CH375 枚举个别键盘,按键一秒以后才接受到键码
Bus Hound 6.01 capture on Windows Vista Service Pack 1 (x64). Complements of www.perisoft.net
123
  Device - Device ID (followed by the endpoint for USB devices)
            (9) 英特尔(R) USB 3.0 根集线器
            (27) USB Composite Device
            (28) USB 输入设备
            (29) USB 输入设备
  Length - Total transfer length
  Phase  - Phase Type
            CTL   USB control transfer
            IN    Data in transfer
            OUT   Data out transfer
            USTS  USB status
  Data   - Hex dump of the data transferred
  Descr  - Description of the phase
  Delta  - Elapsed time from the previous phase to the current phase
  Cmd... - Position in the captured data
  Time   - Time the phase occurred in hour:minute:second.millisec form
Device  Length    Phase  Data                                                Description       Delta  Cmd.Phase.Ofs(rep)  Time
  27.0            CTL    80 06 00 01  00 00 12 00                            GET DESCRIPTOR     24sc         1.1.0        11:41:22.391
  27.0        18  IN     12 01 00 02  00 00 00 08  ef 17 2d 60  30 01 01 02  ..........-`0...  3.2ms         1.2.0        11:41:22.394
                         00 01                                               ..                              1.2.16
  27.0            CTL    80 06 00 02  00 00 09 00                            GET DESCRIPTOR    487us         2.1.0        11:41:22.394
  27.0         9  IN     09 02 3b 00  02 01 00 a0  32                        ..;.....2         2.0ms         2.2.0        11:41:22.396
  27.0            CTL    80 06 00 02  00 00 3b 00                            GET DESCRIPTOR    164us         3.1.0        11:41:22.397
  27.0        59  IN     09 02 3b 00  02 01 00 a0  32 09 04 00  00 01 03 01  ..;.....2.......  8.3ms         3.2.0        11:41:22.405
                         01 00 09 21  11 01 00 01  22 41 00 07  05 81 03 08  ...!...."A......                3.2.16
                         00 0a 09 04  01 00 01 03  00 00 00 09  21 11 01 00  ............!...                3.2.32
                         01 22 a5 00  07 05 82 03  05 00 0a                  .".........                     3.2.48
  27.0            CTL    00 09 01 00  00 00 00 00                            SET CONFIG        212us         4.1.0        11:41:22.405
  27.0            CTL    80 06 02 03  09 04 04 00                            GET DESCRIPTOR    3.2ms         5.1.0(2)     11:41:22.408
  27.0         4  IN     3e 03 4c 00                                         >.L.              1.1ms         5.2.0        11:41:22.410
  27.0            CTL    80 06 02 03  09 04 3e 00                            GET DESCRIPTOR     14us         6.1.0(2)     11:41:22.410
  27.0        62  IN     3e 03 4c 00  65 00 6e 00  6f 00 76 00  6f 00 20 00  >.L.e.n.o.v.o. .  8.7ms         6.2.0        11:41:22.418
                         42 00 6c 00  61 00 63 00  6b 00 20 00  53 00 69 00  B.l.a.c.k. .S.i.                6.2.16
                         6c 00 6b 00  20 00 55 00  53 00 42 00  20 00 4b 00  l.k. .U.S.B. .K.                6.2.32
                         65 00 79 00  62 00 6f 00  61 00 72 00  64 00        e.y.b.o.a.r.d.                  6.2.48
  28.0            CTL    80 06 00 01  00 00 12 00                            GET DESCRIPTOR     14ms         9.1.0        11:41:22.432
  28.0        18  IN     12 01 00 02  00 00 00 08  ef 17 2d 60  30 01 01 02  ..........-`0...    7us         9.2.0        11:41:22.432
                         00 01                                               ..                              9.2.16
  28.0            CTL    80 06 00 02  00 00 09 00                            GET DESCRIPTOR      9us        10.1.0        11:41:22.432
  28.0         9  IN     09 02 22 00  01 01 00 a0  32                        ..".....2           4us        10.2.0        11:41:22.432
  28.0            CTL    80 06 00 02  00 00 22 00                            GET DESCRIPTOR      6us        11.1.0        11:41:22.432
  28.0        34  IN     09 02 22 00  01 01 00 a0  32 09 04 00  00 01 03 01  ..".....2.......    3us        11.2.0        11:41:22.432
                         01 00 09 21  11 01 00 01  22 41 00 07  05 81 03 08  ...!...."A......               11.2.16
                         00 0a                                               ..                             11.2.32
  28.0            CTL    00 09 01 00  00 00 00 00                            SET CONFIG          8us        12.1.0        11:41:22.432
  28.0            CTL    21 0a 00 00  00 00 00 00                            SET IDLE            7us        13.1.0        11:41:22.432
  28.0            CTL    81 06 00 22  00 00 81 00                            GET DESCRIPTOR    1.2ms        14.1.0        11:41:22.434
  28.0        65  IN     05 01 09 06  a1 01 05 07  19 e0 29 e7  15 00 25 01  ..........)...%.  8.9ms        14.2.0        11:41:22.443
                         75 01 95 08  81 02 95 01  75 08 81 01  95 03 75 01  u.......u.....u.               14.2.16
                         05 08 19 01  29 03 91 02  95 05 75 01  91 01 95 06  ....).....u.....               14.2.32
