新手小白求助,ch32v307连接esp826601s连接不上,串口连接使用的串口3,打印用的1
#include "usart.h"
#include
#include
#include
void Usart1_Init(unsigned int baud)
    GPIO_InitTypeDef gpio_initstruct;
    USART_InitTypeDef usart_initstruct;
    NVIC_InitTypeDef nvic_initstruct;
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
    //PA9   TXD
    gpio_initstruct.GPIO_Mode = GPIO_Mode_AF_PP;
    gpio_initstruct.GPIO_Pin = GPIO_Pin_9;
    gpio_initstruct.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_Init(GPIOA, &gpio_initstruct);
    //PA10  RXD
    gpio_initstruct.GPIO_Mode = GPIO_Mode_IN_FLOATING;
    gpio_initstruct.GPIO_Pin = GPIO_Pin_10;
    usart_initstruct.USART_BaudRate = baud;
    usart_initstruct.USART_HardwareFlowControl = USART_HardwareFlowControl_None;        //无硬件流控
    usart_initstruct.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;                        //接收和发送
    usart_initstruct.USART_Parity = USART_Parity_No;                                    //无校验
    usart_initstruct.USART_StopBits = USART_StopBits_1;                             //1位停止位
    usart_initstruct.USART_WordLength = USART_WordLength_8b;                            //8位数据位
    USART_Init(USART1, &usart_initstruct);
    USART_Cmd(USART1, ENABLE);                                                      //使能串口
    USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);                                  //使能接收中断
    nvic_initstruct.NVIC_IRQChannel = USART1_IRQn;
    nvic_initstruct.NVIC_IRQChannelCmd = ENABLE;
    nvic_initstruct.NVIC_IRQChannelPreemptionPriority = 0;
    nvic_initstruct.NVIC_IRQChannelSubPriority = 2;
    NVIC_Init(&nvic_initstruct);
void Usart2_Init(unsigned int baud)
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3, ENABLE);
    GPIO_Init(GPIOB, &gpio_initstruct);
    gpio_initstruct.GPIO_Pin = GPIO_Pin_11;
    USART_Init(USART3, &usart_initstruct);
    USART_Cmd(USART3, ENABLE);                                                      //使能串口
    USART_ITConfig(USART3, USART_IT_RXNE, ENABLE);                                  //使能接收中断
    nvic_initstruct.NVIC_IRQChannel = USART3_IRQn;
    nvic_initstruct.NVIC_IRQChannelSubPriority = 0;
void Usart_SendString(USART_TypeDef *USARTx, unsigned char *str, unsigned short len)
    unsigned short count = 0;
    for(; count < len; count++)
        USART_SendData(USARTx, *str++);                                 //发送数据
        while(USART_GetFlagStatus(USARTx, USART_FLAG_TC) == RESET);     //等待发送完成
void UsartPrintf(USART_TypeDef *USARTx, char *fmt,...)
    unsigned char UsartPrintfBuf[296];
    va_list ap;
    unsigned char *pStr = UsartPrintfBuf;
    va_start(ap, fmt);
    vsnprintf((char *)UsartPrintfBuf, sizeof(UsartPrintfBuf), fmt, ap);                         //格式化
    va_end(ap);
    while(*pStr != 0)
        USART_SendData(USARTx, *pStr++);
void USART1_IRQHandler(void)
    if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET) //接收中断
        USART_ClearFlag(USART1, USART_FLAG_RXNE);
//这是串口初始化,下面是esp8266的代码
#include "debug.h"
#include "esp8266.h"
#include "usart.h"
#include
#include
#define ESP8266_WIFI_INFO       "AT+CWJAP=\"IQOOneo5\",\"12345678\"\r\n"
unsigned char esp8266_buf[512];
unsigned short esp8266_cnt = 0, esp8266_cntPre = 0;
void ESP8266_Clear(void)
    memset(esp8266_buf, 0, sizeof(esp8266_buf));
