ch582 主从一体时 从机断连
大佬们好
硬件情况:现在手头两块开发板,板1做从机,运行例程的hid_kbd;板2做主从一体机,板2主机连接板1,板2从机运行hid_kbd,并被pc端连接。
遇到问题:当板2从机连接pc端后,开启板1,板2主机发现并连接板1,此时板2从机开始与pc端持续断开重连,一直报错reason13或8。附件上传失败,我在下面提供了板2主机的代码,请各位多多指点。
/********************************** (C) COPYRIGHT *******************************
* File Name          : central.c
* Author             : WCH
* Version            : V1.1
* Date               : 2020/08/06
* Description        : 主机例程,主动扫描周围设备,连接至给定的从机设备地址,
*                      寻找自定义服务及特征,执行读写命令,需与从机例程配合使用,
                       并将从机设备地址修改为该例程目标地址,默认为(84:C2:E4:03:02:02)
 * Copyright (c) 2021 Nanjing Qinheng Microelectronics Co., Ltd.
 * Attention: This software (modified or not) and binary are used for
 * microcontroller manufactured by Nanjing Qinheng Microelectronics.
 * INCLUDES
#include "CONFIG.h"
#include "gattprofile.h"
#include "central.h"
 * MACROS
// Length of bd addr as a string
#define B_ADDR_STR_LEN                      15
 * CONSTANTS
// Maximum number of scan responses
#define DEFAULT_MAX_SCAN_RES                10
// Scan duration in 0.625ms
#define DEFAULT_SCAN_DURATION               2400
// Connection min interval in 1.25ms
#define DEFAULT_MIN_CONNECTION_INTERVAL     20
// Connection max interval in 1.25ms
#define DEFAULT_MAX_CONNECTION_INTERVAL     100
// Connection supervision timeout in 10ms
#define DEFAULT_CONNECTION_TIMEOUT          100
// Discovey mode (limited, general, all)
#define DEFAULT_DISCOVERY_MODE              DEVDISC_MODE_ALL
// TRUE to use active scan
#define DEFAULT_DISCOVERY_ACTIVE_SCAN       TRUE
// TRUE to use white list during discovery
#define DEFAULT_DISCOVERY_WHITE_LIST        FALSE
// TRUE to use high scan duty cycle when creating link
#define DEFAULT_LINK_HIGH_DUTY_CYCLE        FALSE
// TRUE to use white list when creating link
#define DEFAULT_LINK_WHITE_LIST             FALSE
// Default read RSSI period in 0.625ms
#define DEFAULT_RSSI_PERIOD                 2400
// Minimum connection interval (units of 1.25ms)
#define DEFAULT_UPDATE_MIN_CONN_INTERVAL    20
// Maximum connection interval (units of 1.25ms)
#define DEFAULT_UPDATE_MAX_CONN_INTERVAL    100
// Slave latency to use parameter update
#define DEFAULT_UPDATE_SLAVE_LATENCY        0
// Supervision timeout value (units of 10ms)
#define DEFAULT_UPDATE_CONN_TIMEOUT         600
// Default passcode
#define DEFAULT_PASSCODE                    0
// Default GAP pairing mode
#define DEFAULT_PAIRING_MODE                GAPBOND_PAIRING_MODE_INITIATE
// Default MITM mode (TRUE to require passcode or OOB when pairing)
#define DEFAULT_MITM_MODE                   TRUE
// Default bonding mode, TRUE to bond, max bonding 6 devices
#define DEFAULT_BONDING_MODE                TRUE
// Default GAP bonding I/O capabilities
#define DEFAULT_IO_CAPABILITIES             GAPBOND_IO_CAP_NO_INPUT_NO_OUTPUT
// Default service discovery timer delay in 0.625ms
#define DEFAULT_SVC_DISCOVERY_DELAY         1600
// Default parameter update delay in 0.625ms
#define DEFAULT_PARAM_UPDATE_DELAY          3200
// Default phy update delay in 0.625ms
#define DEFAULT_PHY_UPDATE_DELAY            2400
// Default read or write timer delay in 0.625ms
#define DEFAULT_READ_OR_WRITE_DELAY         1600
// Default write CCCD delay in 0.625ms
