点击烧录下方的OPENOCD就出现这个错误,请问应该修改什么地方?应该怎样修改?
CH585: 集成高速USB和NFC的蓝牙MCU
把烧录命令发下,最好是先用WCH-LinkUtility测试下能不能下载,这个应该是没找到link,正常找不到单片机会提示
Info : only one transport option; autoselect 'sdi'
Warn : Transport "sdi" was already selected
Ready for Remote Connections
Info : WCH-LinkW mode:RV version 2.13
Error: WCH-Link failed to connect with riscvchip
Error: 1.Make sure the two-line debug interface has been opened.
