CH32V307VCT6
void ws281x_init(void)
    GPIO_InitTypeDef GPIO_InitStructure;
    SPI_InitTypeDef  SPI_InitStructure;
    DMA_InitTypeDef DMA_InitStructure;
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC | RCC_APB2Periph_AFIO, ENABLE); //PORTA时钟使能
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI3, ENABLE); //SPI3时钟使能
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);   //使能DMA传输
    GPIO_PinRemapConfig(GPIO_Remap_SPI3, ENABLE);
    /* PC12  SPI3_MOSI */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_Init(GPIOC, &GPIO_InitStructure);
    SPI_InitStructure.SPI_Direction = SPI_Direction_1Line_Tx;  //设置SPI单向或者双向的数据模式:SPI设置为双线双向全双工
    SPI_InitStructure.SPI_Mode = SPI_Mode_Master;                //设置SPI工作模式:设置为主SPI
    SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;                //设置SPI的数据大小:SPI发送接收8位帧结构
    SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;                //串行同步时钟的空闲状态为低电平
    SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;        //串行同步时钟的第2个跳变沿(上升或下降)数据被采样
    SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;                //NSS信号由硬件(NSS管脚)还是软件(使用SSI位)管理:内部NSS信号有SSI位控制
    SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_32;                //定义波特率预分频的值:波特率预分频值为16
    SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;        //指定数据传输从MSB位还是LSB位开始:数据传输从MSB位开始
    SPI_InitStructure.SPI_CRCPolynomial = 7;        //CRC值计算的多项式
    SPI_Init(SPI3, &SPI_InitStructure);  //根据SPI_InitStruct中指定的参数初始化外设SPIx寄存器
    SPI_Cmd(SPI3, ENABLE); //使能SPI外设
    SPI_I2S_DMACmd(SPI3, SPI_I2S_DMAReq_Tx, ENABLE);
    DMA_DeInit(DMA1_Channel5);   //将DMA的通道5寄存器重设为缺省值
    DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t) &(SPI3 -> DATAR); //cpar;  //DMA外设ADC基地址
    DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)pixelBuffer; //cmar;  //DMA内存基地址
    DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;  //数据传输方向,从内存读取发送到外设
    DMA_InitStructure.DMA_BufferSize = PIXEL_NUM * 24; //cndtr;  //DMA通道的DMA缓存的大小
    DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;  //外设地址寄存器不变
    DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;  //内存地址寄存器递增
    DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;  //数据宽度为8位
    DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte; //数据宽度为8位
    DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;  //工作在正常缓存模式
    DMA_InitStructure.DMA_Priority = DMA_Priority_Medium; //DMA通道 x拥有中优先级
    DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;  //DMA通道x没有设置为内存到内存传输
    DMA_Init(DMA1_Channel5, &DMA_InitStructure);  //根据DMA_InitStruct中指定的参数初始化DMA的通道USART1_Tx_DMA_Channel所标识的寄存器
    DMA_ClearFlag(DMA1_FLAG_TC5);
    ws281x_closeAll();  //关闭全部的灯
    Delay_Ms(100); //关闭全部的灯需要一定的时间
void ws281x_show(void)
    static uint8_t sendflag = 0;
    if (!sendflag)
        printf("send new\r\n");
        DMA_Cmd(DMA1_Channel5, DISABLE );
        DMA_SetCurrDataCounter(DMA1_Channel5, 24 * PIXEL_NUM);
        DMA_Cmd(DMA1_Channel5, ENABLE);
        sendflag = 1;
    else {
        if (DMA_GetFlagStatus(DMA1_FLAG_TC5) == RESET)
            sendflag = 0;
            printf("send over\r\n");
引脚PC12没有数据输出啊?这个是为什么?
您好,SPI3的输出引脚对应的DMA通道应该是DMA2通道2,如下图,你可以修改试一下。
