CH583M Passkey pairing goes wrong
How to properly configure a connection to a device using a passkey? I set the settings when initializing BLE, as indicated in the screenshot. The GAPBOND_PAIRING_MODE_INITIATE mode is set, i.e. at the moment of connection, the device should immediately start bonding proccess and request a connection key on its own, but this does not happen and anyone can just connect, read the characteristics and work with them, for some reason they are not asked for a key and dont start the pairing proccess.
At the same time, the key that I installed is requested only when trying to manualy establish a bond but only after the connection has been
established, why is that? I tried to connect via smartphone using nrf connect and ble scanner
When the "GAPBondMgr_SetParameter(GAPBOND_PERI_BONDING_ENABLED, sizeof(uint8), &bonding);" is enabled pairing do not even started and bonding doesnt work.....And its looks like that the pairing proccess starting only after successfull connection when im manualy pressing the bond button in app, how can i fix that?
p.s.
On some phones everything happens fine and the password is requested immediately at the time of connection, strange
Solved the problem.
At first I tried to manually set read and write protection specifically for each characteristic using GATT_PERMIT_AUTHEN_READ, but in my project with this setting the characteristics stopped being read at all, so I did it differently:
I created a flag that is activated during the successful completion of bonding and allows you to read the characteristic only if this flag is present:
So to read characteristics you need always to start bonding which accompanied by passkey entering
