根据文档的步骤,在使用sudo ln –s /dev/ttyUSB0 /dev/ttyISP0报错,
~/work$ sudo ln –s /dev/ttyUSB0 /dev/ttyISP0 ln: 目标 '/dev/ttyISP0': 不是目录
但直接使用/dev/ttyUSB0下载报错
~/work$ sudo ./WCHISPTool_CMD -p /dev/ttyUSB0 -b 115200 -c Config.ini -o program -f 5G.hex =====ISP_Command_Tool===== TOOL VERSION: V3.60 p:/dev/ttyUSB0 b:115200 v:0 c:Config.ini o:0 f:5G.hex read configuration file or set isp option to device error. {"Device":/dev/ttyUSB0", "Status":"Fail", "Code":100, "Message":"Unknow error"}
是要安装什么驱动吗???
CH641: PD及无线充电专用MCU
