRINT("3 \r\n");
