CH32F205 USBFS配置为Device 但是不管如何转发描述符到USB端点 都是让鼠标往右移动
CH32F205 两个usb 一个配置为主机 一个配置为HID设备 主机接收HID设备数据 然后通过从机USB端口 转发给PC
这是主函数设置
int main( void )
    /* Initialize system configuration */
    Delay_Init( );
    USART_Printf_Init( 115200 );
    DUG_PRINTF( "SystemClk:%d\r\n", SystemCoreClock );
    DUG_PRINTF( "USB HOST KM Test\r\n" );
    /* Initialize TIM3 */
    TIM3_Init( 9, SystemCoreClock / 10000 - 1 );
    DUG_PRINTF( "TIM3 Init OK!\r\n" );
    /* Initialize USBHS host */
    /* Note: Only CH32F205/CH32F207 support USB high-speed port. */
#if DEF_USBHS_PORT_EN
    DUG_PRINTF( "USBHS Host Init\r\n" );
    USBHS_RCC_Init( );
    USBHS_Host_Init( ENABLE );
    memset( &RootHubDev[ DEF_USBHS_PORT_INDEX ].bStatus, 0, sizeof( ROOT_HUB_DEVICE ) );
    memset( &HostCtl[ DEF_USBHS_PORT_INDEX * DEF_ONE_USB_SUP_DEV_TOTAL ].InterfaceNum, 0, DEF_ONE_USB_SUP_DEV_TOTAL * sizeof( HOST_CTL ) );
#endif
    /* Initialize USBFS host */
#if DEF_USBFS_PORT_EN
    DUG_PRINTF( "USBFS Host Init\r\n" );
//    USBFS_RCC_Init( );
//    USBFS_Host_Init( ENABLE );
    USBFS_RCC_Init( );
     USBFS_Device_Init( ENABLE );
     DUG_PRINTF(" < - USB DEVCIE INIT OK - > \r\n");
    memset( &RootHubDev[ DEF_USBFS_PORT_INDEX ].bStatus, 0, sizeof( ROOT_HUB_DEVICE ) );
    memset( &HostCtl[ DEF_USBFS_PORT_INDEX * DEF_ONE_USB_SUP_DEV_TOTAL ].InterfaceNum, 0, DEF_ONE_USB_SUP_DEV_TOTAL * sizeof( HOST_CTL ) );
#endif
    while( 1 )
        USBH_MainDeal( );
这是USBH_MainDeal 函数里获取到描述符的部分 不管我接入键盘还是鼠标 都是鼠标一直往右移动
/* Get the data of the HID device connected to the USB host port */
    for( usb_port = 0; usb_port < DEF_TOTAL_ROOT_HUB; usb_port++ )
        if( RootHubDev[ usb_port ].bStatus >= ROOT_DEV_SUCCESS )
            index = RootHubDev[ usb_port ].DeviceIndex;
            if( RootHubDev[ usb_port ].bType == USB_DEV_CLASS_HID )
                for( intf_num = 0; intf_num < HostCtl[ index ].InterfaceNum; intf_num++ )
                    for( in_num = 0; in_num < HostCtl[ index ].Interface[ intf_num ].InEndpNum; in_num++ )
                        /* Get endpoint data based on the interval time of the device */
                        if( HostCtl[ index ].Interface[ intf_num ].InEndpTimeCount[ in_num ] >= HostCtl[ index ].Interface[ intf_num ].InEndpInterval[ in_num ] )
                            HostCtl[ index ].Interface[ intf_num ].InEndpTimeCount[ in_num ] %= HostCtl[ index ].Interface[ intf_num ].InEndpInterval[ in_num ];
                            /* Get endpoint data */
                            s = USBH_GetHidData( usb_port, index, intf_num, in_num, Com_Buf, &len );
                            if( s == ERR_SUCCESS )
#if DEF_DEBUG_PRINTF
                                for( i = 0; i < len; i++ )
                                    DUG_PRINTF( "%02x ", Com_Buf[ i ] );
                                DUG_PRINTF( "\r\n" );
#endif
int8_t x_move = (int8_t)Com_Buf[1]; // X 位移
int8_t y_move = (int8_t)Com_Buf[2]; // Y 位移
int8_t wheel_move = (int8_t)Com_Buf[3]; // 滚轮位移
DUG_PRINTF("Mouse Move: X=%d, Y=%d, Wheel=%d\r\n", x_move, y_move, wheel_move);
// 上传数据到端点
DUG_PRINTF("Uploading Data: %02x %02x %02x %02x\r\n", Com_Buf[0], Com_Buf[1], Com_Buf[2], Com_Buf[3]);
uint8_t report_len = 4; // HID 描述符定义了 4 字节
if (USBFS_Endp_DataUp(endp, Com_Buf, report_len, DEF_UEP_DMA_LOAD) == READY) {
DUG_PRINTF("Mouse Data Uploaded to Endpoint %d\r\n", endp);
} else {
DUG_PRINTF("Mouse Data Upload Failed!\r\n");
然后串口的打印数据一直是往一个方向累加
SystemClk:96000000
USB HOST KM Test
TIM3 Init OK!
