这两天在整理代码,看了hal的代码,效率有待提高。
   可以用宏定义来实现,得到高效的代码。建议用##连接宏。
 * @fn      USART_GetITStatus
 * @brief   Checks whether the specified USART interrupt has occurred or not.
 * @param   USARTx - where x can be 1 to select the USART peripheral.
 *          USART_IT - specifies the USART interrupt source to check.
 *            USART_IT_LBD - LIN Break detection interrupt.
 *            USART_IT_TXE - Tansmit Data Register empty interrupt.
 *            USART_IT_TC - Transmission complete interrupt.
 *            USART_IT_RXNE - Receive Data register not empty interrupt.
 *            USART_IT_IDLE - Idle line detection interrupt.
 *            USART_IT_ORE_RX - OverRun Error interrupt if the RXNEIE bit is set.
 *            USART_IT_ORE_ER - OverRun Error interrupt if the EIE bit is set.
 *            USART_IT_NE - Noise Error interrupt.
 *            USART_IT_FE - Framing Error interrupt.
 *            USART_IT_PE - Parity Error interrupt.
 * @return  bitstatus: SET or RESET.
ITStatus USART_GetITStatus(USART_TypeDef *USARTx, uint16_t USART_IT)
    uint32_t bitpos = 0x00, itmask = 0x00, usartreg = 0x00;
    ITStatus bitstatus = RESET;
    usartreg = (((uint8_t)USART_IT) >> 0x05);
    itmask = USART_IT & IT_Mask;
    itmask = (uint32_t)0x01 << itmask;
    if(usartreg == 0x01)
        itmask &= USARTx->CTLR1;
    else if(usartreg == 0x02)
        itmask &= USARTx->CTLR2;
    else
        itmask &= USARTx->CTLR3;
    bitpos = USART_IT >> 0x08;
    bitpos = (uint32_t)0x01 << bitpos;
    bitpos &= USARTx->STATR;
    if((itmask != (uint16_t)RESET) && (bitpos != (uint16_t)RESET))
        bitstatus = SET;
    else
        bitstatus = RESET;
    return bitstatus;
您好,感谢你的建议,这边会反馈给相关同事
我去,我基本上极少用串口中断,还真没留意这个函数里面是这样处理的啊…这也太浪费资源了…感觉还是不用官方的函数,自己直接操作寄存器更节省资源。
就是三种通信类外设中断标志位这么写。完全要以用inline类函数或宏定义实现
更高效率。