#define DEFAULT_WRITE_CCCD_DELAY            1600
// Establish link timeout in 0.625ms
#define ESTABLISH_LINK_TIMEOUT              3200
// Application states
enum
    BLE_STATE_IDLE,
    BLE_STATE_CONNECTING,
    BLE_STATE_CONNECTED,
    BLE_STATE_DISCONNECTING
// Discovery states
enum
    BLE_DISC_STATE_IDLE, // Idle
    BLE_DISC_STATE_SVC,  // Service discovery
    BLE_DISC_STATE_CHAR, // Characteristic discovery
    BLE_DISC_STATE_CCCD  // client characteristic configuration discovery
 * TYPEDEFS
 * GLOBAL VARIABLES
 * EXTERNAL VARIABLES
 * EXTERNAL FUNCTIONS
 * LOCAL VARIABLES
// Task ID for internal task/event processing
static uint8_t centralTaskId;
// Number of scan results
static uint8_t centralScanRes;
// Scan result list
static gapDevRec_t centralDevList[DEFAULT_MAX_SCAN_RES];
// Peer device address
static uint8_t PeerAddrDef[B_ADDR_LEN] = {0x2c, 0x5a, 0x83, 0x7b, 0x54, 0xd0};
// RSSI polling state
static uint8_t centralRssi = FALSE;
// Parameter update state
static uint8_t centralParamUpdate = TRUE;
// Phy update state
static uint8_t centralPhyUpdate = FALSE;
// Connection handle of current connection
static uint16_t centralConnHandle = GAP_CONNHANDLE_INIT;
static uint8_t centralState = BLE_STATE_IDLE;
// Discovery state
static uint8_t centralDiscState = BLE_DISC_STATE_IDLE;
// Discovered service start and end handle
static uint16_t centralSvcStartHdl = 0;
static uint16_t centralSvcEndHdl = 0;
// Discovered characteristic handle
static uint16_t centralCharHdl = 0;
// Discovered Client Characteristic Configuration handle
static uint16_t centralCCCDHdl = 0;
// Value to write
static uint8_t centralCharVal = 0x5A;
// Value read/write toggle
static uint8_t centralDoWrite = TRUE;
// GATT read/write procedure state
static uint8_t centralProcedureInProgress = FALSE;
 * LOCAL FUNCTIONS
static void centralProcessGATTMsg(gattMsgEvent_t *pMsg);
static void centralRssiCB(uint16_t connHandle, int8_t rssi);
static void centralEventCB(gapRoleEvent_t *pEvent);
static void centralHciMTUChangeCB(uint16_t connHandle, uint16_t maxTxOctets, uint16_t maxRxOctets);
static void centralPasscodeCB(uint8_t *deviceAddr, uint16_t connectionHandle,
                              uint8_t uiInputs, uint8_t uiOutputs);
static void centralPairStateCB(uint16_t connHandle, uint8_t state, uint8_t status);
static void central_ProcessTMOSMsg(tmos_event_hdr_t *pMsg);
static void centralGATTDiscoveryEvent(gattMsgEvent_t *pMsg);
static void centralStartDiscovery(void);
static void centralAddDeviceInfo(uint8_t *pAddr, uint8_t addrType);
 * PROFILE CALLBACKS
// GAP Role Callbacks
static gapCentralRoleCB_t centralRoleCB = {
    centralRssiCB,        // RSSI callback
    centralEventCB,       // Event callback
    centralHciMTUChangeCB // MTU change callback
// Bond Manager Callbacks
static gapBondCBs_t centralBondCB = {
    centralPasscodeCB,
    centralPairStateCB
 * PUBLIC FUNCTIONS
 * @fn      Central_Init
 * @brief   Initialization function for the Central App Task.
 *          This is called during initialization and should contain
 *          any application specific initialization (ie. hardware
 *          initialization/setup, table initialization, power up
 *          notification).