USBHS Host Init
USBFS Host Init
USB Port1 Dev In.
Enum:
Get DevDesc: 12 01 10 01 00 00 00 08 4f 1c 34 00 10 01 01 02 00 01
Set DevAddr: OK
Get CfgDesc: 09 02 22 00 01 01 00 a0 32 09 04 00 00 01 03 01 02 00 09 21 10 01 00 01 22 34 00 07 05 81 03 04 00 0a
DevType: 03
Set Cfg: OK
Root Device Is HID. Enum Hid:
Analyze CfgDesc: OK
Get Interface0 RepDesc: HID Descriptor:
05 01 09 02 a1 01 09 01 a1 00 05 09 19 01 29 03 15 00 25 01 95 03 75 01 81 02 95 01 75 05 81 01 05 01 09 30 09 31 09 38 15 81 25 7f 75 08 95 03 81 06 c0 c0
Get StringDesc1: 14 03 53 00 49 00 47 00 4d 00 41 00 43 00 48 00 49 00 50 00
Get StringDesc2: 14 03 55 00 73 00 62 00 20 00 4d 00 6f 00 75 00 73 00 65 00
Further Enum Result: OK
00 00 00 00
Mouse Move: X=0, Y=0, Wheel=0
Uploading Data: 00 00 00 00
Mouse Data Uploaded to Endpoint 2
00 01 00 00
00 01 ff 00
Mouse Move: X=1, Y=-1, Wheel=0
Uploading Data: 00 01 ff 00
00 01 ff 00
00 02 00 00
Mouse Move: X=2, Y=0, Wheel=0
Uploading Data: 00 02 00 00
00 03 ff 00
Mouse Move: X=3, Y=-1, Wheel=0
Uploading Data: 00 03 ff 00
00 05 00 00
Mouse Move: X=5, Y=0, Wheel=0
Uploading Data: 00 05 00 00
00 06 00 00
Mouse Move: X=6, Y=0, Wheel=0
Uploading Data: 00 06 00 00
00 04 00 00
Mouse Move: X=4, Y=0, Wheel=0
Uploading Data: 00 04 00 00
00 02 00 00
00 05 fe 00
Mouse Move: X=5, Y=-2, Wheel=0
Uploading Data: 00 05 fe 00
00 09 fc 00
Mouse Move: X=9, Y=-4, Wheel=0
Uploading Data: 00 09 fc 00
00 06 fe 00
Mouse Move: X=6, Y=-2, Wheel=0
Uploading Data: 00 06 fe 00
00 06 ff 00
Mouse Move: X=6, Y=-1, Wheel=0
Uploading Data: 00 06 ff 00
00 05 ff 00
Mouse Move: X=5, Y=-1, Wheel=0
Uploading Data: 00 05 ff 00
00 06 fe 00
00 09 ff 00
Mouse Move: X=9, Y=-1, Wheel=0
Uploading Data: 00 09 ff 00
00 09 fe 00
Mouse Move: X=9, Y=-2, Wheel=0
Uploading Data: 00 09 fe 00
00 0a 00 00
Mouse Move: X=10, Y=0, Wheel=0
Uploading Data: 00 0a 00 00
00 09 fe 00
00 09 fd 00
Mouse Move: X=9, Y=-3, Wheel=0
Uploading Data: 00 09 fd 00
00 09 fe 00
00 0a fd 00
Mouse Move: X=10, Y=-3, Wheel=0
Uploading Data: 00 0a fd 00
00 0a fd 00
00 0a fd 00
00 0a ff 00
Mouse Move: X=10, Y=-1, Wheel=0
Uploading Data: 00 0a ff 00
00 0a 00 00
00 08 ff 00
Mouse Move: X=8, Y=-1, Wheel=0
Uploading Data: 00 08 ff 00
00 06 00 00
00 05 ff 00
00 03 ff 00
00 ff 00 00
Mouse Move: X=-1, Y=0, Wheel=0
Uploading Data: 00 ff 00 00
00 fd 01 00
Mouse Move: X=-3, Y=1, Wheel=0
