在虚拟机可以正常运行官网提供的 openocd 工具,但是将其移动到docker环境后,和主机共享设备。Docker 内 lsusb 可以识别出来usb设备
qomolink@c6b6d755ebf5:/tools/MRS_Toolchain_Linux_x64_V1.92.1/beforeinstall$ lsusb Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 003: ID 1a86:8010 QinHeng Electronics Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
但是详细展示出来的话就感觉缺少了一些东西
qomolink@c6b6d755ebf5:/tools/MRS_Toolchain_Linux_x64_V1.92.1/beforeinstall$ lsusb -s 001:003 -v Bus 001 Device 003: ID 1a86:8010 QinHeng Electronics Couldn't open device, some information will be missing Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 1.10 bDeviceClass 239 Miscellaneous Device bDeviceSubClass 2 ? bDeviceProtocol 1 Interface Association bMaxPacketSize0 64 idVendor 0x1a86 QinHeng Electronics idProduct 0x8010 bcdDevice 2.12 iManufacturer 1 iProduct 2 iSerial 3 bNumConfigurations 1 Configuration Descriptor: bLength 9 bDescriptorType 2 wTotalLength 120 bNumInterfaces 3 bConfigurationValue 1 iConfiguration 0 bmAttributes 0x80 (Bus Powered) MaxPower 100mA Interface Association: bLength 8 bDescriptorType 11 bFirstInterface 0 bInterfaceCount 1 bFunctionClass 255 Vendor Specific Class bFunctionSubClass 0 bFunctionProtocol 0 iFunction 2 Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 0 bNumEndpoints 4 bInterfaceClass 255 Vendor Specific Class bInterfaceSubClass 128 bInterfaceProtocol 85 iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x82 EP 2 IN bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0040 1x 64 bytes bInterval 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x02 EP 2 OUT bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0040 1x 64 bytes bInterval 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x81 EP 1 IN bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0040 1x 64 bytes bInterval 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x01 EP 1 OUT bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0040 1x 64 bytes bInterval 0 Interface Association: bLength 8 bDescriptorType 11 bFirstInterface 1 bInterfaceCount 2 bFunctionClass 2 Communications bFunctionSubClass 2 Abstract (modem) bFunctionProtocol 1 AT-commands (v.25ter) iFunction 4 Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 1 bAlternateSetting 0 bNumEndpoints 1 bInterfaceClass 2 Communications bInterfaceSubClass 2 Abstract (modem) bInterfaceProtocol 1 AT-commands (v.25ter) iInterface 0 CDC Header: bcdCDC 1.10 CDC Call Management: bmCapabilities 0x00 bDataInterface 1 CDC ACM: bmCapabilities 0x02 line coding and serial state CDC Union: bMasterInterface 1 bSlaveInterface 2 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x84 EP 4 IN bmAttributes 3 Transfer Type Interrupt Synch Type None Usage Type Data wMaxPacketSize 0x0040 1x 64 bytes bInterval 1 Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 2 bAlternateSetting 0 bNumEndpoints 2 bInterfaceClass 10 CDC Data bInterfaceSubClass 0 Unused bInterfaceProtocol 0 iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x83 EP 3 IN bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0040 1x 64 bytes bInterval 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x03 EP 3 OUT bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0040 1x 64 bytes bInterval 0
和宿主机里面不一样:
binwatson@LAPTOP-0GJDRKKJ:~/docker/development_environment_docker/ch32$ lsusb -v -s 001:003 Bus 001 Device 003: ID 1a86:8010 QinHeng Electronics Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 1.10 bDeviceClass 239 Miscellaneous Device bDeviceSubClass 2 ? bDeviceProtocol 1 Interface Association bMaxPacketSize0 64 idVendor 0x1a86 QinHeng Electronics idProduct 0x8010 bcdDevice 2.12 iManufacturer 1 wch.cn iProduct 2 WCH-Link iSerial 3 BC66DF7E9BE4 bNumConfigurations 1 Configuration Descriptor: bLength 9 bDescriptorType 2 wTotalLength 120 bNumInterfaces 3 bConfigurationValue 1 iConfiguration 0 bmAttributes 