设想:采用定时器,中断触发后通过串口发送一串hex出去。
代码如下:
timer.h
#ifndef TIMER_H #define TIMER_H #include "debug.h" // Timer configuration structure typedef struct { uint16_t period; // Auto-reload value uint16_t prescaler; // Clock prescaler uint8_t priority; // Interrupt priority uint8_t sub_priority; // Interrupt sub-priority } Timer_Config_t; // Initialize Timer2 with configuration void Timer2_Init(Timer_Config_t *config); // Register callback for Timer2 interrupt void Timer2_RegisterCallback(void (*callback)(void)); // Start/Stop Timer2 void Timer2_Start(void); void Timer2_Stop(void); #endif
timer.c
// timer.c #include "timer.h" static void (*timer2_callback)(void) = NULL; void TIM2_IRQHandler(void) __attribute__((interrupt("WCH-Interrupt-fast"))); void Timer2_Init(Timer_Config_t *config) { TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure = {0}; NVIC_InitTypeDef NVIC_InitStructure = {0}; // Enable Timer2 clock RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE); // Configure Timer TIM_TimeBaseStructure.TIM_Period = config->period - 1; TIM_TimeBaseStructure.TIM_Prescaler = config->prescaler - 1; TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure); // Enable Timer2 interrupt TIM_ITConfig(TIM2, TIM_IT_Update, ENABLE); // Configure NVIC NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = config->priority; NVIC_InitStructure.NVIC_IRQChannelSubPriority = config->sub_priority; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); } void Timer2_RegisterCallback(void (*callback)(void)) { timer2_callback = callback; } void Timer2_Start(void) { TIM_Cmd(TIM2, ENABLE); } void Timer2_Stop(void) { TIM_Cmd(TIM2, DISABLE); } void TIM2_IRQHandler(void) { if (TIM_GetITStatus(TIM2, TIM_IT_Update) != RESET) { TIM_ClearITPendingBit(TIM2, TIM_IT_Update); // Execute callback if registered if (timer2_callback != NULL) { timer2_callback(); } } }
main.c片段
//发送hex void KeepAlive(void) { // 构建返回数据结构 uint8_t response[10]; uint8_t address=0; response[0] = FRAME_HEAD; if (rx_buffer[1]==0x00) { address = 0x11; } else { address = rx_buffer[1]; } response[1] = ((address & 0x70) >> 4) | ((address & 0x07) << 4); response[2] = g_tm1650_data[0]; response[3] = g_tm1650_data[1]; response[4] = 0x13; //当前为固定值 g_tm1650_data[2]; response[5] = 0x14; //当前为固定值 g_tm1650_data[3]; response[6] = g_tm1804_data; response[7] = 0x17; //当前为固定值 // 计算校验码 uint8_t resp_checksum = 0; for (int i = 1; i <= 7; i++) { resp_checksum ^= response[i]; } response[8] = resp_checksum; response[9] = FRAME_TAIL; // 发送返回数据 for (int i = 0; i < 10; i++) { while(USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET); USART_SendData(USART1, response[i]); } } int main(void) { NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1); SystemCoreClockUpdate(); Delay_Init(); // 配置1秒定时器 Timer_Config_t timer_config = { .period = 1000, // 1ms周期 .prescaler = 48, // 48分频 .priority = 1, // 优先级1 .sub_priority = 0 // 子优先级0 }; // 初始化定时器 Timer2_Init(&timer_config); // 注册回调函数 Timer2_RegisterCallback(KeepAlive); // 启动定时器 Timer2_Start(); while(1) { } }
当前碰到的问题是:无论如何修改.period = 1000值,感觉触发中断的时间都没有变化。
CH390:以太网控制器芯片
