CH573蓝牙作为主机时无法接收从机发来的透传数据
我用CH573跑蓝牙主机程序,现在能找到并连接从机设备,但是无法接收来自从机的透传数据,想请假大家,是不是因为主机程序中没有使能CCCD,所以接收不到notify。如果是的话,主机程序中该如何使能CCCD。
下面图片是串口输出的一些信息。
蓝牙连上后,一般来说 要先进行服务和特征发现,
拿到对应uuid 对应的handle,
然后根据handle去操作,诸如使能cccd,和读写数据
如下面是一个发现服务,发现char 和获取cccd 对应的handle的api:
void central_db_dis_process(void){
    uint8_t result = 0;
    attReadByTypeReq_t req;
    switch(ble_db_dis_state){
        case BLE_DISC_STATE_IDLE:
            break;
        case BLE_DISC_STATE_SVC:
            result = GATT_DiscPrimaryServiceByUUID( centralConnHandle,
                            service_uuid,
                             16,
                             centralTaskId );
            PRINT("GATT_DiscPrimaryServiceByUUID:%x\r\n",result);
            break;
        case BLE_DISC_STATE_CHAR:
            result = GATT_DiscAllChars(centralConnHandle,centralSvcStartHdl,centralSvcEndHdl,centralTaskId);
            break;
        case BLE_DISC_STATE_CCCD:
            req.startHandle = centralSvcStartHdl;
            req.endHandle = centralSvcEndHdl;
            req.type.len = ATT_BT_UUID_SIZE;
            req.type.uuid[0] = LO_UINT16(GATT_CLIENT_CHAR_CFG_UUID);
            req.type.uuid[1] = HI_UINT16(GATT_CLIENT_CHAR_CFG_UUID);
            result = GATT_ReadUsingCharUUID( centralConnHandle, &req, centralTaskId );
            break;
        default:
            break;
    if(result != SUCCESS){
        if(centralConnHandle != BLE_STATE_IDLE){
            tmos_start_task(centralTaskId,START_SVC_DISCOVERY_EVT,1600);
        }else{
            PRINT("conntection has been disconnected\r\n");
其中处理函数为:
 * @fn      centralGATTDiscoveryEvent
 * @brief   Process GATT discovery event
 * @return  none
static void centralGATTDiscoveryEvent( gattMsgEvent_t *pMsg ){
    PRINT("centralGATTDiscoveryEvent\r\n");
            // Service found, store handles
            if ( pMsg->method == ATT_FIND_BY_TYPE_VALUE_RSP ){
                if( pMsg->msg.findByTypeValueRsp.numInfo > 0 ){
                    centralSvcStartHdl = ATT_ATTR_HANDLE(pMsg->msg.findByTypeValueRsp.pHandlesInfo,0);
                    centralSvcEndHdl = ATT_GRP_END_HANDLE(pMsg->msg.findByTypeValueRsp.pHandlesInfo,0);
                    // Display Profile Service handle range
                    PRINT("Found Profile Service handle : %x ~ %x \n",centralSvcStartHdl,centralSvcEndHdl);
                if( ( pMsg->hdr.status == bleProcedureComplete )||( pMsg->method == ATT_ERROR_RSP ) ) {
                      if ( centralSvcStartHdl != 0 ){
                          central_db_dis_change_state(BLE_DISC_STATE_CHAR);
            break;
            // Characteristic found, store handle
            if ( pMsg->method == ATT_READ_BY_TYPE_RSP ){
                if(pMsg->msg.readByTypeRsp.numPairs > 0 ){
                    for(unsigned char i = 0; i < pMsg->msg.readByTypeRsp.numPairs ; i++){
#if 0
                            //characteristic properties
                            uint8_t char_properties = pMsg->msg.readByTypeRsp.pDataList[pMsg->msg.readByTypeRsp.len * i + 2];
#endif
                            uint16_t char_value_handle = BUILD_UINT16(pMsg->msg.readByTypeRsp.pDataList[pMsg->msg.readByTypeRsp.len * i+3], \
                                                            pMsg->msg.readByTypeRsp.pDataList[pMsg->msg.readByTypeRsp.len * i + 4]);
                            //characteristic uuid length
                            uint8_t char_uuid_length = pMsg->msg.readByGrpTypeRsp.len - 5;
                            //uuid
                            uint8_t *chat_uuid = &(pMsg->msg.readByGrpTypeRsp.pDataList[pMsg->msg.readByGrpTypeRsp.len * i + 5]);
                            if(sizeof(write_uuid) == char_uuid_length){
                                if(tmos_memcmp(write_uuid,chat_uuid,char_uuid_length)){
                                    PRINT("write_uuid found,handle:%02x\r\n",char_value_handle);
                                }else if(tmos_memcmp(notify_uuid,chat_uuid,char_uuid_length)){
                                    PRINT("notify uuid found,handle:%02x\r\n",char_value_handle);
                if((pMsg->hdr.status == bleProcedureComplete ) || ( pMsg->method == ATT_ERROR_RSP ) ) {
                    central_db_dis_change_state(BLE_DISC_STATE_CCCD);
                    PRINT("BLE_DISC_STATE_CHAR done\r\n");
            break;
        if ( pMsg->method == ATT_READ_BY_TYPE_RSP) {
            if(pMsg->msg.readByTypeRsp.numPairs > 0 ) {
                centralCCCDHdl = BUILD_UINT16( pMsg->msg.readByTypeRsp.pDataList[0],
                                             pMsg->msg.readByTypeRsp.pDataList[1] );
                PRINT("Found client characteristic configuration handle : %x \n",centralCCCDHdl);
                central_enbale_notify(centralConnHandle,centralCCCDHdl);
            ble_db_dis_state = BLE_DISC_STATE_IDLE;
        break;
      default:
            break;
然后enable notify 可以是:
uint8_t central_gatt_write_char_value(uint16_t connection_handle,uint16_t char_handle,uint8_t *data,uint16_t length){
    uint8_t result;
    attWriteReq_t req;
    req.cmd = FALSE;
    req.sig = FALSE;
    req.handle = char_handle;
    req.len = length;
    req.pValue = GATT_bm_alloc(connection_handle,ATT_WRITE_REQ,req.len,NULL,0);
    if ( req.pValue != NULL ){
        tmos_memcpy(req.pValue,data,length);
        result = GATT_WriteCharValue(centralConnHandle,&req,centralTaskId);
        if(SUCCESS == result){
            return SUCCESS;
        }else{
            GATT_bm_free((gattMsg_t *)&req, ATT_WRITE_REQ);
            write_data_when_failed.connection_handle = connection_handle;
            write_data_when_failed.char_handle = char_handle;
            write_data_when_failed.data_length = length;
            tmos_memcpy(write_data_when_failed.data,data,write_data_when_failed.data_length);
            PRINT("data0 data1=%02x %02x \r\n",write_data_when_failed.data[0],write_data_when_failed.data[1]);
            tmos_start_task(centralTaskId,START_WRITE_EVT,80);
            return result;
    return 0xff;
uint8_t central_enbale_notify(uint16_t connection_handle,uint16_t notify_handle){
    uint8_t data[2] = {0x01,0x00};
    return central_gatt_write_char_value(connection_handle,notify_handle,data,2);
uint8_t central_disable_notify(uint16_t connection_handle,uint16_t notify_handle){
    uint8_t data[2] = {0x00,0x00};
你好,请问这个问题解决了吗?我用主机程序或者主从一体的程序,也是出现这个问题。
@TECH46,上传代码是哪个例程里面的,可以发给我么,个人信息保护,已隐藏谢谢!
已发送至邮箱,请查收。