Uploading Data: 00 fd 01 00
00 f6 01 00
Mouse Move: X=-10, Y=1, Wheel=0
Uploading Data: 00 f6 01 00
00 ee 01 00
Mouse Move: X=-18, Y=1, Wheel=0
Uploading Data: 00 ee 01 00
00 e9 00 00
Mouse Move: X=-23, Y=0, Wheel=0
Uploading Data: 00 e9 00 00
00 e7 00 00
Mouse Move: X=-25, Y=0, Wheel=0
Uploading Data: 00 e7 00 00
00 e9 ff 00
Mouse Move: X=-23, Y=-1, Wheel=0
Uploading Data: 00 e9 ff 00
00 eb fd 00
Mouse Move: X=-21, Y=-3, Wheel=0
Uploading Data: 00 eb fd 00
00 ed fc 00
Mouse Move: X=-19, Y=-4, Wheel=0
Uploading Data: 00 ed fc 00
00 ef fc 00
Mouse Move: X=-17, Y=-4, Wheel=0
Uploading Data: 00 ef fc 00
00 ee fb 00
Mouse Move: X=-18, Y=-5, Wheel=0
Uploading Data: 00 ee fb 00
00 ed fb 00
Mouse Move: X=-19, Y=-5, Wheel=0
Uploading Data: 00 ed fb 00
00 eb fb 00
Mouse Move: X=-21, Y=-5, Wheel=0
Uploading Data: 00 eb fb 00
00 e9 fc 00
Mouse Move: X=-23, Y=-4, Wheel=0
Uploading Data: 00 e9 fc 00
00 eb fb 00
00 eb fd 00
00 eb fe 00
Mouse Move: X=-21, Y=-2, Wheel=0
Uploading Data: 00 eb fe 00
00 ef fd 00
Mouse Move: X=-17, Y=-3, Wheel=0
Uploading Data: 00 ef fd 00
00 f2 fe 00
Mouse Move: X=-14, Y=-2, Wheel=0
Uploading Data: 00 f2 fe 00
00 f4 ff 00
您好,按照你的描述,你是不是想实现一个类似HUB的功能,或者说仅是想通过主机口获取连接鼠标的数据,然后通过设备口连接电脑实现鼠标的功能。若仅是想要实现鼠标的功能,建议设备端改成模拟鼠标设备,可以使用bushound抓一下你鼠标的枚举过程,然后根据其修改一下HID设备的描述符,模拟成具体的鼠标设备,然后再将主机抓取的设备通过设备端口上传电脑实现鼠标功能。后续若有问题,可以邮箱(lzs@wch.cn)和我沟通。
您好 (通过主机口获取连接键鼠的数据,然后通过设备口连接电脑实现键鼠的功能)这个问题 我已经解决了
只连接一个鼠标 或者 换成 一个键盘 可以被主机识别并且转发数据到PC
但是我用一个HUB连接主机 只能识别到HUB设备 无法正确枚举连接在HUB上的鼠标或者键盘
/* Get HUB port HID device data */
                for( hub_port = 0; hub_port < RootHubDev[ usb_port ].bPortNum; hub_port++ )
                    if( RootHubDev[ usb_port ].Device[ hub_port ].bStatus == ROOT_DEV_SUCCESS )
                        index = RootHubDev[ usb_port ].Device[ hub_port ].DeviceIndex;
                        if( RootHubDev[ usb_port ].Device[ hub_port ].bType == USB_DEV_CLASS_HID )
                                        /* Select HUB device port */
                                        USBFSH_SetSelfAddr( RootHubDev[ usb_port ].Device[ hub_port ].bAddress );
                                        USBFSH_SetSelfSpeed( RootHubDev[ usb_port ].Device[ hub_port ].bSpeed );
                                        if( RootHubDev[ usb_port ].bSpeed != USB_LOW_SPEED )
