OTA升级工具
   正常使用时没问题,使用OTA升级工具时连接蓝牙或者点击GETINFO后板子就变成砖了,得重新用usb刷代码,以下是部分改动,跟这部分有关系吗
     case GAPROLE_CONNECTED:
            gapEstLinkReqEvent_t *event = (gapEstLinkReqEvent_t *)pEvent;
            uint16_t              conn_interval = 0;
            //conn_interval = event->connInterval;
            if(pEvent->gap.opcode == GAP_LINK_ESTABLISHED_EVENT)
                Peripheral_LinkEstablished(pEvent);
                GPIOA_SetBits(GPIO_Pin_8);    //连接灯亮
                GPIOB_ResetBits(GPIO_Pin_7);
                PRINT("Connected..\n");
            if(conn_interval > DEFAULT_DESIRED_MAX_CONN_INTERVAL)
                PRINT("Send Update\r\n");
                GAPRole_PeripheralConnParamUpdateReq(event->connectionHandle,
                                                     DEFAULT_DESIRED_MIN_CONN_INTERVAL,
                                                     DEFAULT_DESIRED_MAX_CONN_INTERVAL,
                                                     DEFAULT_DESIRED_SLAVE_LATENCY,
                                                     DEFAULT_DESIRED_CONN_TIMEOUT,
                                                     Peripheral_TaskID);
            break;
        case GAPROLE_CONNECTED_ADV:
            PRINT("Connected Advertising..\n");
            break;
        case GAPROLE_WAITING:
            if(pEvent->gap.opcode == GAP_LINK_TERMINATED_EVENT)
                Peripheral_LinkTerminated(pEvent);
                GPIOA_ResetBits(GPIO_Pin_8);      //断开连接灯灭
                GPIOB_SetBits(GPIO_Pin_7);
                loadch = false;
                startadc = false;
                fdeltch = false;
                chageload = false;
                noload = false;
                PRINT("Disconnected.. Reason:%x\n", pEvent->linkTerminate.reason);
https://www.cnblogs.com/risc5-ble/p/17386314.html
https://www.cnblogs.com/risc5-ble/p/16986897.html
您好,这边有两份博客介绍,分别是备份升级和固定库升级两种方式的介绍,您这边看一下