 * @param   task_id - the ID assigned by TMOS.  This ID should be
 *                    used to send messages and set timers.
 * @return  none
void Central_Init()
    centralTaskId = TMOS_ProcessEventRegister(Central_ProcessEvent);
    // Setup GAP
    GAP_SetParamValue(TGAP_DISC_SCAN, DEFAULT_SCAN_DURATION);
    GAP_SetParamValue(TGAP_CONN_EST_INT_MIN, DEFAULT_MIN_CONNECTION_INTERVAL);
    GAP_SetParamValue(TGAP_CONN_EST_INT_MAX, DEFAULT_MAX_CONNECTION_INTERVAL);
    GAP_SetParamValue(TGAP_CONN_EST_SUPERV_TIMEOUT, DEFAULT_CONNECTION_TIMEOUT);
    // Setup the GAP Bond Manager
        uint32_t passkey = DEFAULT_PASSCODE;
        uint8_t  pairMode = DEFAULT_PAIRING_MODE;
        uint8_t  mitm = DEFAULT_MITM_MODE;
        uint8_t  ioCap = DEFAULT_IO_CAPABILITIES;
        uint8_t  bonding = DEFAULT_BONDING_MODE;
        GAPBondMgr_SetParameter(GAPBOND_CENT_DEFAULT_PASSCODE, sizeof(uint32_t), &passkey);
        GAPBondMgr_SetParameter(GAPBOND_CENT_PAIRING_MODE, sizeof(uint8_t), &pairMode);
        GAPBondMgr_SetParameter(GAPBOND_CENT_MITM_PROTECTION, sizeof(uint8_t), &mitm);
        GAPBondMgr_SetParameter(GAPBOND_CENT_IO_CAPABILITIES, sizeof(uint8_t), &ioCap);
        GAPBondMgr_SetParameter(GAPBOND_CENT_BONDING_ENABLED, sizeof(uint8_t), &bonding);
    // Initialize GATT Client
    GATT_InitClient();
    // Register to receive incoming ATT Indications/Notifications
    GATT_RegisterForInd(centralTaskId);
    // Setup a delayed profile startup
    tmos_set_event(centralTaskId, START_DEVICE_EVT);
 * @fn      Central_ProcessEvent
 * @brief   Central Application Task event processor.  This function
 *          is called to process all events for the task.  Events
 *          include timers, messages and any other user defined events.
 * @param   task_id  - The TMOS assigned task ID.
 * @param   events - events to process.  This is a bit map and can
 *                   contain more than one event.
 * @return  events not processed
uint16_t Central_ProcessEvent(uint8_t task_id, uint16_t events)
    if(events & SYS_EVENT_MSG)
        uint8_t *pMsg;
        if((pMsg = tmos_msg_receive(centralTaskId)) != NULL)
            central_ProcessTMOSMsg((tmos_event_hdr_t *)pMsg);
            // Release the TMOS message
            tmos_msg_deallocate(pMsg);
        // return unprocessed events
        return (events ^ SYS_EVENT_MSG);
    if(events & START_DEVICE_EVT)
        // Start the Device
        GAPRole_CentralStartDevice(centralTaskId, &centralBondCB, &centralRoleCB);
        return (events ^ START_DEVICE_EVT);
    if(events & ESTABLISH_LINK_TIMEOUT_EVT)
        GAPRole_TerminateLink(INVALID_CONNHANDLE);
        return (events ^ ESTABLISH_LINK_TIMEOUT_EVT);
    if(events & START_SVC_DISCOVERY_EVT)
        // start service discovery
        centralStartDiscovery();
        return (events ^ START_SVC_DISCOVERY_EVT);
    if(events & START_PARAM_UPDATE_EVT)
        // start connect parameter update
        GAPRole_UpdateLink(centralConnHandle,
                           DEFAULT_UPDATE_MIN_CONN_INTERVAL,
                           DEFAULT_UPDATE_MAX_CONN_INTERVAL,
                           DEFAULT_UPDATE_SLAVE_LATENCY,
                           DEFAULT_UPDATE_CONN_TIMEOUT);
        return (events ^ START_PARAM_UPDATE_EVT);
    if(events & START_PHY_UPDATE_EVT)
        // start phy update
        PRINT("PHY Update %x...\n", GAPRole_UpdatePHY(centralConnHandle, 0,
                    GAP_PHY_BIT_LE_2M, GAP_PHY_BIT_LE_2M, GAP_PHY_OPTIONS_NOPRE));
        return (events ^ START_PHY_UPDATE_EVT);
    if(events & START_READ_OR_WRITE_EVT)
        if(centralProcedureInProgress == FALSE)
            if(centralDoWrite)
