Hello!
For some reasons I need to disable autonegotiation and force Ethernet PHY to 10M Half-Duplex. I am tried to write a value 0 into PHY register 0, but without success. The register value still 0x1100. So the questions:
1) Is it possible to force PHY into specific mode?
2) What I need to do?
3) What is the exact procedure to write into PHY registers (it seems to be different from CH563)?
CH347:高速USB转接芯片