    esp8266_cnt = 0;
_Bool ESP8266_WaitRecive(void)
    if(esp8266_cnt == 0)                            //如果接收计数为0 则说明没有处于接收数据中,所以直接跳出,结束函数
        return REV_WAIT;
    if(esp8266_cnt == esp8266_cntPre)               //如果上一次的值和这次相同,则说明接收完毕
        esp8266_cnt = 0;                            //清0接收计数
        return REV_OK;                              //返回接收完成标志
    esp8266_cntPre = esp8266_cnt;                   //置为相同
    return REV_WAIT;                                //返回接收未完成标志
_Bool ESP8266_SendCmd(char *cmd, char *res)
    unsigned char timeOut = 200;
    Usart_SendString(USART3, (unsigned char *)cmd, strlen((const char *)cmd));
    while(timeOut--)
        if(ESP8266_WaitRecive() == REV_OK)                          //如果收到数据
            UsartPrintf(USART_DEBUG, " Hardware init OK\r\n");
            if(strstr((const char *)esp8266_buf, res) != NULL)      //如果检索到关键词
                ESP8266_Clear();                                    //清空缓存
                return 0;
        Delay_Ms(10);
    return 1;
void ESP8266_SendData(unsigned char *data, unsigned short len)
    char cmdBuf[32];
    ESP8266_Clear();                                //清空接收缓存
    sprintf(cmdBuf, "AT+CIPSEND=%d\r\n", len);      //发送命令
    if(!ESP8266_SendCmd(cmdBuf, ">"))               //收到‘>’时可以发送数据
        Usart_SendString(USART3, data, len);        //发送设备连接请求数据
unsigned char *ESP8266_GetIPD(unsigned short timeOut)
    char *ptrIPD = NULL;
    do
        if(ESP8266_WaitRecive() == REV_OK)                              //如果接收完成
            ptrIPD = strstr((char *)esp8266_buf, "IPD,");               //搜索“IPD”头
            if(ptrIPD == NULL)                                          //如果没找到,可能是IPD头的延迟,还是需要等待一会,但不会超过设定的时间
                //UsartPrintf(USART_DEBUG, "\"IPD\" not found\r\n");
            else
                ptrIPD = strchr(ptrIPD, ':');                           //找到':'
                if(ptrIPD != NULL)
                    ptrIPD++;
                    return (unsigned char *)(ptrIPD);
                else
                    return NULL;
        Delay_Ms(10);                                              //延时等待
    } while(timeOut--);
    return NULL;                                                        //超时还未找到,返回空指针
void ESP8266_Init(void)
    ESP8266_Clear();
    UsartPrintf(USART_DEBUG, "1. AT\r\n");
    while(ESP8266_SendCmd("AT\r\n", "OK"))
        Delay_Ms(500);
    UsartPrintf(USART_DEBUG, "2. CWMODE\r\n");
    while(ESP8266_SendCmd("AT+CWMODE=1\r\n", "OK"))
        Delay_Ms(500);
    UsartPrintf(USART_DEBUG, "3. AT+CWDHCP\r\n");
    while(ESP8266_SendCmd("AT+CWDHCP=1,1\r\n", "OK"))
        Delay_Ms(500);
    UsartPrintf(USART_DEBUG, "4. CWJAP\r\n");
    while(ESP8266_SendCmd(ESP8266_WIFI_INFO, "GOT IP"))
        Delay_Ms(500);
    UsartPrintf(USART_DEBUG, "5. ESP8266 Init OK\r\n");
void USART2_IRQHandler(void)
    if(USART_GetITStatus(USART3, USART_IT_RXNE) != RESET) //接收中断
        if(esp8266_cnt >= sizeof(esp8266_buf))  esp8266_cnt = 0; //防止串口被刷爆
        esp8266_buf[esp8266_cnt++] = USART3->DATAR;
        USART_ClearFlag(USART3, USART_FLAG_RXNE);
image.png卡到连接第一步。
您好,下图圈出部分应该有问题,使用的是串口3 PB10、PB11,应该使能开启GPIOB的时钟,此外中断函数名称应该改为串口3的。此外注意中断函数要加中断声明。
您好,谢谢您的回复,使能时钟是我疏忽了,我按照您的提供修改了时钟与中断,结果好像没变化,是不是使用串口没用好呢
您好,中断函数注意加一下中断声明,参考下图。若方便,可将你的工程发我的邮箱(lzs@wch.cn)具体看一下
感谢您的回复,已解决问题