                // Do a write
                attWriteReq_t req;
                req.cmd = FALSE;
                req.sig = FALSE;
                req.handle = centralCharHdl;
                req.len = 1;
                req.pValue = GATT_bm_alloc(centralConnHandle, ATT_WRITE_REQ, req.len, NULL, 0);
                if(req.pValue != NULL)
                    *req.pValue = centralCharVal;
                    if(GATT_WriteCharValue(centralConnHandle, &req, centralTaskId) == SUCCESS)
                        centralProcedureInProgress = TRUE;
                        centralDoWrite = !centralDoWrite;
                        tmos_start_task(centralTaskId, START_READ_OR_WRITE_EVT, DEFAULT_READ_OR_WRITE_DELAY);
                    else
                        GATT_bm_free((gattMsg_t *)&req, ATT_WRITE_REQ);
            else
                // Do a read
                attReadReq_t req;
                if(GATT_ReadCharValue(centralConnHandle, &req, centralTaskId) == SUCCESS)
        return (events ^ START_READ_OR_WRITE_EVT);
    if(events & START_WRITE_CCCD_EVT)
            // Do a write
            attWriteReq_t req;
            req.cmd = FALSE;
            req.sig = FALSE;
            req.handle = 0x0039;
            PRINT("start_write_cccd: %#x\n",req.handle);
            req.len = 2;
                req.pValue[0] = 1;
                req.pValue[1] = 0;
                else
        return (events ^ START_WRITE_CCCD_EVT);
    if(events & START_READ_RSSI_EVT)
        GAPRole_ReadRssiCmd(centralConnHandle);
        tmos_start_task(centralTaskId, START_READ_RSSI_EVT, DEFAULT_RSSI_PERIOD);
        return (events ^ START_READ_RSSI_EVT);
    // Discard unknown events
    return 0;
 * @fn      central_ProcessTMOSMsg
 * @brief   Process an incoming task message.
 * @param   pMsg - message to process
 * @return  none
    switch(pMsg->event)
        case GATT_MSG_EVENT:
            centralProcessGATTMsg((gattMsgEvent_t *)pMsg);
            break;
 * @fn      centralProcessGATTMsg
 * @brief   Process GATT messages
 * @return  none
    if(centralState != BLE_STATE_CONNECTED)
        // In case a GATT message came after a connection has dropped,
        // ignore the message
        GATT_bm_free(&pMsg->msg, pMsg->method);
        return;
    if((pMsg->method == ATT_EXCHANGE_MTU_RSP) ||
       ((pMsg->method == ATT_ERROR_RSP) &&
        (pMsg->msg.errorRsp.reqOpcode == ATT_EXCHANGE_MTU_REQ)))
        if(pMsg->method == ATT_ERROR_RSP)
            uint8_t status = pMsg->msg.errorRsp.errCode;
            PRINT("Exchange MTU Error: %x\n", status);
    if(pMsg->method == ATT_MTU_UPDATED_EVENT)
        PRINT("MTU: %d\n", pMsg->msg.mtuEvt.MTU);
    if((pMsg->method == ATT_READ_RSP) ||
        (pMsg->msg.errorRsp.reqOpcode == ATT_READ_REQ)))
            PRINT("Read Error: %x\n", status);
        else
            // After a successful read, display the read value
            PRINT("Read rsp: %x\n", *pMsg->msg.readRsp.pValue);
    else if((pMsg->method == ATT_WRITE_RSP) ||
             (pMsg->msg.errorRsp.reqOpcode == ATT_WRITE_REQ)))
            PRINT("Write Error: %x\n", status);
        else
            // Write success
            PRINT("Write success \n");
    else if(pMsg->method == ATT_HANDLE_VALUE_NOTI)
//        PRINT("Receive noti: %#x\n", pMsg->msg.handleValueNoti.pValue);
        PRINT("Receive noti:");
        for (int i = 0; i < 8; i++) {
            if(i) PRINT(" ");
            PRINT("%#x", pMsg->msg.handleValueNoti.pValue[i]);
        PRINT("]\n");
    else if(centralDiscState != BLE_DISC_STATE_IDLE)
        centralGATTDiscoveryEvent(pMsg);
 * @fn      centralRssiCB
 * @brief   RSSI callback.
