CH32V307V SD卡 死在FindSCR 函数
使用官方的 示例代码中的 SDIO_SD工程。
自己做的评估板,想同时使用 10M ETH PHY, 和 SD卡。 看到datasheet中可以将PB14,PB15作为 SDIO_D1和 SDIO_DO 使用。
SD_Error SD_Init( void )
    NVIC_InitTypeDef NVIC_InitStructure;
    GPIO_InitTypeDef  GPIO_InitStructure;
    u8 clkdiv = 0;
    SD_Error errorstatus = SD_OK;
    RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOC |RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOD, ENABLE );
    RCC_AHBPeriphClockCmd( RCC_AHBPeriph_SDIO | RCC_AHBPeriph_DMA2, ENABLE );
    GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_10 | GPIO_Pin_11 | GPIO_Pin_12;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_Init( GPIOC, &GPIO_InitStructure );
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_14 | GPIO_Pin_15;
    GPIO_Init( GPIOB, &GPIO_InitStructure );
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
    GPIO_Init( GPIOD, &GPIO_InitStructure );
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
    GPIO_ResetBits(GPIOD, GPIO_Pin_4);
    SDIO_DeInit();
    NVIC_InitStructure.NVIC_IRQChannel = SDIO_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
    NVIC_Init( &NVIC_InitStructure );
    errorstatus = SD_PowerON();
    if( errorstatus == SD_OK )
        errorstatus = SD_InitializeCards();
        errorstatus = SD_GetCardInfo( &SDCardInfo );
        errorstatus = SD_SelectDeselect( ( u32 )( SDCardInfo.RCA << 16 ) );
        errorstatus = SD_EnableWideBusOperation( 1 );
    if( ( errorstatus == SD_OK ) || ( SDIO_MULTIMEDIA_CARD == CardType ) )
        if( SDCardInfo.CardType == SDIO_STD_CAPACITY_SD_CARD_V1_1 || SDCardInfo.CardType == SDIO_STD_CAPACITY_SD_CARD_V2_0 )
            clkdiv = SDIO_TRANSFER_CLK_DIV + 6;
        else
            clkdiv = SDIO_TRANSFER_CLK_DIV + 1;
        SDIO_Clock_Set( clkdiv );
        errorstatus = SD_SetDeviceMode( SD_POLLING_MODE );
    return errorstatus;
不知道为什么 会卡在 FindSCR 函数中
另外 一块 同样的电路板,直接CmdResp1Error,现象还不一样
能给点提示吗? 同时使用 10M Eth 和sd卡 ,可以吗?使用PB14,PB15作为 SDIO_D1,SDIO_D0, 有什么特殊要求吗?
检查了一遍电路,没有问题。  SDIO的布线有 等长要求吗?
您好,如下图,对于使用PB14和PB15作为SDIO D0和D1是有要求的,具体可看数据手册注7,此外注7描述的那几个寄存器对应位要进行使能和配置。
批号 31102FD12 , 倒数 第五位 是2, 也就是满足使用 PB14 PB15作为 SDIO引脚的条件。
只是 使用PB14 PB15 作为SDIO 引脚 时, 需要 ETHMACEN =1 ,才行。
 我测试一下
果然,在使能时钟时,增加RCC_AHBPeriph_ETH_MAC 就可以了。 多谢啦
RCC_AHBPeriphClockCmd( RCC_AHBPeriph_SDIO |RCC_AHBPeriph_ETH_MAC| RCC_AHBPeriph_DMA2, ENABLE );