                                            USBFSH->HOST_CTRL &= ~USBFS_UH_LOW_SPEED;
#endif
if (HostCtl[index].Interface[intf_num].Type == DEC_MOUSE)
/* Forward mouse data */
int8_t btn = (int8_t)Com_Buf[0];    // Buttons
int8_t x_move = (int8_t)Com_Buf[1]; // X movement
int8_t y_move = (int8_t)Com_Buf[2]; // Y movement
int8_t wheel_move = (int8_t)Com_Buf[3]; // Wheel movement
DUG_PRINTF("Hub Mouse Data: btn=%d, X=%d, Y=%d, Wheel=%d\r\n", btn, x_move, y_move, wheel_move);
if (USBFS_Endp_DataUp(endp_mouse, Com_Buf, len, DEF_UEP_CPY_LOAD) == READY)
DUG_PRINTF("Hub Mouse Data Uploaded to Endpoint %d\r\n", endp_mouse);
else
DUG_PRINTF("Hub Mouse Data Upload Failed!\r\n");
else if (HostCtl[index].Interface[intf_num].Type == DEC_KEY)
/* Forward keyboard data */
DUG_PRINTF("Hub Keyboard Data: ");
for (i = 0; i < len; i++)
DUG_PRINTF("%02x ", Com_Buf[i]);
DUG_PRINTF("\r\n");
if (USBFS_Endp_DataUp(endp_keyboard, Com_Buf, len, DEF_UEP_CPY_LOAD) == READY)
DUG_PRINTF("Hub Keyboard Data Uploaded to Endpoint %d\r\n", endp_keyboard);
else
DUG_PRINTF("Hub Keyboard Data Upload Failed!\r\n");
                                            if( HostCtl[ index ].Interface[ intf_num ].Type == DEC_KEY )
                                                KB_AnalyzeKeyValue( index, intf_num, Com_Buf, len );
                                                if( HostCtl[ index ].Interface[ intf_num ].SetReport_Flag )
                                                    KB_SetReport( usb_port, index, RootHubDev[ usb_port ].Device[ hub_port ].bEp0MaxPks, intf_num );
                                        else if( s == ERR_USB_DISCON )
                                            break;
                                    break;
#endif
然后串口的打印也只显示 HUB-Device
SystemClk:96000000
USB HOST KM Test
TIM3 Init OK!
USBHS Host Init
USB Port1 Dev Out.
USB Port1 Dev In.
Enum:
Get DevDesc: 12 01 10 02 09 00 01 40 e3 05 10 06 56 06 01 02 00 01
Set DevAddr: OK
Get CfgDesc: 09 02 19 00 01 01 00 e0 32 09 04 00 00 01 09 00 00 00 07 05 81 03 01 00 0c
DevType: 09
Set Cfg: OK
Root Device Is HUB. Enum Hub:
Analyze CfgDesc: OK
Get StringDesc1: 1a 03 47 00 65 00 6e 00 65 00 73 00 79 00 73 00 4c 00 6f 00 67 00 69 00 63 00
Get StringDesc2: 16 03 55 00 53 00 42 00 32 00 2e 00 31 00 20 00 48 00 75 00 62 00
Get Hub Desc: 09 29 04 e0 00 32 64 00 ff
RootHubDev[ 01 ].bPortNum: 04
Port Power Status: 00