 * @param   connHandle - connection handle
 * @param   rssi - RSSI
 * @return  none
    PRINT("RSSI : -%d dB \n", -rssi);
 * @fn      centralHciMTUChangeCB
 * @brief   MTU changed callback.
 * @param   maxTxOctets - Max tx octets
 * @param   maxRxOctets - Max rx octets
 * @return  none
    PRINT(" HCI data length changed, Tx: %d, Rx: %d\n", maxTxOctets, maxRxOctets);
 * @fn      centralEventCB
 * @brief   Central event callback function.
 * @param   pEvent - pointer to event structure
 * @return  none
    switch(pEvent->gap.opcode)
        case GAP_DEVICE_INIT_DONE_EVENT:
            PRINT("Discovering...\n");
            GAPRole_CentralStartDiscovery(DEFAULT_DISCOVERY_MODE,
                                          DEFAULT_DISCOVERY_ACTIVE_SCAN,
                                          DEFAULT_DISCOVERY_WHITE_LIST);
        break;
        case GAP_DEVICE_INFO_EVENT:
            // Add device to list
            centralAddDeviceInfo(pEvent->deviceInfo.addr, pEvent->deviceInfo.addrType);
        break;
        case GAP_DEVICE_DISCOVERY_EVENT:
            uint8_t i;
            // See if peer device has been discovered
            for(i = 0; i < centralScanRes; i++)
                if(tmos_memcmp(PeerAddrDef, centralDevList[i].addr, B_ADDR_LEN))
                    break;
            // Peer device not found
            if(i == centralScanRes)
                PRINT("Device not found...\n");
                centralScanRes = 0;
            // Peer device found
            else
                PRINT("Device found...\n");
                GAPRole_CentralEstablishLink(DEFAULT_LINK_HIGH_DUTY_CYCLE,
                                             DEFAULT_LINK_WHITE_LIST,
                                             centralDevList[i].addrType,
                                             centralDevList[i].addr);
                // Start establish link timeout event
                tmos_start_task(centralTaskId, ESTABLISH_LINK_TIMEOUT_EVT, ESTABLISH_LINK_TIMEOUT);
                PRINT("Connecting...\n");
        break;
        case GAP_LINK_ESTABLISHED_EVENT:
            tmos_stop_task(centralTaskId, ESTABLISH_LINK_TIMEOUT_EVT);
            if(pEvent->gap.hdr.status == SUCCESS)
                centralState = BLE_STATE_CONNECTED;
                centralConnHandle = pEvent->linkCmpl.connectionHandle;
                // Update MTU
                attExchangeMTUReq_t req = {
                    .clientRxMTU = BLE_BUFF_MAX_LEN - 4,
                GATT_ExchangeMTU(centralConnHandle, &req, centralTaskId);
                // Initiate service discovery
                tmos_start_task(centralTaskId, START_SVC_DISCOVERY_EVT, DEFAULT_SVC_DISCOVERY_DELAY);
