CH375 library compile warning messages
when we use the ch375 library in keil C,after "build all" the following warning messages positivappear.Is something wrong with my library setting?Any positive suggestions is welcome.
Best Regards for you all mikeliu
-------------------------- following warning messages --------------------------
*** WARNING L2: REFERENCE MADE TO UNRESOLVED EXTERNAL SYMBOL: MCMDPARAM MODULE: ..\CH375HF4.LIB (CH375SEC) ADDRESS: 28A2H *** WARNING L2: REFERENCE MADE TO UNRESOLVED EXTERNAL SYMBOL: MCMDPARAM MODULE: ..\CH375HF4.LIB (CH375SEC) ADDRESS: 1A5EH *** WARNING L2: REFERENCE MADE TO UNRESOLVED EXTERNAL
-------------------------- warning messages --------------------------
Maybe the "CH375HF4.H" can't be included successfully in your project,you can refrence the following example:UploadImages/20087148514535.rar
我也遇到了这种问题,H文件已经包含进去了,但是使用动态连接库里面的变量和函数就有问题。 问题也是REFERENCE MADE TO UNRESOLVED EXTERNAL。是不是动态连接库有问题啊???我用的是CH375HF4.LIB。
上面的示例工程也不行么? “REFERENCE MADE TO UNRESOLVED EXTERNAL”具体是什么?
