在自己花的ch573f芯片上测试了一下上电源亮灯,过了大概10s左右才亮,试了几个不同的例程结果都差不多,是启动文件哪里有问题么
启动文件如下
/********************************** (C) COPYRIGHT *******************************
* File Name : startup_ch57x.s
* Author : WCH
* Version : V1.0.0
* Date : 2020/04/30
* Description :
* Copyright (c) 2021 Nanjing Qinheng Microelectronics Co., Ltd.
* SPDX-License-Identifier: Apache-2.0
.section .init,"ax",@progbits
.global _start
.align 1
_start:
j handle_reset
.section .vector,"ax",@progbits
.align 1
_vector_base:
.option norvc;
.word 0
.word 0
j NMI_Handler /* NMI Handler */
j HardFault_Handler /* Hard Fault Handler */
.word 0
.word 0
.word 0
.word 0
.word 0
.word 0
.word 0
.word 0
j SysTick_Handler /* SysTick Handler */
.word 0
j SW_Handler /* SW Handler */
.word 0
/* External Interrupts */
j TMR0_IRQHandler /* 0: TMR0 */
j GPIOA_IRQHandler /* GPIOA */
j GPIOB_IRQHandler /* GPIOB */
j SPI0_IRQHandler /* SPI0 */
j BB_IRQHandler /* BLEB */
j LLE_IRQHandler /* BLEL */
j USB_IRQHandler /* USB */
.word 0
j TMR1_IRQHandler /* TMR1 */
j TMR2_IRQHandler /* TMR2 */
j UART0_IRQHandler /* UART0 */
j UART1_IRQHandler /* UART1 */
j RTC_IRQHandler /* RTC */
j ADC_IRQHandler /* ADC */
.word 0
j PWMX_IRQHandler /* PWMX */
j TMR3_IRQHandler /* TMR3 */
j UART2_IRQHandler /* UART2 */
j UART3_IRQHandler /* UART3 */
j WDOG_BAT_IRQHandler /* WDOG_BAT */
.option rvc;
.section .vector_handler, "ax", @progbits
.weak NMI_Handler
.weak HardFault_Handler
.weak SysTick_Handler
.weak SW_Handler
.weak TMR0_IRQHandler
.weak GPIOA_IRQHandler
.weak GPIOB_IRQHandler
.weak SPI0_IRQHandler
.weak BB_IRQHandler
.weak LLE_IRQHandler
.weak USB_IRQHandler
.weak TMR1_IRQHandler
.weak TMR2_IRQHandler
.weak UART0_IRQHandler
.weak UART1_IRQHandler
.weak RTC_IRQHandler
.weak ADC_IRQHandler
.weak PWMX_IRQHandler
.weak TMR3_IRQHandler
.weak UART2_IRQHandler
.weak UART3_IRQHandler
.weak WDOG_BAT_IRQHandler
NMI_Handler: 1: j 1b
HardFault_Handler: 1: j 1b
SysTick_Handler: 1: j 1b
SW_Handler: 1: j 1b
TMR0_IRQHandler: 1: j 1b
GPIOA_IRQHandler: 1: j 1b
GPIOB_IRQHandler: 1: j 1b
SPI0_IRQHandler: 1: j 1b
BB_IRQHandler: 1: j 1b
LLE_IRQHandler: 1: j 1b
USB_IRQHandler: 1: j 1b
TMR1_IRQHandler: 1: j 1b
TMR2_IRQHandler: 1: j 1b
UART0_IRQHandler: 1: j 1b
UART1_IRQHandler: 1: j 1b
RTC_IRQHandler: 1: j 1b
ADC_IRQHandler: 1: j 1b
PWMX_IRQHandler: 1: j 1b
TMR3_IRQHandler: 1: j 1b
UART2_IRQHandler: 1: j 1b
UART3_IRQHandler: 1: j 1b
WDOG_BAT_IRQHandler: 1: j 1b
.section .handle_reset,"ax",@progbits
.weak handle_reset
.align 1
handle_reset:
.option push
.option norelax
la gp, __global_pointer$
.option pop
1:
la sp, _eusrstack
/* Load highcode code section from flash to RAM */
2:
la a0, _highcode_lma
la a1, _highcode_vma_start
la a2, _highcode_vma_end
bgeu a1, a2, 2f
1:
lw t0, (a0)
sw t0, (a1)
addi a0, a0, 4
addi a1, a1, 4
bltu a1, a2, 1b
/* Load data section from flash to RAM */
2:
la a0, _data_lma
la a1, _data_vma
la a2, _edata
bgeu a1, a2, 2f
1:
lw t0, (a0)
sw t0, (a1)
addi a0, a0, 4
addi a1, a1, 4
bltu a1, a2, 1b
2:
/* clear bss section */
la a0, _sbss
la a1, _ebss
bgeu a0, a1, 2f
1:
sw zero, (a0)
addi a0, a0, 4
bltu a0, a1, 1b
2:
li t0, 0x88
csrs mstatus, t0
la t0, _vector_base
ori t0, t0, 1
csrw mtvec, t0
la t0, main
csrw mepc, t0
/* enable vector relocation
li t0, 0xE000ED14
li t1, 1
sw t1, 0(t0)*/
mret
偶尔启动速度很快,大多时候十多秒
如果是10s左右的话,可以看下pb22引脚在上电时是不是接地了,导致程序停留在bootloader中等待升级。
拿万用表量了一下没接地,但是我刷程序的时候上电就直接检测到设备了,PB22没跟PB23用跳冒线短接
上电是直接检测到设备,则代表进入boot模式,此时会在boot等待无法运行你的功能代码。检查PB22是否接地,如果上电的时候该引脚接地则会进入boot。正常处理将该引脚处于悬空的状态即可;并检查是否将烧录引脚修改为PB11(上电拉高会进入boot);可以烧录一个ADC的代码测试查看是否会上电立马执行功能代码。
