CH376,USB写文件不稳定
文件创建在根目录下,调用沁恒给的驱动往文件里面写数据,并关闭文件。加入写文件代码后,定时自动检测USB连接状态的函总是检测到USB设备自动断开连接的现象。而且打开文件,里面也没有数据。
ps:论坛上看见一个仁兄说每次新创建一个文件过后,文件里总是有一个字节的数据,我这里也有这个情况
附上代码
if(Get_Status(UsbConnect)==1&&Get_Status(UsbMount)==1&&Get_Status(UsbRdy)==0)//磁盘信息正确
         //CH376DirCreatePath("/CHARGE");
          if(CH376FileOpen("HOST.TXT")== ERR_MISS_FILE)
            if(CH376FileCreate("HOST.TXT")==USB_INT_SUCCESS){Set_Status(FileCreate,1);}
            else{Set_Status(FileOpen,0);Set_Status(FileCreate,0);}
          else
             CH376ByteLocate( 0xFFFFFFFF );
             Set_Status(FileOpen,1);
          if(Get_Status(FileCreate)==1||Get_Status(FileOpen)==1)
            Set_Status(UsbRdy,1);
        // s=CH376GetFileSize( );
        // Set_Status(FileSize,s);
      strcpy( Buf, "SHENMEGUI" );  /* 注意字符串长度不能溢出buf,否则加大缓冲区或者分多次写入 */
    s = CH376ByteWrite( Buf, s, NULL );  /* 以字节为单位向文件写入数据 */ //这个函数存在时,判断USB拔出的while循环会被直接跳过
         CLOSEFILE:
         if(Get_Status(FileOpen)==1||Get_Status(FileCreate)==1)
            if(CH376FileClose(TRUE)==USB_INT_SUCCESS)
            else
             goto CLOSEFILE;
         LED=0xE7;
         Ch376TaskCnt++;
if(Get_Status(UsbRdy)==1)
         if(CheckUsbConnect()!=USB_INT_SUCCESS)
          Set_Status(UsbConnect,0);
          Set_Status(UsbMount,0);
          Set_Status(UsbRdy,0);
把写文件函数屏蔽过后,就不会出现在没拔出U盘的情况下自动检测到U盘断开连接的现象了
 while(1)
          if(CH376FileOpen("HOST.TXT")== USB_INT_SUCCESS){
          else{
         s = CH376ByteWrite( "shenmegui", strlen( "shenmegui" ), NULL );
         if(Get_Status(FileCreate)==1||Get_Status(FileOpen)==1){
         CLOSEFILE:
         if(Get_Status(FileOpen)==1||Get_Status(FileCreate)==1){
          if(CH376FileClose(TRUE)==USB_INT_SUCCESS){Set_Status(FileOpen,0);Set_Status(FileCreate,0);}
          else{
             goto CLOSEFILE;
         while(CH376DiskConnect()==USB_INT_SUCCESS){
         BUZZ=1;
         BUZZ=0;
         LED=0xE7;
         Ch376TaskCnt++;
         //DelayMs(1000);
       else if(!(Get_Status(UsbConnect)==1&&Get_Status(UsbMount)==1))
         while(CheckUsbConnect()!=USB_INT_SUCCESS);//在这里等待USB插入
         Set_Status(UsbConnect,1);
         UsualDelay1ms(20);
         for(i=0;i<5;i++)
           if(CH376DiskMount()==USB_INT_SUCCESS)
               Set_Status(UsbMount,1);
               break;
         LED=0xE7;
         Ch376TaskCnt++;
         //DelayMs(1000);
       }else if(Get_Status(UsbRdy)==1){
          //DelayMs(100);
        } else{
           BUZZ=1;
           DelayMs(100);
           BUZZ=0;
       /*if(Flag_TakeOut){
         Flag_TakeOut=0;
     // s = CH376ByteWrite( "shenmegui", strlen( "shenmegui" ), NULL );  //这个函数存在时,判断USB拔出的while循环会被直接跳过
         CLOSEFILE:
          else{
             goto CLOSEFILE;
         BUZZ=1;
         BUZZ=0;
       DelayMs(80);
程序已更改,写文件的函数之前有点问题。但是现在还是写不进去数据。
不加入些文档这段函数,程序能够在执行完创建文件命令后等待拔出。
但是加入写字节函数过后,不动U盘就自动检测到U盘被拔出了
大神  在吗?? 我也在做这个  最近遇到一些问题  想请教你   我的QQ  994099840   希望大神可以叫我 帮我解决一下
