您好,9141硬件设计参考已发送至邮箱。
需要使用DC-DC,建议vsw引脚外接品质好一些的绕线电感。
建议电感参数:
额定电流>100mA
自谐振频率>11Mhz
等效电阻<1Ω
建议电感参数:
额定电流>100mA
自谐振频率>11Mhz
等效电阻<1Ω
Hello. Can you tell us more about using DC-DC? If you don’t use it, where and how should you connect this pin?
Or you can keep the L1 pads, and weld 0Ω resistance instead of inductance.
There is no impact remaining L1 on PCB when DC-DC is shut.
Please tell me how DC-DC is turned on/off? And in general, what is it for? Are there any documents with a more detailed technical description of the CH9141 chip?
Forget it. DC-DC is not suppoted by any version of CH9141 now.?
There is a inductance L2 on CH9141_B-PCB, but just works with previous CH9141-firmware.
So just ↓.
CH58x/CH59x series MCUs suppot DC-DC. It can reduce about 50% of average current.
你好 硬件电路原理图可以发我一份参考一下么 个人信息保护,已隐藏
已发送至邮箱,请查收。
已发送至邮箱,请查收。
您好,可以发一份硬件电路原理图参考一下吗
请发送至邮箱lpc@wch.cn,备注需要资料进行获取。
您好,可以发一份硬件电路原理图吗,谢谢
连接好蓝牙模块后,开发板的电压就从3.3掉到2.1,2.2,这个是什么原因呢?
我也求一份电路原理图,谢谢啦!
使用稳压源供电,查看是否会出现掉电压的情况。
电路硬件参考可以发送至lpc@wch.cn,备注需求,进行获取。
