实例代码如下
/********************************** (C) COPYRIGHT ******************************* * File Name : main.c * Author : WCH * Version : V1.0.0 * Date : 2024/02/20 * Description : Main program body. ********************************************************************************* * Copyright (c) 2021 Nanjing Qinheng Microelectronics Co., Ltd. * Attention: This software (modified or not) and binary are used for * microcontroller manufactured by Nanjing Qinheng Microelectronics. *******************************************************************************/ /* *@Note *TIM trigger ADC conversion routine: *ADC channel 2 (PC4) - injection group channel, TIM1 CH3 pin (PC3) TIM trigger, *In this mode, an ADC conversion is triggered by an event on TIM1 CH3 TIM trigger, and a JEOC interrupt is generated after *the conversion is completed. * */ #include "debug.h" /* Global Variable */ /********************************************************************* * @fn ADC_Function_Init * * @brief Initializes ADC collection. * * @return none */ void ADC_Function_Init(void) { ADC_InitTypeDef ADC_InitStructure = {0}; GPIO_InitTypeDef GPIO_InitStructure = {0}; NVIC_InitTypeDef NVIC_InitStructure = {0}; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE); RCC_ADCCLKConfig(RCC_PCLK2_Div6); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN; GPIO_Init(GPIOC, &GPIO_InitStructure); ADC_DeInit(ADC1); ADC_InitStructure.ADC_Mode = ADC_Mode_Independent; ADC_InitStructure.ADC_ScanConvMode = DISABLE; ADC_InitStructure.ADC_ContinuousConvMode = DISABLE; ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigInjecConv_T1_CC3; ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; ADC_InitStructure.ADC_NbrOfChannel = 1; ADC_Init(ADC1, &ADC_InitStructure); ADC_InjectedSequencerLengthConfig(ADC1, 1); ADC_InjectedChannelConfig(ADC1, ADC_Channel_2, 1, ADC_SampleTime_9Cycles); ADC_ExternalTrigInjectedConvCmd(ADC1, ENABLE); NVIC_InitStructure.NVIC_IRQChannel = ADC_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); ADC_ExternalTrig_DLY(ADC1, ADC_ExternalTrigInjec_DLY, 0x80); /* external trigger sources delay time */ ADC_Calibration_Vol(ADC1, ADC_CALVOL_50PERCENT); ADC_ITConfig(ADC1, ADC_IT_JEOC, ENABLE); ADC_Cmd(ADC1, ENABLE); ADC_ResetCalibration(ADC1); while(ADC_GetResetCalibrationStatus(ADC1)); ADC_StartCalibration(ADC1); while(ADC_GetCalibrationStatus(ADC1)); } /********************************************************************* * @fn EXTI_Event_Init * * @brief Initializes EXTI. * * @return none */ void TIM1_PWM_In(u16 arr, u16 psc, u16 ccp) { GPIO_InitTypeDef GPIO_InitStructure = {0}; TIM_OCInitTypeDef TIM_OCInitStructure = {0}; TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStructure = {0}; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC | RCC_APB2Periph_TIM1, ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;// GPIO_InitStructure.GPIO_Speed = GPIO_Speed_30MHz; GPIO_Init(GPIOC, &GPIO_InitStructure); TIM_TimeBaseInitStructure.TIM_Period = arr; TIM_TimeBaseInitStructure.TIM_Prescaler = psc; TIM_TimeBaseInitStructure.TIM_ClockDivision = TIM_CKD_DIV1; TIM_TimeBaseInitStructure.TIM_CounterMode = TIM_CounterMode_Up; TIM_TimeBaseInit(TIM1, &TIM_TimeBaseInitStructure); TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1; TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; TIM_OCInitStructure.TIM_Pulse = ccp; TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; TIM_OC3Init(TIM1, &TIM_OCInitStructure); TIM_CCxCmd(TIM1, TIM_Channel_3, TIM_CCx_Enable); TIM_CtrlPWMOutputs(TIM1, ENABLE); TIM_OC3PreloadConfig(TIM1, TIM_OCPreload_Disable); TIM_ARRPreloadConfig(TIM1, ENABLE); TIM_SelectOutputTrigger(TIM1, TIM_TRGOSource_Update); TIM_Cmd(TIM1, ENABLE); } /********************************************************************* * @fn main * * @brief Main program. * * @return none */ int main(void) { SystemCoreClockUpdate(); Delay_Init(); #if (SDI_PRINT == SDI_PR_OPEN) SDI_Printf_Enable(); #else USART_Printf_Init(115200); #endif printf("SystemClk:%d\r\n", SystemCoreClock); printf( "ChipID:%08x\r\n", DBGMCU_GetCHIPID() ); RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD, ENABLE); GPIO_InitTypeDef GPIO_InitStructure = {0}; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;// GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOD, &GPIO_InitStructure); ADC_Function_Init(); TIM1_PWM_In(4800,100,2400); while(1) { } } void ADC1_IRQHandler(void) __attribute__((interrupt("WCH-Interrupt-fast"))); /********************************************************************* * @fn ADC1_IRQHandler * * @brief ADC1_2 Interrupt Service Function. * * @return none */ void ADC1_IRQHandler(void) { if(ADC_GetITStatus(ADC1, ADC_IT_JEOC)) { //printf("ADC Extline trigger conversion...\r\n"); //ADC_val = ADC_GetInjectedConversionValue(ADC1, ADC_InjectedChannel_1); //printf("JADC-%04d\r\n", ADC_val); GPIO_SetBits(GPIOD, GPIO_Pin_2); GPIO_ResetBits(GPIOD, GPIO_Pin_2); } ADC_ClearITPendingBit(ADC1, ADC_IT_JEOC); }
当延时设置为0x00时:
ADC_ExternalTrig_DLY(ADC1, ADC_ExternalTrigInjec_DLY, 0x00);
波形如下:
当延时设置为0x40时:
ADC_ExternalTrig_DLY(ADC1, ADC_ExternalTrigInjec_DLY, 0x40);
波形如下:
大约都是3.8us,与预期不符。
代码附件:
CH390:以太网控制器芯片
