关于CH32V003J4M6开启TIM2的PC2(T2CH2)PWM输出事宜
前辈,我需要CH32V003J4M6开启TIM2的PC2(T2CH2_)PWM输出,这是个复用PIN,我不懂复用重映射配置,麻烦帮忙提供下资源范例或代码.谢谢!
/********************************** (C) COPYRIGHT *******************************
 * File Name          : main.c
 * Author             : WCH
 * Version            : V1.0.0
 * Date               : 2022/08/08
 * Description        : Main program body.
* Copyright (c) 2021 Nanjing Qinheng Microelectronics Co., Ltd.
* Attention: This software (modified or not) and binary are used for
* microcontroller manufactured by Nanjing Qinheng Microelectronics.
 *@Note
 PWM output routine:
 TIM1_CH1(PD2)
 This example demonstrates that the TIM_CH1(PD2) pin outputs PWM in PWM mode 1
 and PWM mode 2.
#include "debug.h"
/* PWM Output Mode Definition */
#define PWM_MODE1   0
#define PWM_MODE2   1
/* PWM Output Mode Selection */
//#define PWM_MODE PWM_MODE1
#define PWM_MODE PWM_MODE2
 * @fn      TIM1_OutCompare_Init
 * @brief   Initializes TIM1 output compare.
 * @param   arr - the period value.
 *          psc - the prescaler value.
 *          ccp - the pulse value.
 * @return  none
void TIM2_PWMOut_Init(u16 arr, u16 psc, u16 ccp)
    GPIO_InitTypeDef GPIO_InitStructure={0};
    TIM_OCInitTypeDef TIM_OCInitStructure={0};
    TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStructure={0};
    RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOC | RCC_APB2Periph_AFIO, ENABLE );
    GPIO_PinRemapConfig(GPIO_PartialRemap1_TIM2, ENABLE);
    RCC_APB1PeriphClockCmd( RCC_APB1Periph_TIM2, ENABLE );
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_Init( GPIOC, &GPIO_InitStructure );
    TIM_TimeBaseInitStructure.TIM_Period = arr;
    TIM_TimeBaseInitStructure.TIM_Prescaler = psc;
    TIM_TimeBaseInitStructure.TIM_ClockDivision = TIM_CKD_DIV1;
    TIM_TimeBaseInitStructure.TIM_CounterMode = TIM_CounterMode_Up;
    TIM_TimeBaseInit( TIM2, &TIM_TimeBaseInitStructure);
#if (PWM_MODE == PWM_MODE1)
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
#elif (PWM_MODE == PWM_MODE2)
    TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
#endif
    TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
    TIM_OCInitStructure.TIM_Pulse = ccp;
    TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
    TIM_OC2Init( TIM2, &TIM_OCInitStructure );
    TIM_CtrlPWMOutputs(TIM2, ENABLE );
    TIM_OC2PreloadConfig( TIM2, TIM_OCPreload_Disable );
    TIM_ARRPreloadConfig( TIM2, ENABLE );
    TIM_Cmd( TIM2, ENABLE );
 * @fn      main
 * @brief   Main program.
 * @return  none
int main(void)
    USART_Printf_Init(115200);
    printf("SystemClk:%d\r\n",SystemCoreClock);
    TIM2_PWMOut_Init( 100, 48000-1, 50 );
    while(1);
你好 ,参考这个。
