stm32+ch376并口
板子自带的LCD用的FSMC的FSMC_Bank1_NORSRAM4,16b宽度的数据线。
STM32ZE与CH376模块引脚的连接如下:
STM32ZE CH376 D0-D7 --------------- D0-D7 A0(LCD_CON RS) ------ A0 PD4(LCD_CON RD) ----- CH375RD# PD5(LCD_CON WR) ----- CH375WR# PG6(FSMC_INT2) ------ CH375INT# PD7(FSMC_OE1) ------ CH375CS#
端口初始化如下: void CH376_PORT_INIT(void) { FSMC_NORSRAMInitTypeDef FSMC_NORSRAMInitStructure; FSMC_NORSRAMTimingInitTypeDef p; GPIO_InitTypeDef GPIO_InitStructure;
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_FSMC, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE | RCC_APB2Periph_GPIOF | RCC_APB2Periph_GPIOG|RCC_APB2Periph_AFIO, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_7 | GPIO_Pin_14 | GPIO_Pin_15; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOD, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10; GPIO_Init(GPIOE, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; GPIO_Init(GPIOF, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 ; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init(GPIOG, &GPIO_InitStructure);
p.FSMC_AddressSetupTime = 0; p.FSMC_AddressHoldTime = 2; p.FSMC_DataSetupTime = 4; p.FSMC_BusTurnAroundDuration = 0; p.FSMC_CLKDivision = 0; p.FSMC_DataLatency = 0; p.FSMC_AccessMode = FSMC_AccessMode_A;
FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM1; FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable; FSMC_NORSRAMInitStructure.FSMC_MemoryType = FSMC_MemoryType_SRAM; FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_8b; FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode = FSMC_BurstAccessMode_Disable; FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low; FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable; FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState; FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable; FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable; FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable; FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable; FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &p; FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &p;
FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure);
FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM1, ENABLE); }
CH376.H 中如下设置: #define CH376_DAT_PORT (*( vu32 *)0x60000000) // A0 = 0, CS = 0 #define CH376_CMD_PORT (*( vu32 *)0x60000002) // A0 = 1, CS = 0
在芯片初始化中卡住了:
u8 mInitCH376Host(void) { // u8 u8Result; CH376_PORT_INIT(); /* 接口硬件初始化 */
/* 测试单片机与CH376之间的通讯接口 */ // 发送测试命令 xWriteCH376Cmd(CMD11_CHECK_EXIST); // 发送测试数据 xWriteCH376Data(0x65); // 读数据 u8Result = xReadCH376Data(); // 通讯正常的情况下将能读到测试数据的取反 if (u8Result != 0x9A ) { /* 通讯接口不正常,可能原因有:接口连接异常,其它设备影响(片选不唯一),串口波特率,一直在复位,晶振不工作 */ return ERR_USB_UNKNOWN; } /* 设备USB工作模式:主机模式 */ xWriteCH376Cmd(CMD11_SET_USB_MODE); xWriteCH376Data(0x06); DelayMs(10); u8Result = xReadCH376Data();
if (u8Result == CMD_RET_SUCCESS) { return USB_INT_SUCCESS; } else { /* 设置模式错误 */ return(ERR_USB_UNKNOWN); } }
每次都是返回未知错误。。。请大侠赐教。
首先确保你的测试命令通过,测试命令没通过会返回未知错误,测试命令没通过一般是硬件连线和接口时序的问题。
能具体一点么,或者有没有参考代码能看一下么,调了几天还是没有什么头绪
我们有51的例子程序需要你自己移植到STM32上去。
可以发过来看一下么,邮箱:个人信息保护,已隐藏,谢谢
大哥,能不能发一下代码看一下,谢谢了,邮箱:个人信息保护,已隐藏
代码到我们网站上下载CH376EVT.ZIP,里面有基于51单片机的例子。
谢谢
我参考了一下那个基于51的例子,和我的程序基本上差不多,但是我修改之后依旧初始化不成功,xWriteCH376Cmd(CMD11_CHECK_EXIST); // 发送测试数据 xWriteCH376Data(0x65); // 读数据 u8Result = xReadCH376Data(); // 通讯正常的情况下将能读到测试数据的取反 if (u8Result != 0x9A ) { /* 通讯接口不正常,可能原因有:接口连接异常,其它设备影响(片选不唯一),串口波特率,一直在复位,晶振不工作 */ return ERR_USB_UNKNOWN; } 一直都返回0x5F,感觉很奇怪,这是什么原因呢
你的测试命令有没有过?0x5F表示操作失败,是在哪边返回的?
就是测试命令没有通过,0x5F是u8Result的读取返回值
你多做几个命令试一下?是否有规律还是一直是0x5F?
不好意思,前一阵子有事;我测试了,一直都是返回0x5F
那是你测试命令都没有通过,检查一下你的硬件连接,晶振是否起振?复位是否完成?并口时序是否正确?
晶振是12M没错,复位是低电平,并口时序是指读写时序么