                // See if initiate connect parameter update
                if(centralParamUpdate)
                    tmos_start_task(centralTaskId, START_PARAM_UPDATE_EVT, DEFAULT_PARAM_UPDATE_DELAY);
                // See if initiate phy update
                if(centralPhyUpdate)
                    tmos_start_task(centralTaskId, START_PHY_UPDATE_EVT, DEFAULT_PHY_UPDATE_DELAY);
                // See if start RSSI polling
                if(centralRssi)
                PRINT("Connected...\n");
            else
                PRINT("Connect Failed...Reason:%X\n", pEvent->gap.hdr.status);
                centralScanRes = 0;
        break;
        case GAP_LINK_TERMINATED_EVENT:
            centralCharHdl = 0;
            centralScanRes = 0;
            tmos_stop_task(centralTaskId, START_READ_RSSI_EVT);
            PRINT("Disconnected...Reason:%x\n", pEvent->linkTerminate.reason);
        break;
        case GAP_LINK_PARAM_UPDATE_EVENT:
            PRINT("Param Update...\n");
        break;
        case GAP_PHY_UPDATE_EVENT:
            PRINT("PHY Update...\n");
        break;
        case GAP_EXT_ADV_DEVICE_INFO_EVENT:
            // Display device addr
            PRINT("Recv ext adv \n");
            centralAddDeviceInfo(pEvent->deviceExtAdvInfo.addr, pEvent->deviceExtAdvInfo.addrType);
        break;
        case GAP_DIRECT_DEVICE_INFO_EVENT:
            PRINT("Recv direct adv \n");
            centralAddDeviceInfo(pEvent->deviceDirectInfo.addr, pEvent->deviceDirectInfo.addrType);
        break;
        default:
            break;
 * @fn      pairStateCB
 * @brief   Pairing state callback.
 * @return  none
    if(state == GAPBOND_PAIRING_STATE_STARTED)
        PRINT("Pairing started:%d\n", status);
    else if(state == GAPBOND_PAIRING_STATE_COMPLETE)
        if(status == SUCCESS)
            PRINT("Pairing success\n");
        else
            PRINT("Pairing fail\n");
    else if(state == GAPBOND_PAIRING_STATE_BONDED)
            PRINT("Bonding success\n");
    else if(state == GAPBOND_PAIRING_STATE_BOND_SAVED)
            PRINT("Bond save success\n");
        else
            PRINT("Bond save failed: %d\n", status);
 * @fn      centralPasscodeCB
 * @brief   Passcode callback.
 * @return  none
    uint32_t passcode;
    // Create random passcode
    passcode = tmos_rand();
    passcode %= 1000000;
    // Display passcode to user
    if(uiOutputs != 0)
        PRINT("Passcode:%06d\n", (int)passcode);
    // Send passcode response
    GAPBondMgr_PasscodeRsp(connectionHandle, SUCCESS, passcode);
 * @fn      centralStartDiscovery
 * @brief   Start service discovery.