0x80 (Bus Powered) MaxPower 100mA Interface Association: bLength 8 bDescriptorType 11 bFirstInterface 0 bInterfaceCount 1 bFunctionClass 255 Vendor Specific Class bFunctionSubClass 0 bFunctionProtocol 0 iFunction 2 WCH-Link Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 0 bNumEndpoints 4 bInterfaceClass 255 Vendor Specific Class bInterfaceSubClass 128 bInterfaceProtocol 85 iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x82 EP 2 IN bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0040 1x 64 bytes bInterval 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x02 EP 2 OUT bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0040 1x 64 bytes bInterval 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x81 EP 1 IN bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0040 1x 64 bytes bInterval 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x01 EP 1 OUT bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0040 1x 64 bytes bInterval 0 Interface Association: bLength 8 bDescriptorType 11 bFirstInterface 1 bInterfaceCount 2 bFunctionClass 2 Communications bFunctionSubClass 2 Abstract (modem) bFunctionProtocol 1 AT-commands (v.25ter) iFunction 4 WCH-Link Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 1 bAlternateSetting 0 bNumEndpoints 1 bInterfaceClass 2 Communications bInterfaceSubClass 2 Abstract (modem) bInterfaceProtocol 1 AT-commands (v.25ter) iInterface 0 CDC Header: bcdCDC 1.10 CDC Call Management: bmCapabilities 0x00 bDataInterface 1 CDC ACM: bmCapabilities 0x02 line coding and serial state CDC Union: bMasterInterface 1 bSlaveInterface 2 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x84 EP 4 IN bmAttributes 3 Transfer Type Interrupt Synch Type None Usage Type Data wMaxPacketSize 0x0040 1x 64 bytes bInterval 1 Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 2 bAlternateSetting 0 bNumEndpoints 2 bInterfaceClass 10 CDC Data bInterfaceSubClass 0 Unused bInterfaceProtocol 0 iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x83 EP 3 IN bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0040 1x 64 bytes bInterval 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x03 EP 3 OUT bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0040 1x 64 bytes bInterval 0 Device Status: 0x47c0 (Bus Powered) Debug Mode
然后在 Docker 里面执行
qomolink@c6b6d755ebf5:/tools/MRS_Toolchain_Linux_x64_V1.92.1/OpenOCD/bin$ ./openocd -f wch-riscv.cfg Open On-Chip Debugger 0.11.0+dev-02415-gfad123a16-dirty (2024-11-11-16:29) Licensed under GNU GPL v2 For bug reports, read http://openocd.org/doc/doxygen/bugs.html Info : only one transport option; autoselect 'sdi' Warn : Transport "sdi" was already selected Ready for Remote Connections Info : Listening on port 6666 for tcl connections Info : Listening on port 4444 for telnet connections Error: libusb_open() failed with LIBUSB_ERROR_ACCESS Error: open failed
在宿主机就是正常的
binwatson@LAPTOP-0GJDRKKJ:~/docker/development_environment_docker/ch32/MRS_Toolchain_Linux_x64_V1.92.1/OpenOCD/bin$ ./openocd -f w ch-riscv.cfg Open On-Chip Debugger 0.11.0+dev-02415-gfad123a16-dirty (2024-11-11-16:29) Licensed under GNU GPL v2 For bug reports, read http://openocd.org/doc/doxygen/bugs.html Info : only one transport option; autoselect 'sdi' Warn : Transport "sdi" was already selected Ready for Remote Connections Info : Listening on port 6666 for tcl connections Info : Listening on port 4444 for telnet connections Info : WCH-Link-CH549 mode:RV version 2.12 Info : wlink_init ok Info : clock speed 6000 kHz Info : [wch_riscv.cpu.0] datacount=2 progbufsize=8 Info : [wch_riscv.cpu.0] Examined RISC-V core; found 1 harts Info : [wch_riscv.cpu.0] XLEN=32, misa=0x40901125 [wch_riscv.cpu.0] Target successfully examined. Info : starting gdb server for wch_riscv.cpu.0 on 3333 Info : Listening on port 3333 for gdb connections
