adc出现问题
程序如下,adc搬了论坛的liyanan用户的程序,程序是定时器中断中设置adc采集,
        DMA_Cmd(DMA1_Channel1, ENABLE);
        ADC_SoftwareStartConvCmd(ADC1, ENABLE);
        while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC));
        ADC_SoftwareStartConvCmd(ADC1, DISABLE);
        DMA_Cmd(DMA1_Channel1, DISABLE);
但如上程序在while中运行正常,采集正常,但我放在定时器中断中却无法采到ad值,一直停在 while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC));
中,为啥?如何修改?
#include "debug.h"
void TIM1_UP_IRQHandler(void) __attribute__((interrupt("WCH-Interrupt-fast")));
u16 TxBuf[3];//ad获取存储
void ADC_Function_Init(void)
    ADC_InitTypeDef  ADC_InitStructure = {0};
    GPIO_InitTypeDef GPIO_InitStructure = {0};
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD, ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
    RCC_ADCCLKConfig(RCC_PCLK2_Div8);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
    GPIO_Init(GPIOC, &GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
    GPIO_Init(GPIOD, &GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
    ADC_DeInit(ADC1);
    ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
    ADC_InitStructure.ADC_ScanConvMode = ENABLE;//多通道需要使能,扫描模式
    ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;//连续转换
    ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;//没有外部触发
    ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
    ADC_InitStructure.ADC_NbrOfChannel = 3;//转换三个通道
    ADC_Init(ADC1, &ADC_InitStructure);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 1, ADC_SampleTime_241Cycles);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_3, 2, ADC_SampleTime_241Cycles);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_4, 3, ADC_SampleTime_241Cycles);
    ADC_Calibration_Vol(ADC1, ADC_CALVOL_50PERCENT);
    ADC_DMACmd(ADC1, ENABLE);
    ADC_Cmd(ADC1, ENABLE);
    ADC_ResetCalibration(ADC1);
    while(ADC_GetResetCalibrationStatus(ADC1));
    ADC_StartCalibration(ADC1);
    while(ADC_GetCalibrationStatus(ADC1));
u16 Get_ADC_Val(u8 ch)
    u16 val;
    ADC_RegularChannelConfig(ADC1, ch, 1, ADC_SampleTime_241Cycles);
    val = ADC_GetConversionValue(ADC1);
    return val;
void DMA_Tx_Init(DMA_Channel_TypeDef *DMA_CHx, u32 ppadr, u32 memadr, u16 bufsize)
    DMA_InitTypeDef DMA_InitStructure = {0};
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
    DMA_DeInit(DMA_CHx);
    DMA_InitStructure.DMA_PeripheralBaseAddr = ppadr;
    DMA_InitStructure.DMA_MemoryBaseAddr = memadr;
    DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
    DMA_InitStructure.DMA_BufferSize = bufsize;
    DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
    DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
    DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
    DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
    DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
    DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh;
    DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
    DMA_Init(DMA_CHx, &DMA_InitStructure);
void TIM1_Int_Init(u16 arr,u16 psc)
    TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure={0};
    NVIC_InitTypeDef         NVIC_InitStructure={0};
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);       //使能TIM1时钟
    TIM_TimeBaseStructure.TIM_Period = arr;                    //指定下次更新事件时要加载到活动自动重新加载寄存器中的周期值。
    TIM_TimeBaseStructure.TIM_Prescaler =psc;                  //指定用于划分TIM时钟的预分频器值。
    TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;    //时钟分频因子
    TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;//TIM计数模式,向上计数模式
    TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
    TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);            //根据指定的参数初始化TIMx的时间基数单位
    //初始化TIM NVIC,设置中断优先级分组
    NVIC_InitStructure.NVIC_IRQChannel = TIM1_UP_IRQn;         //TIM1中断
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;  //设置抢占优先级0
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;         //设置响应优先级3
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;            //使能通道1中断
    NVIC_Init(&NVIC_InitStructure);                            //初始化NVIC
    TIM_ITConfig(TIM1,TIM_IT_Update,ENABLE ); //使能TIM1中断,允许更新中断
    TIM_Cmd(TIM1, ENABLE); //TIM1使能
int main(void)
    SystemCoreClockUpdate();
    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
    TIM1_Int_Init(100-1,720-1);
    ADC_Function_Init();
    DMA_Tx_Init(DMA1_Channel1, (u32)&ADC1->RDATAR, (u32)TxBuf,3);
    while(1)
    if(TIM_GetITStatus(TIM1, TIM_IT_Update) != RESET) //检查TIM1中断是否发生。
        TIM_ClearITPendingBit(TIM1,TIM_IT_Update);      //清除TIM1的中断挂起位。
您好,可将ADC初始化放在定时器初始化之前试一下
这个解决了,这个程序是要求每隔2ms采集一次三个通道的值,思路是在定时中断中设置标志位,while中执行adc采集,为判断
是否正常进入中断和采集,分别在中断和主程序ad后设置端口数出使用示波器查看波形,发现一个有意思的问题,在主程序中我将采集到的第一通道值依次赋给一数组a,发现波形很好,但如果我删掉此,却发现主程序执行就不正常了,按道理我删掉应该是节省了时间,程序如下(我没有删掉赋值a数组)
//定时器产生一次中断时间计算方式如下:
//T=(arr+1)*(psc+1)/Tpclk
//定时器计数一次的时间为:
//t=(psc+1)/Tpclk
//(1/1M)Hz=1us  (1/1K)Hz=1ms
#include "debug.h"
volatile u16 TxBuf[3];//ad获取存储
volatile u16 a[400];//ad获取存储
volatile u8 i=0;
volatile u8 c=0;
volatile u8 k=0;
volatile u8 w=0;
    ADC_DeInit(ADC1);
    u16 val;
    return val;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;         //设置响应优先级3
void GPIO_Toggle_INIT(void)
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_2;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
int main(void)
    TIM1_Int_Init(96-1,1000-1);
    GPIO_Toggle_INIT();
    while(1)
        if(k==1)
            a[i]=TxBuf[0];
            i++;
            GPIO_WriteBit(GPIOC, GPIO_Pin_2, (w == 0) ? (w = Bit_SET) : (w = Bit_RESET));
            k=0;
        k=1;
        if(c==0)
            GPIO_ResetBits(GPIOC, GPIO_Pin_1);
            c++;
        else
           GPIO_SetBits(GPIOC, GPIO_Pin_1) ;
           c=0;
但如果我删掉主程序赋值语句,
您好,下帖已回复
https://www.wch.cn/bbs/thread-126123-1.html