 * @return  none
    centralSvcStartHdl = centralSvcEndHdl = centralCharHdl = 0;
    centralDiscState = BLE_DISC_STATE_SVC;
    uint8_t ret = 0;
    ret = GATT_DiscAllPrimaryServices(centralConnHandle, centralTaskId);
    printf("GATT_DiscAllPrimaryServices ret = %x\n", ret);
 * @fn      centralGATTDiscoveryEvent
 * @brief   Process GATT discovery event
 * @return  none
    attReadByTypeReq_t req;
    if(centralDiscState == BLE_DISC_STATE_SVC)
        // Service found, store handles
        if(pMsg->method == ATT_READ_BY_GRP_TYPE_RSP &&//ATT_FIND_BY_TYPE_VALUE_RSP &&
           pMsg->msg.findByTypeValueRsp.numInfo > 0)
#if 0
            for(uint16_t i = 0; i < pMsg->msg.readByGrpTypeRsp.numGrps; i++)
              // uuid
              printf("uuid = %x", BUILD_UINT16(
                  pMsg->msg.readByGrpTypeRsp.pDataList[pMsg->msg.readByGrpTypeRsp.len * i +4], \
                  pMsg->msg.readByGrpTypeRsp.pDataList[pMsg->msg.readByGrpTypeRsp.len * i +5]));
              //Primary Service UUID Length
              printf("%02d bit x",pMsg->msg.readByGrpTypeRsp.len - 4);
              // printf("att len = %d\n", pMsg->msg.readByGrpTypeRsp.len);
              printf("start handle:%04x",BUILD_UINT16(
                          pMsg->msg.readByGrpTypeRsp.pDataList[pMsg->msg.readByGrpTypeRsp.len * i],\
                          pMsg->msg.readByGrpTypeRsp.pDataList[pMsg->msg.readByGrpTypeRsp.len * i +1]));
              // Attribute End Group Handle
              printf("end handle:%04x\r\n",BUILD_UINT16(
                          pMsg->msg.readByGrpTypeRsp.pDataList[pMsg->msg.readByGrpTypeRsp.len * i +2], \
                          pMsg->msg.readByGrpTypeRsp.pDataList[pMsg->msg.readByGrpTypeRsp.len * i +3]));
#endif
        if((pMsg->method == ATT_READ_BY_GRP_TYPE_RSP &&
            pMsg->hdr.status == bleProcedureComplete) ||
           (pMsg->method == ATT_ERROR_RSP))
            // Discover characteristic
            centralDiscState = BLE_DISC_STATE_CHAR;
            uint8_t ret = GATT_DiscAllChars(centralConnHandle,0x01,0xFFFF,centralTaskId);
            PRINT("GATT_DiscAllChars:%02x\r\n",ret);
    else if(centralDiscState == BLE_DISC_STATE_CHAR)
        // Characteristic found, store handle
        if(pMsg->method == ATT_READ_BY_TYPE_RSP &&
           pMsg->msg.readByTypeRsp.numPairs > 0)
            for(unsigned char i = 0; i < pMsg->msg.readByTypeRsp.numPairs ; i++) {
                //characteristic properties
                uint8_t char_properties = pMsg->msg.readByTypeRsp.pDataList[pMsg->msg.readByTypeRsp.len * i + 2];
                uint16_t char_value_handle = BUILD_UINT16(pMsg->msg.readByTypeRsp.pDataList[pMsg->msg.readByTypeRsp.len * i+3], \
                                             pMsg->msg.readByTypeRsp.pDataList[pMsg->msg.readByTypeRsp.len * i + 4]);
                //characteristic uuid length
                uint8_t char_uuid_length = pMsg->msg.readByGrpTypeRsp.len - 5;
                //uuid
                uint8_t *char_uuid = &(pMsg->msg.readByGrpTypeRsp.pDataList[pMsg->msg.readByGrpTypeRsp.len * i + 5]);
                PRINT("______________________________\n");
                if(char_properties&GATT_PROP_NOTIFY) {
                    centralCCCDHdl = char_value_handle+1;                //通过GATT_DiscAllChars或者handle,noti/indi的handle值需要+1
                    PRINT("Notify handle:%04x\r\n",char_value_handle);
                    PRINT("cccd handle:%04x\r\n",centralCCCDHdl);
                    if (centralCCCDHdl == 0x0039)
                        tmos_start_task(centralTaskId, START_WRITE_CCCD_EVT, 1600);
 * @fn      centralAddDeviceInfo
 * @brief   Add a device to the device discovery result list
 * @return  none
    uint8_t i;
    // If result count not at max
    if(centralScanRes < DEFAULT_MAX_SCAN_RES)
        // Check if device is already in scan results
            if(tmos_memcmp(pAddr, centralDevList[i].addr, B_ADDR_LEN))
                return;
        // Add addr to scan result list
        tmos_memcpy(centralDevList[centralScanRes].addr, pAddr, B_ADDR_LEN);
        centralDevList[centralScanRes].addrType = addrType;
        // Increment scan result count
        centralScanRes++;
/************************ endfile @ central **************************/
