Hello,
Is it possible to use the CH376s as SPI master?
I am using the parallel interface on the MCU side, and I use the USB port for mass storage. I would like to use the SPI master port (meant for SD card) to connect other SPI peripherals (for example SPI to Ethernet controller).
I did not see a way to send raw SPI commands to the SPI slave port, only SD card support. Is it possible to do this?