                         75 08 15 00  26 ff 00 05  07 19 00 2a  ff 00 81 00  u...&......*....               14.2.48
                         c0                                                  .                              14.2.64
  29.0            CTL    80 06 00 01  00 00 12 00                            GET DESCRIPTOR     54ms        15.1.0        11:41:22.497
  29.0        18  IN     12 01 00 02  00 00 00 08  ef 17 2d 60  30 01 01 02  ..........-`0...    8us        15.2.0        11:41:22.497
                         00 01                                               ..                             15.2.16
  29.0            CTL    80 06 00 02  00 00 09 00                            GET DESCRIPTOR      8us        16.1.0        11:41:22.497
  29.0         9  IN     09 02 22 00  01 01 00 a0  32                        ..".....2           5us        16.2.0        11:41:22.497
  29.0            CTL    80 06 00 02  00 00 22 00                            GET DESCRIPTOR      6us        17.1.0        11:41:22.497
  29.0        34  IN     09 02 22 00  01 01 00 a0  32 09 04 01  00 01 03 00  ..".....2.......    3us        17.2.0        11:41:22.497
                         00 00 09 21  11 01 00 01  22 a5 00 07  05 82 03 05  ...!....".......               17.2.16
                         00 0a                                               ..                             17.2.32
  29.0            CTL    00 09 01 00  00 00 00 00                            SET CONFIG          8us        18.1.0        11:41:22.497
  29.0            CTL    21 0a 00 00  01 00 00 00                            SET IDLE            8us        19.1.0        11:41:22.497
  29.0            CTL    81 06 00 22  01 00 e5 00                            GET DESCRIPTOR    1.0ms        20.1.0        11:41:22.498
  29.0       165  IN     05 01 09 80  a1 01 85 01  19 81 29 83  15 00 25 01  ..........)...%.   20ms        20.2.0        11:41:22.519
                         95 03 75 01  81 02 95 05  81 01 c0 06  0c 00 09 01  ..u.............               20.2.16
                         a1 01 85 02  25 01 15 00  75 01 0a e2  00 0a ea 00  ....%...u.......               20.2.32
                         0a e9 00 0a  b6 00 0a cd  00 0a b5 00  0a b3 00 0a  ................               20.2.48
                         b4 00 95 08  81 02 0a d0  00 0a d1 00  0a d2 00 0a  ................               20.2.64
                         d3 00 0a d5  00 0a d6 00  0a d4 00 0a  b8 00 95 08  ................               20.2.80
                         81 02 0a 94  01 0a 92 01  0a 83 01 0a  23 02 0a 8a  ............#...               20.2.96
                         01 0a 24 02  0a 25 02 0a  26 02 95 08  81 02 0a 27  ..$..%..&......'               20.2.112
                         02 0a 21 02  0a 2a 02 0a  b7 00 95 04  81 02 95 04  ..!..*..........               20.2.128
                         81 01 06 01  ff 95 01 75  08 15 00 26  ff 00 09 30  .......u...&...0               20.2.144
                         b1 03 c0 05  01                                     .....                          20.2.160
  27.0            CTL    80 06 00 02  00 00 09 00                            GET DESCRIPTOR    1.0sc        21.1.0        11:41:23.575
  27.0         9  IN     09 02 3b 00  02 01 00 a0  32                        ..;.....2         2.2ms        21.2.0        11:41:23.577
  27.0            CTL    80 06 00 02  00 00 3b 00                            GET DESCRIPTOR    299us        22.1.0        11:41:23.577
  27.0        59  IN     09 02 3b 00  02 01 00 a0  32 09 04 00  00 01 03 01  ..;.....2.......  7.7ms        22.2.0        11:41:23.585
                         01 00 09 21  11 01 00 01  22 41 00 07  05 81 03 08  ...!...."A......               22.2.16
                         00 0a 09 04  01 00 01 03  00 00 00 09  21 11 01 00  ............!...               22.2.32
                         01 22 a5 00  07 05 82 03  05 00 0a                  .".........                    22.2.48
  28.0            CTL    21 09 00 02  00 00 01 00                            SET REPORT        2.0sc        23.1.0        11:41:25.659
  28.0         1  OUT    00                                                  .                 1.5ms        23.2.0        11:41:25.660
  29.2            USTS   c0000004                                            stall pid         5.4sc        24.1.0        11:41:31.094
这是我键盘的bushound看到的采集结果;
我利用的单片机+CH375做主机来枚举这个键盘;
我的程序流程:获取设备描述符->设置地址->获取配置描述符->获取接口描述符->set_config(1)->set_idle()->get_report_descr_ex
然后set_config(1)->set_idle()->get_report_descr_ex来枚举第二个接口;
我已经把第一个set_idle()和第二个set_idle()改的和电脑的一样了,
现在现象时我按下任意一个按键都要等一秒左右才接受到信息,如果我改成二端点,采集多媒体的信息一样是要等一秒左右;你们帮我分析下这个问题,我实在没有什么办法了,困扰我一个多月了
你这个复合设备的枚举没看出有什么异常,方便的话把程序发到lb@wch.cn这个邮箱,我帮你你看一下是不是哪个地方处理的有问题。
邮件已经发过去了,您查看下
邮件已经发过去了,您查看下
邮件已回复,请查收。
楼主的键盘是个复合设备,造成这种现象的原因是开启了IN包重试功能,使用的时候关闭CH375的IN重试就可以了,即:
 CH375_WR_CMD_PORT(CMD_SET_RETRY);
CH375_WR_DAT_PORT(0x25);
CH375_WR_DAT_PORT(0x00);
这个程序可以直接外接键盘吗?敲击A键就显示A的键值吗?驱动这块怎么做的?
UploadImages/200710151704796.rar 可以参考此例程
