FreeModbus successfully ported to CH32V307
Here you have Modbus RTU working on CH32V307VCT6.
Connect an USB-TTL adapter to A9/A10 and use RMMS (RADZIO MODBUS) 19200, 8N1 to test.
More info in the GitHub:
https://github.com/NedelcuBogdanSebastian/CH32V307ModbusRTU
If someone would want to help me port also Modbus TCP will be very usefull!
臉/笑脸
you are so great!??The code quality is so good!
这个人将freeMOdbus移植到CH32V307上了。他是罗马尼亚的一位专家/科学家,我在IEEE上看到他的名字了。
建议管理员保存好这类高质量资料,方便其他用户使用和参与开发
Please check also Modbus TCP example for the CH32V307VCT6 :
https://github.com/NedelcuBogdanSebastian/CH32V307ModbusTCP
great work! it's very cool!
大概看了RTU的移植代码,基本上都是参考官方的例程来移植的,并没有看到什么亮点。
依然是接收靠串口接收中断收数据、发送靠空闲中断发数据…
如果波特率上到2.5mbps,感觉有丢数据的风险或者在接收120个寄存器时短时间250个接收中断轰炸,其他低优先的中断得跪,又或者主循环周期很遭罪。
依然是仅支持唯一串口、唯一实例。
讲真,在实际项目中我从来不用这玩意,还是自己弄自己的更方便。
讲真,git上有不少开源的modbus都比FreeModbus优秀很多很多。
Check also this implementation of a server with support for WEBSOCKETS, JSON, AJAX, and MODBUS TCP
on the CH32V307VCT6.
https://github.com/NedelcuBogdanSebastian/CH32V307JSONMODBUSWEBSOCKETAJAX
Dear Mr. Zaxife :
I know the following products very well:
1. Janitza-UMG-604-power-quality-monitor
2. Hydrocal-1005-gas-in-oil measurement
3. Qualitrol-Tguard-408-fiber-optic-temperature-monitor
4. ZVCM-1001-bushing-monitor
If those giants use only one Modbus 485 port, and it works for years at only 19200 baud rate, than
I am realy happy with my humble example! :)
The work started because I didn't found in the internet many examples of Modbus, Websockets,
for the CH32V307, which in my humble oppinion is a GREAT, again, a GREAT MICROCONTROLLER!
The FreeModbus is a great library!
Good luck and fortune!
