偶尔情况是这样,但是好像时不时会出现,断电重上电之后可能会正常,安卓主机的日志:[INFO:btsnoop.cc(323)] clear_l2cap_whitelist: Clearing whitelist from l2cap channel. conn_handle=6 cid=4:4
btm_sec_disconnected clearing pending flag handle:6 reason:8
蓝牙设置:
// How often to perform read rssi event
#define SBP_READ_RSSI_EVT_PERIOD 3200
// Parameter update delay
#define SBP_PARAM_UPDATE_DELAY 6400
// What is the advertising interval when device is discoverable (units of 625us, 80=50ms)
#define DEFAULT_ADVERTISING_INTERVAL 80
// Limited discoverable mode advertises for 30.72s, and then stops
// General discoverable mode advertises indefinitely
#define DEFAULT_DISCOVERABLE_MODE GAP_ADTYPE_FLAGS_GENERAL
// Minimum connection interval (units of 1.25ms, 6=7.5ms)
#define DEFAULT_DESIRED_MIN_CONN_INTERVAL 6
// Maximum connection interval (units of 1.25ms, 100=125ms)
#define DEFAULT_DESIRED_MAX_CONN_INTERVAL 3200
// Slave latency to use parameter update
#define DEFAULT_DESIRED_SLAVE_LATENCY 6
// Supervision timeout value (units of 10ms, 100=1s)
#define DEFAULT_DESIRED_CONN_TIMEOUT 3200
